emagdnim Posted March 27, 2008 Report Share Posted March 27, 2008 (edited) RWD Pick up tube: MD025573 - $18.50 Pick up tube gasket: MD183240 - $1.51 Pick up tube bolts (2): MS241071 - $1.80 RWD Oil Pan: MD014915 - $126.46 NT Oil pump: MD060517 - $152.71 NT Oil pump gasket: MD191432 - $2.80 New oil pan bolts (24) 6x12mm Put it in the FAQ, people will need this soon.. Edited April 8, 2008 by emagdnim Link to comment Share on other sites More sharing options...
MainstreaM Posted April 7, 2008 Report Share Posted April 7, 2008 You mean rear sump oil pan? Kane Link to comment Share on other sites More sharing options...
emagdnim Posted April 7, 2008 Author Report Share Posted April 7, 2008 If it makes you feel better, sure! Link to comment Share on other sites More sharing options...
pagemo Posted April 7, 2008 Report Share Posted April 7, 2008 If it makes you feel better, sure! OK Ill bite whats this conversion for? wide block 4G63 or some other engine config? Link to comment Share on other sites More sharing options...
emagdnim Posted April 7, 2008 Author Report Share Posted April 7, 2008 Rear sumping a G54B so you don't throw rod bearings on hard launches, therefor making you sleep better at night. Link to comment Share on other sites More sharing options...
StarquestRescue Posted April 7, 2008 Report Share Posted April 7, 2008 Are you going to be making new crossmembers for sale to go with these Montero oil pans? I will have to check this out at the u pull it. Rear sumping a G54B so you don't throw rod bearings on hard launches, therefor making you sleep better at night. I am still working on the hard launches. I thought it was Internet addiction keeping me up at night. Link to comment Share on other sites More sharing options...
emagdnim Posted April 7, 2008 Author Report Share Posted April 7, 2008 I'm not making anything, but ill modify mine if i have too... I'm glad you said something about a clearance issue, Has this been done before and not have clearance? Link to comment Share on other sites More sharing options...
StarquestRescue Posted April 7, 2008 Report Share Posted April 7, 2008 I'm glad you said something about a clearance issue, Has this been done before and not have clearance? I don't know, I am not sure of the accuresee of these pictures. The drag links is back there also. http://i237.photobucket.com/albums/ff45/StarquestRescue/Monterooilpan002.jpg http://i237.photobucket.com/albums/ff45/StarquestRescue/Monterooilpan001-1.jpg Link to comment Share on other sites More sharing options...
emagdnim Posted April 8, 2008 Author Report Share Posted April 8, 2008 Isn't that sexy? mmmm Link to comment Share on other sites More sharing options...
PDX87Starion Posted April 8, 2008 Report Share Posted April 8, 2008 The confusing part is "RWD" oil pan conversion. My SQ came RWD from the factory. "Non-turbo" or "truck" oil pan conversion/kit, makes more sense. Link to comment Share on other sites More sharing options...
Technology Posted April 8, 2008 Report Share Posted April 8, 2008 Yeah, the back of the oil pan is above the crossmember by about an inch. Link to comment Share on other sites More sharing options...
heefner Posted April 9, 2008 Report Share Posted April 9, 2008 Unless you seriously modify your cross member this will no worky. Link to comment Share on other sites More sharing options...
spoolinturbo Posted April 10, 2008 Report Share Posted April 10, 2008 I dont see this working, but if someone makes it work then effin awesome. Link to comment Share on other sites More sharing options...
emagdnim Posted April 10, 2008 Author Report Share Posted April 10, 2008 I dont see this working, but if someone makes it work then effin awesome. Thats what I'm here for. Link to comment Share on other sites More sharing options...
Maxzillian Posted April 10, 2008 Report Share Posted April 10, 2008 Good luck with it! I'll cheat with my accumulator until you figure it out and post the skinny. Link to comment Share on other sites More sharing options...
pagemo Posted April 11, 2008 Report Share Posted April 11, 2008 Good luck with it! I'll cheat with my accumulator until you figure it out and post the skinny. My plan as well ^ 1.5 Qt Accusump accumulator better protection and much easier in regards to install. if you want better protection from the pan just work on a trap door and wing the sides for more capacity. Link to comment Share on other sites More sharing options...
Alcyone Posted April 15, 2008 Report Share Posted April 15, 2008 accumulator? like baffling? and no I don't mean baffling as in to be Baflled, addled, agape, aghast, agog, appalled, astonished, astounded, awe-struck, awed, baffled, befuddled, bowled over, confused, dazed, dazzled, disconcerted, dizzy, dumbfounded, dumbstruck, flabbergasted, flipped out, floored, flustered, giddy, lost, misled, muddled, mystified, perplexed, puzzled, rattled, reeling, shocked, shook up, speechless, staggered, startled, struck speechless, stumped, stunned, stupefied, surprised, taken aback, thrown, thunderstruck, uncertain, unglued. but baffles. ^^^^^^ Like that. :chair: Link to comment Share on other sites More sharing options...
Maxzillian Posted April 16, 2008 Report Share Posted April 16, 2008 Nope, like a 2 quart Accusump oil accumulator. Basically a tank that can store pressurized oil. http://www.maxzillian.com/starion/install4-2.jpg http://www.maxzillian.com/starion/accumulator4.jpg http://www.maxzillian.com/starion/accumulator5.jpg http://www.maxzillian.com/starion/accumulator7.jpg Sorry to hijack a bit, Sam. Link to comment Share on other sites More sharing options...
emagdnim Posted April 16, 2008 Author Report Share Posted April 16, 2008 I post these threads to get knowledge outta you people... seems to be working! I like all the different ideas and set-ups... I wish more were posted. Link to comment Share on other sites More sharing options...
PDX87Starion Posted April 17, 2008 Report Share Posted April 17, 2008 Accusumps are very popular in the road racing scene for those who dont have a drysump system. It is pressurised by the stock oil system and if the pressure goes below a certain PSI it releases its oil keeping the engine lubricated. When the oil pressure comes back the accusump refills and holds the oil and pressure until the next time. Can also be used as a pre-oiler for start up too. Great product for people who are going to drive hard. Launches, donuts, and hard cornering where oil can slosh away from the pick-up. Kudos Maxzillion for installing one. :thumbsup: Link to comment Share on other sites More sharing options...
