tehzack Posted October 22, 2009 Report Share Posted October 22, 2009 I posted a lot of pics!! Also, SFBMX88 did as well... haha... It's pretty simple yo!! If you just want to use front inserts, all you need to do is get KYB gland nuts (email customer support and they'll hook you up) and make a spacer (about 2") for the bottom of the MR2 inserts, easy!! If you want to go baller low like I did, you'll just need to cut a 2" section out of the strut housings, and reweld it. Rears, SHP rears are the easiest, same route. With non shp rears you need to either rethread the housings or use a front set of housings threaded portion and weld it to the rear. -Robert So you can weld on the struts without them exploding in your face? I'm a little confused on that part. I've always heard and seen on struts to keep them away from extreme heat. Link to comment Share on other sites More sharing options...
spoolinturbo Posted October 22, 2009 Author Report Share Posted October 22, 2009 he is talking about welding the housings, the strut inserts don't get welded Link to comment Share on other sites More sharing options...
thagremlin Posted October 22, 2009 Report Share Posted October 22, 2009 I've talked to that guy that owns the Starion, he was selling it on CL for awhile. He was running a set of Lincoln LSC meshies on it. That bronze 944 in the first pic is a friend of his. Cool dude, gave me some advice on wheel selection. Here's a couple pics he emailed me: did he give you the bolt pattern for those wheels.. i always thought they werent 5x114. Link to comment Share on other sites More sharing options...
MoltoMario Posted October 22, 2009 Report Share Posted October 22, 2009 You will probably have to have the hubs bored out too Link to comment Share on other sites More sharing options...
dmyers151 Posted October 22, 2009 Report Share Posted October 22, 2009 did he give you the bolt pattern for those wheels.. i always thought they werent 5x114. Said they fit the hubs without any issues, I think they are 5x4.5". If you were to get 'em tho, you'd need something like a 1-1/2" spacer for the rears. They are all 16x7's I believe. Link to comment Share on other sites More sharing options...
Komeuppance Posted October 22, 2009 Report Share Posted October 22, 2009 Appreciate this info. Nice clear and concise. Only question is when you cut and re welded your fronts did you also use a 2 inch spacer? No spacer needed if you are shortening the strut housings. The MR2 struts are shorter than the stock strut housings, so that is why a spacer is needed. I'm gonna do the rears soon, I'll get some pics for ebreybawdee. Hmmm... so he ISN'T lower than me... -Robert Link to comment Share on other sites More sharing options...
BrazilBoy Posted October 22, 2009 Report Share Posted October 22, 2009 Hmmm... so he ISN'T lower than me... -RobertNobodies lower than you.....................................or your car for that matter....... Link to comment Share on other sites More sharing options...
dmyers151 Posted October 22, 2009 Report Share Posted October 22, 2009 I found an email I had from the guy, his name's Nate and he's from Orlando: You got a good eye dude these r a diamond in the rough, absolutely will tell u, I'm using ichiban 1"1/2 Spacers for the rear, they r safe I got mine used for $50 but they are a lot more than that, not a s*** brand but anyway, I have 2" lowering springs from h&r so the stance is quite different as u can c. The tires are 205/50/16 in front and 215/55/16 rear, u can run wider but stay with a 55 series there's room in the fender fir the rear but the front is perfect. Any questions hit me up, also I happen to get those meshies for $100 in mint, good luck let me know. Link to comment Share on other sites More sharing options...
Komeuppance Posted October 22, 2009 Report Share Posted October 22, 2009 Slammed SQ's FTW!! Molto, that car needs to be lower!! I think I'm a bit used to my lack of ground clearance, stock height just seems WAY too high. Nobodies lower than you.....................................or your car for that matter....... No fat chicks... exhaust will scrape, tires will rub on fender, and I'll lose my super potential!! -Robert Link to comment Share on other sites More sharing options...
MoltoMario Posted October 22, 2009 Report Share Posted October 22, 2009 Slammed SQ's FTW!! Molto, that car needs to be lower!! I think I'm a bit used to my lack of ground clearance, stock height just seems WAY too high. No fat chicks... exhaust will scrape, tires will rub on fender, and I'll lose my super potential!! -Robert Haha I would go lower but I cant!. Any lower and I will have ZERO suspention travel . I need to work on a Wheel set up. A set of nice Volks or Works with a 9in/+12ish In the Front and a 10/-4 in the rear should be nice Link to comment Share on other sites More sharing options...
thagremlin Posted October 23, 2009 Report Share Posted October 23, 2009 (edited) this is how low i am. with my cat installed i scrape more than with the test pipe see the lighter in front of the car.http://i49.photobucket.com/albums/f256/maricherry1987/Starion%20stuff/101_3594.jpghttp://i49.photobucket.com/albums/f256/maricherry1987/Starion%20stuff/101_3591.jpg Edited October 23, 2009 by thagremlin Link to comment Share on other sites More sharing options...
spoolinturbo Posted October 23, 2009 Author Report Share Posted October 23, 2009 i want your wheels =( Link to comment Share on other sites More sharing options...
Convette Posted October 23, 2009 Report Share Posted October 23, 2009 man I love how woman of ill reputed out your car is, f=-in beautiful, especially those wheels.. Its been on my back ground at work for a while... My cars low too... (eventhough its empty)..lol bout 3 fingers high http://i177.photobucket.com/albums/w239/johnboy9788/1256314066.jpg Link to comment Share on other sites More sharing options...
thagremlin Posted October 23, 2009 Report Share Posted October 23, 2009 Yea when I get coilovers in the rear I might go just a tad bit lower. Link to comment Share on other sites More sharing options...
dmyers151 Posted October 23, 2009 Report Share Posted October 23, 2009 Yea when I get coilovers in the rear I might go just a tad bit lower. I'm confused, your running coil-ovahs up front and what out back right now? Just lowering springs? Link to comment Share on other sites More sharing options...
thagremlin Posted October 23, 2009 Report Share Posted October 23, 2009 Yea there just stock struts and st springs. And I have no rear interior, panels, spare etc. And still sits nice and low. Which is good because the drop looks nice and even. But I still want coilovers to be more stiff Link to comment Share on other sites More sharing options...
dmyers151 Posted October 23, 2009 Report Share Posted October 23, 2009 That's kicka$$, I may have to do that with my Eibach's so I can run the camber plates up front and not worry about having the car sit all crocked and look dumped out back. Thanks man Link to comment Share on other sites More sharing options...
