ALXunderpressure Posted May 21, 2003 Report Share Posted May 21, 2003 1.12 exhuast is still way big.... Link to comment Share on other sites More sharing options...
turbo26tsi Posted May 21, 2003 Author Report Share Posted May 21, 2003 1.12 exhuast is still way big.... so is 500WHP ;D Link to comment Share on other sites More sharing options...
BMWTech Posted May 21, 2003 Report Share Posted May 21, 2003 After reading a few articles on these turbos, I think those of that feel the turbine housing is too large, we are looking at it from the wrong point of view. I think someone posted it earler, but that 1.12 housing, isnt it based on a T3 housing? So that 1.12 A/R (which is just a ratio not a volume) is closer to a .70-.80 on a T4 turbine housing in terms of volume. So, given how much lighter the rotating mass in the turbo is and the ball bearing technology. It should be very efficient and make some nice power. This is what was confusing me, I was seeing 1.12 as a volume on a T4 housing and thinkig thats insanely large.....now i can see a little bit clearer -Neil Link to comment Share on other sites More sharing options...
Lizzord30 Posted May 21, 2003 Report Share Posted May 21, 2003 The exhaust side isnt as large as you would think by looking at it on paper, it is very heavy and thick, i dont think he will have any spool up issues with everything correctly set up. The wheel is about as large as my T3 stage 5 turbine, and mine isnt that bad of spool at all so i dont think he will have any major problems with spool Link to comment Share on other sites More sharing options...
Heybud Posted June 15, 2003 Report Share Posted June 15, 2003 ??? I was checking out your alternator setup. I looks like it will be able to handle the energy demand the can will need to get the car running well. I have been exploring customizing my stock alternator setup. It looks like you are using an eclipes alternator and a customize support bracket. Can you tell me a little about your alternator setup? Link to comment Share on other sites More sharing options...
turbo26tsi Posted June 15, 2003 Author Report Share Posted June 15, 2003 My alternator is out of a 2001 dodge caravan, and i have to run an external voltage regulator and use a talon bracket and some spacers. I haven't run the car yet, but it should work fine, and it is 150amp so it very powerful and looks to be high quality, its delco brand. thanks, kevin Link to comment Share on other sites More sharing options...
nuffnuff Posted June 16, 2003 Report Share Posted June 16, 2003 I just got off the dyno saterday and befor my rpm sensor started to pack it in we tuned up to 3500rpm on 8psi(wastgate) where it had 177whp I run a 60-1 a/r .70 with P-trim a/r 1.00 split tang we had 3psi at 2000rpm 7psi @ 2500rpm and was on the wastgate befor 3000 do plan on running 20psi so will let u know what rpm it hits that at next week Link to comment Share on other sites More sharing options...
Boosted_One Posted June 16, 2003 Report Share Posted June 16, 2003 I just got off the dyno saterday and befor my rpm sensor started to pack it in we tuned up to 3500rpm on 8psi(wastgate) where it had 177whp I run a 60-1 a/r .70 with P-trim a/r 1.00 split tang we had 3psi at 2000rpm 7psi @ 2500rpm and was on the wastgate befor 3000 do plan on running 20psi so will let u know what rpm it hits that at next week That's pretty darn good, especially with such a large A/R on the hot side! Are you running an open or split tang housing? Link to comment Share on other sites More sharing options...
Lizzord30 Posted June 16, 2003 Report Share Posted June 16, 2003 He says split tang in his post and in your quote ;D Link to comment Share on other sites More sharing options...
Boosted_One Posted June 16, 2003 Report Share Posted June 16, 2003 He says split tang in his post and in your quote ;D 7 psi at 2500... just goes to show how well the split tangs do work, even with a P trim and 1.00 A/R. Thanks for the clarification Lizzord. Link to comment Share on other sites More sharing options...
ALXunderpressure Posted June 16, 2003 Report Share Posted June 16, 2003 I just got my hands on the GT-30's very nice stuff quick spooling but I need to see how they respond with a big housing still. Link to comment Share on other sites More sharing options...
nuffnuff Posted June 16, 2003 Report Share Posted June 16, 2003 Hey Mike, Glen here(4gmits) my computer is down atm and i have forgoten my password and username so i have this for now. that was also with a gen2 magna head and my prototype turbo header that i have put a bit of thought into. so the GT turboes could b good. i have heard a lot of good about them. im also told that the 25g with the 12cm2 turbine end spools much better than my turbo and has more top end. so i amay try one of them next. Link to comment Share on other sites More sharing options...
heefner Posted June 16, 2003 Report Share Posted June 16, 2003 Glen, anymore info on your header?? Link to comment Share on other sites More sharing options...
Boosted_One Posted June 16, 2003 Report Share Posted June 16, 2003 Hey Mike, Glen here(4gmits) my computer is down atm and i have forgoten my password and username so i have this for now. that was also with a gen2 magna head and my prototype turbo header that i have put a bit of thought into. so the GT turboes could b good. i have heard a lot of good about them. im also told that the 25g with the 12cm2 turbine end spools much better than my turbo and has more top end. so i amay try one of them next. Heya Glen! Is that a stock Gen2 head? My ported US Marnal head is outflowing a stock Gen2 and if these sort of trends are going to be more typical with a larger turbo coupled with a free flowing head and a good header then I am really looking forward to it. ;D What's the specs on your current turbo Glen? Link to comment Share on other sites More sharing options...
Lizzord30 Posted June 16, 2003 Report Share Posted June 16, 2003 Boy Mike your not reading very compleatly He said all of his turbo spex in his first post ;D On a side note got too porting my Clear water head for the monturbo, and man the more i look at the CW head the more i like it. It DEFF flows more then the marnal (if they had the same valves) the exhaust port is almost compleatly flat, and their is only like 2 sharp edges, plus the intake has 1mm larger ports (then stock and marnal). Also i have too post a pic of my engine as it stands now , the fuel rail and FPR Polish really well on the magna take a look http://www.tristarion.com/images/carpics/1055800467.jpg Link to comment Share on other sites More sharing options...
Boosted_One Posted June 16, 2003 Report Share Posted June 16, 2003 Boy Mike your not reading very compleatly He said all of his turbo spex  in his first post ;D I was checking the board and typing in between running my printing press, I didn't see it was the same guy (Glen). Yes I didn't read it too well. Thanks again for the clarification. Link to comment Share on other sites More sharing options...
artinist Posted August 4, 2003 Report Share Posted August 4, 2003 turbo26tsi, how is your setup coming along. Link to comment Share on other sites More sharing options...
ALXunderpressure Posted August 4, 2003 Report Share Posted August 4, 2003 Whats going on with the car Neil? Have you changed anything or tuned at all? If not I have a Dyno in Opa-Locka, lets spin the wheels and finally find out whats gonna happen with it. Alex C Link to comment Share on other sites More sharing options...
BMWTech Posted August 9, 2003 Report Share Posted August 9, 2003 Bleh finally done moving, check your messages Alex....gonna this show back on the road again... Link to comment Share on other sites More sharing options...
