edjee Posted November 17, 2004 Report Share Posted November 17, 2004 We can do this test with our tps in the car right? Does the battery need to be connected? Sorry, I just want to try this now ;D Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 17, 2004 Report Share Posted November 17, 2004 This is resistance.. So, it doesn't matter if the battery is hooked up or not.. I've done it in the car, and with a spare TPS on my bench.. You just wanna see if it operates smoothly as you slowly open the throttle... ;D Link to comment Share on other sites More sharing options...
Professor Quest Posted November 17, 2004 Author Report Share Posted November 17, 2004 "Can you do it in the car?" you can do it in a car...........you can do it in a bar.......BUT JUST DO IT! ;D Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 17, 2004 Report Share Posted November 17, 2004 http://2.6liter.com/userfiles/StarPauser/TPS20Res.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 17, 2004 Author Report Share Posted November 17, 2004 OK, this is the OTHER "INSPECTION". Use the TOP pin and the LEFT LOWER pin. The "STANDARD VALUE" is 3.5 to 6.5 KILO OHMS. Why am I not surprised that the BAD TPS also failed this test. : Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 17, 2004 Report Share Posted November 17, 2004 http://2.6liter.com/userfiles/StarPauser/P1010003TPS.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 17, 2004 Author Report Share Posted November 17, 2004 And the WINNER is................THIS TPS! ;D Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted November 17, 2004 Report Share Posted November 17, 2004 http://2.6liter.com/userfiles/StarPauser/TPS%20wire%20har.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted November 17, 2004 Author Report Share Posted November 17, 2004 Now then............Once you have a GOOD TPS.......you can ADJUST IT using  VOLTS. Open manual to page 14-32, 14-33, 14-34  Make the little harness adapter above. Start the car, let it warm up. Adjust the VOLTAGE at idle to 0.48-0.52 volts. When you open the throttle all the way you should see AROUND 4.5 -5.5 VOLTS. You might make 4 of those wires......you'll need them for the ISC adjustment. Link to comment Share on other sites More sharing options...
Professor Quest Posted December 17, 2004 Author Report Share Posted December 17, 2004 Moving to "Starquest.i-x. net" See "Professor's Manual for Dummies" Link to comment Share on other sites More sharing options...
JAinsworth Posted December 17, 2004 Report Share Posted December 17, 2004 Wayne/John, Can you get a close up pic of the ends of the harness adapter? Jimmy Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted December 17, 2004 Report Share Posted December 17, 2004 They look to be the same size as I used for the fuel pump test port's jumper wire.. Haha, that didn't help.. What I've always wanted to know, is how do you take off some of the wire's sheathing like that? I need to know before my A/F goes in, and I can't figure out how to take off just a middle section... Hmmn, maybe I should just play with some wire and figure it out.. ;D Link to comment Share on other sites More sharing options...
Shelby Posted December 17, 2004 Report Share Posted December 17, 2004 Jimmy i think they are commonly refer'd to as a 1/2 spade Link to comment Share on other sites More sharing options...
Professor Quest Posted December 17, 2004 Author Report Share Posted December 17, 2004 Look closer..............that is not a "midway" strip.  Cut  the insulation about 2" from the END OF THE WIRE...........pull the insulation off about 1/2"..........THEN strip just the end off!  CLEVER! ;D Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted December 18, 2004 Report Share Posted December 18, 2004 Sneaky... ;D But in my case, that's not going to work... For a A/F gauge, I don't wanna have to disconnect a wire from the ECU to get the sheathing off... Maybe I could burn it a little bit..Just to the point where it gets soft, then I can pull it off without damaging the ECU connection.. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted December 18, 2004 Report Share Posted December 18, 2004 http://2.6liter.com/userfiles/StarPauser/close%20up%20adapter.JPG Link to comment Share on other sites More sharing options...
Professor Quest Posted December 18, 2004 Author Report Share Posted December 18, 2004 Ahhh, John. What you want is the OTHER trick. SINGLE EDGE RAZOR BLADE.....two VERY CAREFUL CUTS.......don't cut into the copper.......then one cut the lenght of the wire connecting between the first two cuts........peel the peice off. Now take your time and when doing fine electronics work......like cutting the ECU harness, place the wire on a hard surface......like a CD case. And wearing VISION ADDS HELPS. Now the manual tells you how to release the PIN from the connector. If you do that, you can then use heat shrink AFTER you SODER the A/F lead in. You don't HAVE to be an electronics geek......just be patient and use a NEW BLADE. You can use Shelby's trick with electrical tape and PVC cement. Just electrical tape will work fine........but WASH YOUR HANDS and WIPE the FLUX OFF with eletrical cleaner. Better still............just cut the damn wire and soder the three back together with the heat shrink installed. ;D As usual.........unhook the BATTERY. : Link to comment Share on other sites More sharing options...
Professor Quest Posted December 18, 2004 Author Report Share Posted December 18, 2004 Sorry, Jimmy I just noticed your request. The females are pretty easy to find. I just D-Y-K-E the males from a standard male connector. I keep forgetting to order more of the males. Â ;D You can tie in alligators as well to make life easier. Link to comment Share on other sites More sharing options...
Professor Quest Posted June 10, 2005 Author Report Share Posted June 10, 2005 :wink: Link to comment Share on other sites More sharing options...
