knightrider56 Posted June 11, 2008 Report Share Posted June 11, 2008 every time i build up boost and then let go gas i have a cloud of smoke coming out my muffler , when im at boost from 0 and up theres no smoke only when i let go of gas is when the smoke comes out......when im at 0 and under on boost gauge there will be no smoke coming out of exhaust......only when i have boost and then let go of gas is when i have a cloud of white smoke coming out of muffler Link to comment Share on other sites More sharing options...
garrett41 Posted June 11, 2008 Report Share Posted June 11, 2008 (edited) every time i build up boost and then let go gas i have a cloud of smoke coming out my muffler , when im at boost from 0 and up theres no smoke only when i let go of gas is when the smoke comes out......when im at 0 and under on boost gauge there will be no smoke coming out of exhaust......only when i have boost and then let go of gas is when i have a cloud of white smoke coming out of muffler White usually means coolant is burning... Black is usually fuel... White with blueish tint is usually oil... Maybe a head gasket leak... Edited June 11, 2008 by garrett41 Link to comment Share on other sites More sharing options...
knightrider56 Posted June 11, 2008 Author Report Share Posted June 11, 2008 White usually means coolant is burning... Black is usually fuel... White with blueish tint is usually oil... Maybe a head gasket leak... is there any way of testing to see if the head gasket is blown? Link to comment Share on other sites More sharing options...
macrophage Posted June 11, 2008 Report Share Posted June 11, 2008 (edited) I had a similar problem when i first got my squest only difference was when i idled at the light i was cool, but when the light turned green i mash the gas and white smoke would come out i later found out it was the intake and exhaust seals. At low RPMs it will leak oil in the comb chamber when you raise the rpm it burns oil then stops because the oil is moving too fast to got into the chambers, thats why i didnt get a lot of smoke when i drove. Edited June 11, 2008 by macrophage Link to comment Share on other sites More sharing options...
Caliber308 Posted June 11, 2008 Report Share Posted June 11, 2008 Does this happen when the car is cold ? CALIBER 308 Link to comment Share on other sites More sharing options...
macrophage Posted June 11, 2008 Report Share Posted June 11, 2008 is there any way of testing to see if the head gasket is blown? You could probably check the spark plugs the one with the white stuff is probably water. Link to comment Share on other sites More sharing options...
macrophage Posted June 11, 2008 Report Share Posted June 11, 2008 Does this happen when the car is cold ? CALIBER 308 you askin me? Link to comment Share on other sites More sharing options...
Caliber308 Posted June 11, 2008 Report Share Posted June 11, 2008 (edited) you askin me? No. It was directed to the poster. The easiest way to check for a blown headgasket is this: A: Air bubbles coming out of the radiator neck. B: Coolant in the oil. CALIBER 308 Edited June 11, 2008 by Caliber308 Link to comment Share on other sites More sharing options...
hyselltech Posted June 11, 2008 Report Share Posted June 11, 2008 My car is doing the same thing and i replaced all the plugs on monday and they were all white. Link to comment Share on other sites More sharing options...
Caliber308 Posted June 11, 2008 Report Share Posted June 11, 2008 (edited) My car is doing the same thing and i replaced all the plugs on monday and they were all white. They should look white, thats normal. Crusted white with deposits on them usually indicates the presents of oil or fuel additives (Ash). CALIBER 308 Edited June 11, 2008 by Caliber308 Link to comment Share on other sites More sharing options...
macrophage Posted June 11, 2008 Report Share Posted June 11, 2008 what should the color be if water is present Link to comment Share on other sites More sharing options...
Caliber308 Posted June 11, 2008 Report Share Posted June 11, 2008 what should the color be if water is present Read post no. 8. CALIBER 308 Link to comment Share on other sites More sharing options...
knightrider56 Posted June 11, 2008 Author Report Share Posted June 11, 2008 Does this happen when the car is cold ? CALIBER 308 no...but the car doesnt stay cold for long...... Link to comment Share on other sites More sharing options...
