brianpaul98 Posted November 7, 2009 Author Report Share Posted November 7, 2009 I think Im going to want in but now I dont know which ones to get. I wanna lightly mod my engine eventually, at least 12psi on maybe a 14G... -Chris P Hey Chris, I'm running a 3" GM MAS, 3" Exhaust and a 20G turbo at about 23 ~ 25 psi boost and I'm using 2 85lb injectors. The MAFT is zeroed out and the Apexi SAFC settings are all about zero and its still running a little rich. I would say if you went with the stock replacement injectors (65lb and 95lb) you would almost be at the same cc's as mine. I just went this route because if I ever want to go MPI I just need to buy 2 more 85lb injectors instead of 4. If your running a 1G MAF and no SAFC to tune with you will probably be a lot rich with the 85lb injectors in there and won't have a way to lean it out. Let me know what you decide and I'll get them for you. Quote Link to comment Share on other sites More sharing options...
Cobalt60 Posted November 8, 2009 Report Share Posted November 8, 2009 OK I definitely want the 650 primary, secondary either 950 or 1050. Whats the added cost of the 1050? And can you accept a Postal MO as payment? Thanks -Chris P Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 8, 2009 Author Report Share Posted November 8, 2009 (edited) OK I definitely want the 650 primary, secondary either 950 or 1050. Whats the added cost of the 1050? And can you accept a Postal MO as payment? Thanks -Chris P Hello Chris, the 650cc and 950cc are $162.00 shipped and the 650cc and 1050cc are $166.96 so you have about a $5.00 difference. I do accept USPS Postal Money Orders and please send it to this address : Brian Arnone 17 Bielenda DriveCastle Hayne, NC. 28429 I put in orders every Monday so let me know what sizes you want and when you will be sending out the money order and I'll get these ordered for you. Edited November 8, 2009 by brianpaul98 Quote Link to comment Share on other sites More sharing options...
Hotpocket Posted November 9, 2009 Report Share Posted November 9, 2009 Hello Brian, I'd like a set of stock replacements ones. Can you put me down for the 650/950 set? HotpocketPaypal being sent as soon as I close this post. Thanks,Glenn 1 Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 9, 2009 Author Report Share Posted November 9, 2009 Hello Brian, I'd like a set of stock replacements ones. Can you put me down for the 650/950 set? HotpocketPaypal being sent as soon as I close this post. Thanks,Glenn Hello Glenn, I'll be ordering another batch this afternoon and I'll put you on the list for the stock replacements (650cc - 950cc). Quote Link to comment Share on other sites More sharing options...
88conquest_nutz Posted November 9, 2009 Report Share Posted November 9, 2009 id also like to purchase a set of stock replacements. Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 10, 2009 Author Report Share Posted November 10, 2009 id also like to purchase a set of stock replacements. I just put in my order today but if I receive your payment by noon tomorrow (11/10/09) I can add it to my order. Paypal $162.00 for the stock replacement injectors (650cc - 950cc) to : lower.shores.performance@gmail.com I'll add you to the list as soon as your payment posts and please be sure you send it as "GOODS". If you have any questions let me know. Quote Link to comment Share on other sites More sharing options...
89questzilla69 Posted November 10, 2009 Report Share Posted November 10, 2009 i was thinkin bout a 650 or 750 (prim) but i am thinkin big (sec) like the 1600 if i went 750 and 1600 is there anything i would have to change or do to make it run ok i am on stocks now and 21 lbs of boost is my high setting, i have your rockers and a tep cam w/ a straight through exhaust(no cat or muff) i want more though will i need a maft or safc to run these inj's Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 10, 2009 Author Report Share Posted November 10, 2009 (edited) i was thinkin bout a 650 or 750 (prim) but i am thinkin big (sec) like the 1600 if i went 750 and 1600 is there anything i would have to change or do to make it run ok i am on stocks now and 21 lbs of boost is my high setting, i have your rockers and a tep cam w/ a straight through exhaust(no cat or muff) i want more though will i need a maft or safc to run these inj's I'm running a 3" GM MAF w/ MAFT and APEXi SAFC with two 850cc injectors, a 20G turbo @ 23 psi with stock ported exhaust manifold, 3" exhaust w/ muffler, 1.6 roller rockers, 2 1/4" IC piping, stock TB and I don't need to add any fuel. There is no way you need injectors that big unless you have a BIG turbo running 30+ psi. If you go with any injectors bigger than the factory sizes you will more than likely need some type of AFC and definitely a wide band to tune them in. If you are using the stock MAF or a 1G MAF you won't need a MAFT. If you don't have an AFC I wouldn't recommend going bigger than the 650cc primary for driveability and a 1050cc secondary if you needed more fuel. This is the Wideband A/F gauge I recommend right here : Innovate LC-1 Edited November 10, 2009 by brianpaul98 Quote Link to comment Share on other sites More sharing options...
89questzilla69 Posted November 10, 2009 Report Share Posted November 10, 2009 but will i be ok on higher boost levels wit the 1050 im at 21 i would like to go a bit higher like 25 -30 Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 10, 2009 Author Report Share Posted November 10, 2009 but will i be ok on higher boost levels wit the 1050 im at 21 i would like to go a bit higher like 25 -30 The only way to know for sure if you needed bigger injectors is if you had a wide band in the exhaust other wise your just guessing and I can't tell you what you need unless I was there and put a wide band in your exhaust to see what the A/F ratio was at 21 ~ 25 psi. Right now if your injectors are just running off the factory ECU with no AFC you still have plenty of fuel left for the size injectors that you have considering that they are in good working condition. Running bigger injectors isn't necessarily going to fix the problem of leaning out at higher boost levels unless you have a way to increase the fuel with an AFC and knowing where in the rpm range it needs to be increased. Bigger injectors will cause the engine to run rich across the whole RPM range and that will make the engine lose power. Right now your dipping your feet into the waters of tuning your car for maximum power output and in doing that you can't be guessing and I can't guess for you. Too little fuel and you lean out and melt a piston / head, too much fuel and you can detonate the engine and score the cylinders walls, break rings / ring lands, blow head gaskets, etc.... If your serious about this car and making big power with it and there is big power to be made the first investment you need to make is the wide band. Without it your driving with a blindfold on and your odds of crashing are very good. Quote Link to comment Share on other sites More sharing options...
88conquest_nutz Posted November 10, 2009 Report Share Posted November 10, 2009 money sent Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 11, 2009 Author Report Share Posted November 11, 2009 money sent I received your payment and just added you to the list Quote Link to comment Share on other sites More sharing options...
pitboss Posted November 11, 2009 Report Share Posted November 11, 2009 The only way to know for sure if you needed bigger injectors is if you had a wide band in the exhaust other wise your just guessing and I can't tell you what you need unless I was there and put a wide band in your exhaust to see what the A/F ratio was at 21 ~ 25 psi. Right now if your injectors are just running off the factory ECU with no AFC you still have plenty of fuel left for the size injectors that you have considering that they are in good working condition. Running bigger injectors isn't necessarily going to fix the problem of leaning out at higher boost levels unless you have a way to increase the fuel with an AFC and knowing where in the rpm range it needs to be increased. Bigger injectors will cause the engine to run rich across the whole RPM range and that will make the engine lose power. Right now your dipping your feet into the waters of tuning your car for maximum power output and in doing that you can't be guessing and I can't guess for you. Too little fuel and you lean out and melt a piston / head, too much fuel and you can detonate the engine and score the cylinders walls, break rings / ring lands, blow head gaskets, etc.... If your serious about this car and making big power with it and there is big power to be made the first investment you need to make is the wide band. Without it your driving with a blindfold on and your odds of crashing are very good. Not cutting in on your deal Brian, just wanting to pass on some info to him. I have a 650 pri. and 1150 sec. and my detonation light is indicating at constant 19 - 20 psi with a 14G, so it is possible to get TOO MUCH FUEL. I think this is my problem, but I also have alky injection so this needs looking into also. I know where he's coming from though. Boost is awesome until consistant full load at 19 psi. Stock injectors aren't quite cutting it, so you want new ones, but seriously, a 1050 will probably be the biggest sec. you'll need on a bigger than stock turbo in a TB. I should down size to one as well lol. Quote Link to comment Share on other sites More sharing options...
89questzilla69 Posted November 12, 2009 Report Share Posted November 12, 2009 The only way to know for sure if you needed bigger injectors is if you had a wide band in the exhaust other wise your just guessing and I can't tell you what you need unless I was there and put a wide band in your exhaust to see what the A/F ratio was at 21 ~ 25 psi. Right now if your injectors are just running off the factory ECU with no AFC you still have plenty of fuel left for the size injectors that you have considering that they are in good working condition. Running bigger injectors isn't necessarily going to fix the problem of leaning out at higher boost levels unless you have a way to increase the fuel with an AFC and knowing where in the rpm range it needs to be increased. Bigger injectors will cause the engine to run rich across the whole RPM range and that will make the engine lose power. Right now your dipping your feet into the waters of tuning your car for maximum power output and in doing that you can't be guessing and I can't guess for you. Too little fuel and you lean out and melt a piston / head, too much fuel and you can detonate the engine and score the cylinders walls, break rings / ring lands, blow head gaskets, etc.... If your serious about this car and making big power with it and there is big power to be made the first investment you need to make is the wide band. Without it your driving with a blindfold on and your odds of crashing are very good.\ at 21 w/ the fpr hooked up i am running bout 13.9 to 14.9 afr on an aem eugo Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 12, 2009 Author Report Share Posted November 12, 2009 \ at 21 w/ the fpr hooked up i am running bout 13.9 to 14.9 afr on an aem eugo I hate to say this but anything over 11.9 and your going to have a meltdown. Not knowing what condition the stock injectors are in I would recommend going with the 650cc or 750cc primary and 1050 secondary and you will be fine. If you can get your hands on an AFC like the APEXi 1st or 2nd gen then you can fine tune the injectors from there. Just be careful with what you have now because you are running dangerously lean at that boost level. Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 13, 2009 Author Report Share Posted November 13, 2009 The new batch of injectors just arrived and I'll have them ready to ship out either tomorrow or Monday. Quote Link to comment Share on other sites More sharing options...
89questzilla69 Posted November 13, 2009 Report Share Posted November 13, 2009 ok thanx for the info i thought i was a bit lean and others had told me i was ok i will be buying inj. from u but it will be a lil while maybe 2 weeks Quote Link to comment Share on other sites More sharing options...
dem0ntsi Posted November 13, 2009 Report Share Posted November 13, 2009 yay! are you going to email tracking numbers? Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 13, 2009 Author Report Share Posted November 13, 2009 yay! are you going to email tracking numbers? Yes, tracking numbers get sent out automatically through USPS when I print the shipping labels. If you didn't get one please let me know and I'll re-send it to you. Quote Link to comment Share on other sites More sharing options...
dem0ntsi Posted November 14, 2009 Report Share Posted November 14, 2009 Yes, tracking numbers get sent out automatically through USPS when I print the shipping labels. If you didn't get one please let me know and I'll re-send it to you. I didnt get an email, please resend if you can, thanks! Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 14, 2009 Author Report Share Posted November 14, 2009 I didnt get an email, please resend if you can, thanks! tracking number re-sent Quote Link to comment Share on other sites More sharing options...
aust75 Posted November 17, 2009 Report Share Posted November 17, 2009 Received my injectors today.Thanks!! Quote Link to comment Share on other sites More sharing options...
brianpaul98 Posted November 17, 2009 Author Report Share Posted November 17, 2009 Received my injectors today.Thanks!! Let me know when you get them installed and remember to leave some feedback. Quote Link to comment Share on other sites More sharing options...
xtremeboost Posted November 17, 2009 Report Share Posted November 17, 2009 \ at 21 w/ the fpr hooked up i am running bout 13.9 to 14.9 afr on an aem eugo WOW !!!! .... Yeah ... you need to relax with that ,turn down that boost or get bigger injectors . Quote Link to comment Share on other sites More sharing options...
