G54B3sgte
Everything posted by G54B3sgte
omg guys calm down lol i am taking note of all the things your suggesting i think matt will love that he has decided to help out the sq community
thanks for the faith extreme and i understand i wasnt asking people to commit to a purchase i was asking for interest for possibly buying the product and this isnt one of those deals the guy is having the mold made for himself i will not be selling them via to yall you will deal with him directly for your parts i am just introducing him to these cars he isnt charging me to make the molds because he is the one that will be making the money he will be the one to setup the gp thread when he has them ready this guy is a straight shooter he doesnt have any other job then making fg parts he used to make car kits for people his handy work is incredibly the craftsmanship is amazing and extreme we are working on a wide mouth design without sacrificing the foglight assemblies so all it will be is to modd the support bumper and bolt on like i said i am going to get a sample of the first airdam once it is out of the mold and gonna let the dfw guys look touch smell if they want lol but i was also trying to see what other items you guys might want that no one has taken the time to actualy have reproduced like our center consoles and such and btw he makes his molds so its not going to be a situation where he is waiting on another company to make it for him this guy used to make countache kits for people to have a replica of and the all famous ac cobras but he is trying to build up his own business making parts for cars who either have no aftermarket support or a item was stopped from production like alot of the hks stuff has so dont throw in the towel yet but the 225 is shipped to your door ready for primer and paint and as such as we progress with other items
Ok i met up with a guy yesterday evening who does fiberglass body parts for a living and is trying to expand his business further then doing 300GT/Stealth parts I need to see how many of you guys would like o purchase airdams for 225 shipped I will have the first one out of the mold from him in about a month and a half but it wont stop there if there is enough s upport from you guys I have heard suggested items as such: Fiberglass Fenders Reproduction Airdams Reproduction 83 hoods for cheaper then mookeeh which is a possibility and i mean alot cheaper Reproduction Center consoles and and shifter pieces Custom front and rear bumpers maybe some hatch pieces and such but for the first run it will be airdams I need atleast 40 people to show interest in possibly ordering these and when the first one comes out of the mold I will be showing the DFW guys so they get to see it first hand and can give you their thoughts on the quality of it now I have seen his work for the 3000gt stuff and its first rate and this isnt some guy doing it afterwork this is all he does for a living so once the molds are made production will be quick so sign up for the interest of a airdam so we can get this ball rolling and get us the parts we need and want for cheaper and with qaulity
pics have sent to the guys who have requested
i will be away from the computer most of today so its either best to call me or send me an email because all my emails go to my phone the email adress is stealthedgt4@aim.com
email sent with pics
size STD. as it was posted made by Perfect Circle Cast pistons these are flat tops as i stated above not stock turbo pistons
MegaSquirt-II Engine Management System w/PCB3.0
All 'Basic Components' PWM Flyback Damping Circuit components Hall Sensor/Coil(-) and VR Sensor Ignition Trigger Components IGBT High Current Ignition Driver Components Current Limiting Circuit Components MegaSquirt II includes all of the features and benefits of the original... Onboard MAP sensor for NA or boosted engines up to 21psi! Speed density or Alpha-N. Use any injector - High or Low impedance. Compatible with output from narrowband and wideband O2 sensors. Log data on your laptop for later analysis. Tuning software is free for download and regularly updated with new features. Open Source design - all code and hardware information is available online. Includes proper female DB37 connector and shell for building your wiring harness. Additional Features new to the MegaSquirt-II 24 MHz HCS12 processor, Fuel control to 1 µsec (100 times more resolution than MegaSquirt-I), Ignition control (full spark timing advance control, dwell control, etc) for one coil/distributor (7 pin HEI for example) and Ford's EDIS systems, On-board stepper motor driver for IAC stepper control (we install the jumpers for this by default) Ford PWM idle valve firmware support, Built-in rev limiter, either 'fuel cut' or 'spark retard', All tables are now 12×12 in size, WBO2 AFR target table (in AFR units), Independent dual-tables for VE and AFR target, EGO feedback in wide-band mode is proportional to the difference between the measured AFR and the target AFR, the bigger the difference, the bigger the feedback step, Spark advance table can have different rpm and kpa bins than VE and AFR tables, 115,200 baud serial interface with MegaTune2.25+, CANbus networking Barometric correction amount and direction configurable in software, and provisions for: barometric correction based on initial MAP reading, independent 2nd barometric MAP sensor for continuous real-time baro correction, or no baro correction. TPS values for open loop and flood clear mode are user configurable, MAP based open loop can be set as well as TPS, Both TPS and MAP based accel enrichment is built into the code, you can configure the ratio of each, Blended Alpha-N and speed density is an option, 2 spare I/O lines for custom controls. (This is in addition to 4 lines for Idle stepper control if you don't need this, or the Fast idle solenoid then becomes a spare if you do use a stepper motor.)
the rod bearings are clevite the main bearings are federal mogul
I have a megasquirt version 2 forsale $375 plus shipping flatop pistons std. never installed $60 plus shipping 2 85lb injectors with modified fuel injector rail and bolts $120 plus shipping Timing Chain kit (balance shaft elimination kit without sleave) $65 plus shipping brand new rings never installed std size $50 plus shipping brand new main bearings std size $45 plus shipping brand new rod bearings std size $45 plus shipping magna head without valetrain SOLD!! new oem valves $60 plus shipping schnieder valve springs $65 plus shipping valve seats and keepers and valve guides $70 plus shipping 86 ecu $100 plus shipping 86 airflow meter $50 plus shipping 1st gen dsm airflow meter $50 plus shipping passenger side pacer tail light without harness $50 plus shipping 87 Cluster $25 plus shipping maroon cluster cover $25 plus shipping thats all i can think of for right now if i find more parts i will list them as i find them i do paypal for payments and i do not over charge on shipping ( i hate people who do that) contact me via 817-703-7532 or aim stealthedgt4 pictures of items will be provided for pm requests also will consider trades for 4g6x parts as that is what i am going with i need a head intake and exhaust manifold and turbo a wiring harness and a ecu
oh yea forgot contact info 1-817-703-7532 stealthedgt4@aim.com messengers; aim (stealthedgt4) yahoo (technofreak2049)
I have a modded magna mpi manifold i have the fuel rail and thermostat housing and the gasket that bolts the bottom section to the head I am asking 500 plus shipping payments will be via paypal http://i306.photobucket.com/albums/nn264/stealthedgt4/S6300970.jpg http://i306.photobucket.com/albums/nn264/stealthedgt4/S6300971.jpg http://i306.photobucket.com/albums/nn264/stealthedgt4/S6300972.jpg http://i306.photobucket.com/albums/nn264/stealthedgt4/S6300973.jpg http://i306.photobucket.com/albums/nn264/stealthedgt4/S6300974.jpg
After 6 years. I've located my first car. Very sentimental..
G54B3sgte replied to Kreal's topic in Just plain ol' B.S.
wow man thats cool i just had something like that happen to me this week as well a buddy of mine bought my original car little to his knowledge anyways my first car was a 1986 plymouth conquest tsi well back in 2003 i sold the car to a underserving kid well he left with the car and never came back for the tittle as i told him i had to find it but he was impatient so a month went by after the sell he gets in contact with me and says the car burned down could i sell him another one well ever since then i thought it was destroyed well turns out the car only had a small engine fire nothing major well my 2 buddies gary and john found it 30 miles southwest from me in a gentlemans backyard and bought it with the intentions of making a track car out of it since there was no tittle well they took the car to johns house on sunday of last week well the monday john had me come out to his house to deliver some parts and it was late that night so when i got there john was off at his brothers house so i was waiting and i was like i will just go check this new car out and i walk over to it and i start looking at it and i started to realize i knew this car and i ran around back and i saw what was left of some vinyl letters on the spoiler that said DINGO and i about had a heart attack and i called john told him what i had figured out and we traded project cars lol and i got my first car back and the cool thing is it runs still and its still in my name lol -
ok lets look at it this way the 2jz is already in which means swapping for a 2jzgte would be easy since the motor mouts and such are done but one thing he didnt specify on is has the driveshaft already been modded and installed?
welcome to texas sorry it had to be el paso dont breath too deeply there
ratcheting wrenches are the best i got a full set of metics and sae god do i love them and we are also forgetting northern tool the one step above harbor freight sometimes they have a good deal and the only ones who car SK tools that i have found in Tx atleast
make sure you get it clean and i mean super clean get all oil residue off then have it powder coated it will last so much longer
omg i cant believe you guys all waiting to get nices boxes just do what i did and i am going to show you a website you guys are going to love http://www.thetoolwarehouse.net/ they sell everything there they cary all the same tools as craftsman snap on matco mac etc they deal with the companies that the others deal with but you can buy it directly and its so much cheaper and the chest selection and prices are awesome
