KrazedZ Posted March 4, 2008 Report Share Posted March 4, 2008 OK, whats the trick to taking apart the dash and guages? i don't see any screws holding it down, does it just snap into place? any info or pics on how it comes apart would be great.ThanksTony Link to comment Share on other sites More sharing options...
emagdnim Posted March 4, 2008 Report Share Posted March 4, 2008 just use a BFH. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted March 4, 2008 Report Share Posted March 4, 2008 I was going to say, use an air chisel.. There might be some pics/info about it at www.starquest.i-x.net in the SOS section.. Back when I pulled my dash, i just kinda had to wing it.. Link to comment Share on other sites More sharing options...
Alcyone Posted March 4, 2008 Report Share Posted March 4, 2008 the over the gauge hood has 2-3 screws directly under the hood (into the plastic. and there is a screw under each control switch on the sides. the dash..... never tried it. Link to comment Share on other sites More sharing options...
GCNTSi Posted March 4, 2008 Report Share Posted March 4, 2008 First off this Question should be posted in the Virtual Mechanic section. Second, do a search, make sure and click on the find all terms button so you don't get thousands of results. Third, be very patient or you will break something(s). Finally, check the pic I have at the bottom of this post: http://www.starquestclub.com/forums/viewtopic.php?t=69991 -GCNTSi. Link to comment Share on other sites More sharing options...
Alcyone Posted March 4, 2008 Report Share Posted March 4, 2008 First off this Question should be posted in the Virtual Mechanic section. Second, do a search, make sure and click on the find all terms button so you don't get thousands of results. Third, be very patient or you will break something(s). Finally, check the pic I have at the bottom of this post: http://www.starquestclub.com/forums/viewtopic.php?t=69991 -GCNTSi. searching sound like a good option......... until you search and get 7 unrelated pages. Link to comment Share on other sites More sharing options...
GCNTSi Posted March 5, 2008 Report Share Posted March 5, 2008 searching sound like a good option......... until you search and get 7 unrelated pages. Well then you need to search for a lesson on how to perform a proper, and accurate search. :wink: -GCNTSi. Link to comment Share on other sites More sharing options...
G54B3sgte Posted June 6, 2008 Report Share Posted June 6, 2008 use a really big hammer and a flat head screw driver works everytime :fighting0061: Link to comment Share on other sites More sharing options...
Minagera Posted June 6, 2008 Report Share Posted June 6, 2008 One word, carefully. Link to comment Share on other sites More sharing options...
Komeuppance Posted June 6, 2008 Report Share Posted June 6, 2008 Anyway... www.starquestgarage.com Look at a factory manual there (doesn't matter what year, they're all basically the same). It's not that hard, just takes time. -Robert Link to comment Share on other sites More sharing options...
Technology Posted June 6, 2008 Report Share Posted June 6, 2008 the over the gauge hood has 2-3 screws directly under the hood (into the plastic. and there is a screw under each control switch on the sides. the dash..... never tried it. there are 4 screws for the gauge hood. Then two more and two nuts under that. Take out the center console, the glove box, the panel under the steering wheel, you'll start seeing bigger bolts, just keep taking things apart. Probably a good idea to label each bolt or set of identical bolts and screws. Link to comment Share on other sites More sharing options...
PsyshoRacing Posted June 10, 2008 Report Share Posted June 10, 2008 I found a haynes manual and the pic was in there as well as instructions. If you need me to scan the pages, let me know. Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted June 10, 2008 Report Share Posted June 10, 2008 Hi, Yes scan and post pictures / instructions. Link to comment Share on other sites More sharing options...
