Everything posted by 88conquest_nutz
thanks guys
Hey everyone, I'm entered in a contest for Go Ape tickets, and I could use your votes. If you have a Go Ape near you i highly recommend it. It seriously takes 2 secs to vote for me, my pics name is Hulk goes Ape. thanks http://a.pgtb.me/hFp...052&e=100842586
finally selling her, just is becoming to much work for me. it has a 19c turbo on it, has full 3" exhaust with no muffler. has i believe 2 1/4" hard pipes, and a 3" intake. has the GM maf with maf translator, and a wideband. only has 52k miles as shown in the pic. rust is minimal, clear is peeling in most places, a few small dents. has a small coolant leak and a small oil leak. the clutch will need to be replaced, starts slipping in the upper gears. engine just started making a weird noise and i just dont want to mess with it anymore. $2500, located in myrtle beach, sc. more photos can be taken just ask, and ill answer questions as best as i can. i have a few spare turbos(need rebuilds) and manifolds and other spare parts that will be sold with the car as well
Conquest parts liquidation. Everything must go!
88conquest_nutz replied to on4now4's topic in Parts for sale
do you have a distributor with vac advance by chance? for an 88 quest -
WTB distributor w/ vacuum advance
88conquest_nutz replied to 88conquest_nutz's topic in Items Wanted
k -
looking for a good distributor with vacuum advance attached. thanks
do you have a good distributor with vaccum advance?
dont know to much about them, grey one looks to be stock, and red one is ported. the exhaust side is ported on the red one where it meets the manifold. they both have some play in them. $75 for the grey one $100 for the red one http://i33.photobucket.com/albums/d72/ledzepballz/garage1460.jpg http://i33.photobucket.com/albums/d72/ledzepballz/garage1459.jpg http://i33.photobucket.com/albums/d72/ledzepballz/garage1462.jpg http://i33.photobucket.com/albums/d72/ledzepballz/garage1461.jpg
Met John Law today in the new Conquest.
88conquest_nutz replied to Dartomotive's topic in War Stories
yea whenever someone comes up and talks to me about my quest, they always say "my friend had one of those 'cars' " or "ive always liked those 'cars' " they will never say what kinda car it is, more then likely because they dont know what it is.... and i have told my friends what kinda car it is a few times and they still forget what its called. -
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/198692_10150276351959863_768079862_7246899_7999542_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/283192_10150276351774863_768079862_7246897_762815_n.jpg
is there a way to do this, rather then to just replace it?? just make the dash lights bright all the time?? thanks
how bout the dimmer switch?
ok, i got the tail lights working correct now. the fuse was blown. i checked all the other fuses and they were good. im using the same ground i used for my wideband. its connected to a ground wire off the ecu. another thing i noticed to, is even when i connect the dimmer switch and the dash lights do come on, my boost gauge doesnt light up. i dont know if that might have something to do with it. the guage was already in the car when i bought it.
ok i bought a radio harness, hooked everything up except for the dimmer wire and illumination wire. the radio lights up fine and works. but i have no dash lights or rear lights. now if i hook up the dimmer wire to the power wire, my gauge lights come on, but my hvac lights go off. if i hook up my illumination wire to a power wire, my rear lights come on and my hvac lights go off.... im confused. ive never wired in a radio so i might be missing something simple.
changed the bov vac source and problem solved. thanks guys
nope its a 5 speed. ill look into adjusting the bov and wastegate. thanks guys phinko get a better vac source for what??
i just got my car running again, and im pretty sure i have compressor surge. was just wondering if im correct and what could be causing it. i have a 19C with all hardpipes. i just installed a wideband and Maf-t, and got it tuned pretty good, still needs a little adjustment while cruising. its kinda hard to hear and you might need to turn your volume up to listen. oh ya i do have a bov and it goes off when i get into boost, this just happens when im get on it a little and let off the gas.
was great to do business with, part looks good, shipping was fast
i dont know what the piece is called, but i need the part that the oil filter, turbo oil line, and oil cooler lines bolt to.
oh ok, thanks.
im trying to hook up my A/F guage, and i searched and it said to hook it up to the shielded wire for the O2 sensor. well i found the wire, and it had this thing attached to it... just doesnt seem right to me. it was just connected to one of the screws that holds the ECU in place.
i should be able to make it. as long as the car is running good.
k, i just got my AEM eugo wideband all mounted, but now ive got to wire it in... and ive never really wired anything in, not even a stereo. my question is, can someone tell me what are good wires to connect to? wiring is like someone talking spanish to me, if you talk slow and use simple words i can understand hehe.
