81zfan Posted April 27, 2009 Report Share Posted April 27, 2009 ok here we go fixing to pull the the stock 190,000 mile motor out and go through it and freshen it up!! so my question is after the rebuild i should have about a 1,000 dollars to throw into the car, i was wanting input on what would be the best mods that i can do with the money, it is completley stock nothing has been touched , all thoughts would be greatly appreciated !!!! Link to comment Share on other sites More sharing options...
Strickdawg Posted April 27, 2009 Report Share Posted April 27, 2009 Maf-t with 3in mas $200-$350 upgrade turbo to 14 or 16 $200-$400 hardpipes $250-$400 2.5 inch exhaust $250- $350 RR fuel pressure reg $80 MBC $70 Walbro fuel pump $120 88-89 ecu if you are not 88-89 $40-$80 Boost gauge $50 Wideband A/F gauge and sensor $200-$300 these are just a few Link to comment Share on other sites More sharing options...
cyberquest Posted April 27, 2009 Report Share Posted April 27, 2009 i would say a upgraded turbo, hardpipes and a nice Downpipe and a MBC to control the turbo. so far my stock 87 fuel system is doing FINE keeping up with a 20G @ 12psi. but those three things are a good start then work on the other things over time that strickdawg mentioned like the Link to comment Share on other sites More sharing options...
81zfan Posted April 27, 2009 Author Report Share Posted April 27, 2009 well it's a 88 i have already been looking at hardpipes and exhaust was going to get that, and already looked at the mbc and fuel pump, i was mainly wanting the other items like the turbo and maf, i gues i need to start searching for parts now, thanks for the quick reply, also can you get the maf with the trans. or do you build it, and wire it in, and will the 16g off of the talons/eclipse bolt up to the exhaust or do you have to have a special 14 or 16 turbo Link to comment Share on other sites More sharing options...
Strickdawg Posted April 27, 2009 Report Share Posted April 27, 2009 i bought my maf-t with 3in mas from ebay as a set for $165 for both. I got my aem wideband with sensor and gauge from ebay for $165 Got my Small 16g off of here fully rebuilt and ready to go for $300 Link to comment Share on other sites More sharing options...
garychoffmann Posted April 28, 2009 Report Share Posted April 28, 2009 I too would go for used parts. Stretch your budget immensely. I check ebay daily and I find alot of good deals. Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted April 28, 2009 Report Share Posted April 28, 2009 Poly suspension bushings, front strut isolators if cracked, and new struts. Link to comment Share on other sites More sharing options...
81zfan Posted May 4, 2009 Author Report Share Posted May 4, 2009 just wondering will the 16g from talon bolt up to the exhaust and fit or is there changes gonna have to be made?? Link to comment Share on other sites More sharing options...
81zfan Posted May 11, 2009 Author Report Share Posted May 11, 2009 what kind of mbc does everyone recommend i looked at the cheap one on ebay but don't know the quality Link to comment Share on other sites More sharing options...
dstar88 Posted May 11, 2009 Report Share Posted May 11, 2009 what kind of mbc does everyone recommend i looked at the cheap one on ebay but don't know the quality some ebay ones work good, i have a cheap ebay one and it works fine for me. ive had no problems with it. Daniel Link to comment Share on other sites More sharing options...
dstar88 Posted May 11, 2009 Report Share Posted May 11, 2009 (edited) just wondering will the 16g from talon bolt up to the exhaust and fit or is there changes gonna have to be made?? it will not bolt right up but it is do able. you will either have to port your stock exhaust housing to fit the biger td05h exhaust wheel (which is what most do i believe), or use a dsm exhaust housing and make a custom dp for it., to get the dsm exhaust housing to bold on, you will either have to get rid of the threading on the housing or get rid of the threading on the mainfold since they are both threaded, there is a little bit more machining to do as well with the housing to get the nuts to fit the studs like the stock exhaust housing does (thats if you get rid of the threading on the dsm exhaust housing). there are other things that need to be done to make it work properly as well. such as re-clock the cartridge to be right side up instead of upside down for our cars (talons and eclipses have the turbos under the manifold, not on top like ours). you will also have to re-clock the compressor housing to be able to have an easier fit for the hard pipe. you will then need to make a custom bracket to hold the waste gate actuator since the the compressor housing had to be re-clocked which would throw off the mounting position of waste gate actuator and keep it from doing its job (holding the waste gate closed)..thats if you use the stock exhaust housing, im not sure if you will need to make a bracket if you use the dsm housing, i havnt put that one on yet. once all this is done, you would have yourself a pretty good up grade. took me no more then a good day to do. Daniel Edited May 11, 2009 by dstar88 Link to comment Share on other sites More sharing options...
mistapickles Posted May 17, 2009 Report Share Posted May 17, 2009 Poly suspension bushings, front strut isolators if cracked, and new struts. a 16G manual boost controller and what Mike is saying all the other stuff affects your reliability. MAF-T, GM 3", blah blah blah, you'll be on the advanced virtual mechanic forum trying to get somebody to help you figure out why your car runs like crap. If you get a good running motor, have all your sensors working properly, and have some clean filters, you'll love the mess out of your car. K.I.S.S. Link to comment Share on other sites More sharing options...
Kane Posted May 19, 2009 Report Share Posted May 19, 2009 BEFORE ANYTHING GET A WIDEBAND O2 SENSOR!!!! ive learned my lesson blowing a forged piston, and warping the head. Link to comment Share on other sites More sharing options...
81zfan Posted May 19, 2009 Author Report Share Posted May 19, 2009 yeah thats what i was thinking getting ready to order wideband, hardpipes,and mbc today while i got some spare change!! Link to comment Share on other sites More sharing options...
