movin on Posted February 24, 2009 Report Share Posted February 24, 2009 (edited) Simple problem, but just too frustrated to think about it today. When tightening the positive terminal on my car. I touched the body of the car with a screw driver and there were some sparks. When I went to start my car, there was no power and the only thing I heard or saw was a click when I turned the key. I know this is a simple problem, but please somebody just tell me where and how to fix. Probably just looking for a main fuse or fuseable link. Thanks Edited February 25, 2009 by movin on Link to comment Share on other sites More sharing options...
19cturbo Posted February 25, 2009 Report Share Posted February 25, 2009 i believe there is a fuseable link right beisde the battery, it goes to the ignition... try that first.. Link to comment Share on other sites More sharing options...
Hoosierquest Posted February 25, 2009 Report Share Posted February 25, 2009 There is also the IGN wire that runs to the starter. its just a little spade connecter, make sure you did not leave it off. Link to comment Share on other sites More sharing options...
patra_is_here Posted February 25, 2009 Report Share Posted February 25, 2009 i don't see how shorting the positive battery post to ground would cause ANY issue with anything BUT the battery. if anything, i would check the terminal itself to make sure that the connectors at the post are tight and that everything is connected at the post as it should be. Link to comment Share on other sites More sharing options...
movin on Posted February 26, 2009 Author Report Share Posted February 26, 2009 I was just trying to explain everything that happened with grounding the battery like I did. Car is running now. I checked all the wires and some were loose. The car has sat for about five months and had a couple things done to it, so I am not surprised. Link to comment Share on other sites More sharing options...
GCNTSi Posted February 26, 2009 Report Share Posted February 26, 2009 I would bet that the IGN (for ignition) fusible link wire is near failing, it's located on the small box next to the battery that has four different fusible links. You may encounter the problem again, of the car not wanting to start, if so try wiggling that wire and checking the connections of it. -GCNTSi. Link to comment Share on other sites More sharing options...
