3 quart Accusump, oil cooler, and filter relocation
SFBMX88
First, you can find information on these things here: http://www.accusump.com/
All this is on a non-intercooled flatty, so there was plenty of room to mount everything.
Had to get the mounting brackets welded on to the bumper. Power steering "cooler" had to be relocated along with the oil cooler.
Before:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01493.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01496.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01495.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01501.jpg
Stock power steering "cooler"
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01536.jpg
Mounting brackets I made for the power steering cooler:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01505.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01509.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01510.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01511.jpg
New location, used cooler. It used to be the oil cooler on my old car, but I flushed it out many many times...
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01513.jpg
Since the front end was all apart, I turned my radiator into a "Griffin" radiator....
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01522.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01525.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01526.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01530.jpg
Engine oil cooler is in a temporary spot for now until I get a new cooler+8-AN lines. Still have to plumb the Accusump in...
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01533.jpg
Edited by SFBMX88
8 AN to metric adapters(16x1.5mm)
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01703.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01704.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01705.jpg
Went to town with the stepped drill bit while I waited for paint to dry...
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01708.jpg
Use lots of lube!
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01706.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01709.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01711.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01712.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01714.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01716.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01722.jpg
Rubber lined clamps kept the hoses nice and tidy.
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01721.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01720.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01724.jpg
Wiring diagram for the Accsump control I drew
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01661.jpg
Had to make a switch mount...
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01727.jpg
Drilled the two holes abit off...dammit
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01728.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01730.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01731.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01733.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01742.jpg
Added a sump warning/function light to the gauge cluster. It will indicate when the valve opens. There was a blank spot in the cluster, so it was easy..
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01656.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01655.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01660.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01651.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01653.jpg
Red Sharpie!
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01654.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01659.jpg
Built another harness and ran the wires through existing holes in the firewall...
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01647.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01650.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01648.jpg
Engine oil primer button...
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01734.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01735.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01736.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01738.jpg
I dont like crimping!
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01740.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01739.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01743.jpg
Lots of solder/electrical tape/shrink wrap later...
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01745.jpg
Had to drill into the firewall to get this in(ac needs to be out of the way, but i removed all my ac anyway) :
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01623.jpg
Filter adapter:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01799.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01800.jpg
Plumbing train...will it fit?
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01803.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01809.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01810.jpg
Had to make a small mounting piece:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01812.jpg
Also found an odd bolt that helped everything come together perfectly:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01814.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01815.jpg
After everything was lined up and indexed, it all had to come back out and all the fittings tightend up:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01818.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01822.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01824.jpg
Tight fit!
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01831.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01832.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01833.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01837.jpg
Edited by SFBMX88
Last part of the harness had to be done too:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01882.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01883.jpg
Boost control solenoid in the works. Harness done though:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01884.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01886.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01887.jpg
Modified the stock oil pressure sender so I could monitor the sump pressure through the stock oil pressure gauge. Seemed like it would be hard to get back to electrical ground having to pass through a bunch of aluminum/clamps, so I soldered on its own ground wire.
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01804.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01805.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01807.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01816.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01817.jpg
Pressure sender adapter harness:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01918.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01920.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01923.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01921.jpg
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01926.jpg
Air charge side of sump, normal PSI after cold startup:
http://i5.photobucket.com/albums/y176/sfbmx88vol2/ultraspeed/DSC01994.jpg
Been around 200 miles with no problems at all! Oil changes should be abit easier, except for the fact this whole setup requires 3-4 more quarts of oil over the stock 5 quarts.
I will still intercool this car!
Edited by SFBMX88
Very nice job! I've been running a 3 quart accusump myself for a few years now and love it. Only difference is mine is wired to be on anytime the ignition is on so it's always active. I'm loving the primer button idea though!
Thanks!
I really liked the idea of having the setup work only when I wanted it to. Plus with the dash light hooked up, I think it would've gotten annoying seeing it come on every time the oil pressure dropped below the 55/60psi threshold(valve opens). The primer button is wired into a normally open relay, and once pressed, will stay energized until the pressure rises above 55/60psi. It will automatically shut off.
  • 3 weeks later...
I like the work you did Andrew. Though I have no idea how that stuff works, I want something nice lke that lol. It's just something about those AN fittings and shinny new oil cooler. Gotta let me check it out when I eventually take my car to your shop
