TopDawg_43 Posted January 30, 2003 Report Share Posted January 30, 2003 What gph rating fuel pump does a MPI require? Link to comment Share on other sites More sharing options...
Joel Posted January 30, 2003 Report Share Posted January 30, 2003 MPI will "run" on the stock pump... What are your power goals? For a street car a 255lph with pressures up to 80psi would do the trick (and will do the trick all the way into the 12s). Joel Link to comment Share on other sites More sharing options...
chiplee Posted January 30, 2003 Report Share Posted January 30, 2003 my pump is 125psi, not sure of GPH but I think it's sold as a bosch 350hp fuel pump. So far it's been all I need and more, providing enough fuel through 720cc injectors, and stock fuel lines to get pig rich at 6500rpm and 18lbs of boost. No fuel pressure drop of any sort. Link to comment Share on other sites More sharing options...
Boosted_One Posted January 30, 2003 Report Share Posted January 30, 2003 Walbro 225lph high pressure extrernal. From fairly wild to mild. Best pump out there next to a full race blown pump that's the size of your microwave and sounds like a sump pump.. I have a 125psi pump like Chip. It was bought from CNM and James told me it's good for 300hp. That's all the info I have about the 125psi pump I had. Alamo Motorsports also sold this 125psi pump, unfortunately they discontinued it. I have mixed feelings about that 125psi pump. :-/ Link to comment Share on other sites More sharing options...
TopDawg_43 Posted January 31, 2003 Author Report Share Posted January 31, 2003 I plan on haveing around 300hp when I'm done. And it's going to be a street monster, and race every so often. I was looking at the MSD pump, it's rated at 43gph @ 40psi 162lph. Will that be enought fuel? I have V8-Slayers (Frank)'s intake, it has 550 injectors. I'm going to run a 16G, 18G, or a 20G on it. Thanks for the advise fellas. Link to comment Share on other sites More sharing options...
TopDawg_43 Posted January 31, 2003 Author Report Share Posted January 31, 2003 Does anybody know the part number on there fuel pump? Link to comment Share on other sites More sharing options...
Shawn_Silva Posted January 31, 2003 Report Share Posted January 31, 2003 Go Aeromotive. The fact is, the more you have, the more you want. I went this route, but yes, you must redo all your fuel system in order to support the increased line size and flow. http://216.242.145.16/products/product.phtml?p=3 http://216.242.145.16/products/product.phtml?p=11 They are not a bolt-in, but they will support my 550+ rwh goals...Can't wait to run the -10an lines from the modded tank to the rail. lol, yeah, thats 5/8" peoples!! Take care Shawn Link to comment Share on other sites More sharing options...
Eldos1 Posted March 7, 2003 Report Share Posted March 7, 2003 Walbro pump http://www.autoperformanceengineering.com Click on external pump link. There is a $10.00 kit for Starion. Know DSM guys who get them here and are happy with the vender. later, Steve Gee Link to comment Share on other sites More sharing options...
blew-by-u Posted March 7, 2003 Report Share Posted March 7, 2003 Here is an internal that should work in the stock location. Anyone seen/heard about this one? Part Number High Flow High Pressure Fuel Pump Part Number= GSL392 Link to comment Share on other sites More sharing options...
Boosted_One Posted March 7, 2003 Report Share Posted March 7, 2003 Here is an internal that should work in the stock location. Anyone seen/heard about this one? Part Number High Flow High Pressure Fuel Pump Part Number= Â GSL392 That's an external Walbro pump Link to comment Share on other sites More sharing options...
TopDawg_43 Posted March 7, 2003 Author Report Share Posted March 7, 2003 FYI- You can't use an internal fuel pump in an external location. Â An internal pump has a sleeve that soak's up some of the gas to help the pump stay cool. Â If the pump is mounted exterally, it will overheat and burn up. Link to comment Share on other sites More sharing options...
blew-by-u Posted March 7, 2003 Report Share Posted March 7, 2003 DOH!! : What part number should I be looking at? Have you seen the Walbro post in the e-bay section? Is that the right one? Link to comment Share on other sites More sharing options...
Eldos1 Posted March 8, 2003 Report Share Posted March 8, 2003 GSL = External GSS = In Tank GSL 393 is the 255 pump for external. StarQuest pump is mounted external on top of the tank. See the charts for internal tank style for flow rates. Notice the flow rate at 13.5 vs. 12 Volts, so you want to make shure you use a relay to suply voltage. Got my GSL 393 on the way with the $10.00 fitting kit. Later, Steve Gee Link to comment Share on other sites More sharing options...
gestun66 Posted March 8, 2003 Report Share Posted March 8, 2003 I just received my GSL 392 which is the Hi-Pressure 255 l/hr external pump from http://www.autoperformanceengineering.com with the $10.00 installation kit. Really good service, I had everything in three days! Link to comment Share on other sites More sharing options...
Boosted_One Posted March 8, 2003 Report Share Posted March 8, 2003 GSL = External GSS = In Tank GSL 393 is the 255 pump for external. StarQuest pump is mounted external on top of the tank. See the charts for internal tank style for flow rates. Notice the flow rate at 13.5 vs. 12 Volts, so you want to make shure you use a relay to suply voltage. Got my GSL 393 on the way with the $10.00 fitting kit. Later, Steve Gee The GSL 393 is a stock rated replacement pump. It isn't the 255lph pump. The GSL392 is the 255LPH high pressure external pump. Link to comment Share on other sites More sharing options...
NeeD2DrifT Posted June 6, 2004 Report Share Posted June 6, 2004 GSL394, upgrade for GSL393 with amazing shut-off pressure of 130 psi how about this 1 ? Link to comment Share on other sites More sharing options...
bamo135 Posted August 9, 2004 Report Share Posted August 9, 2004 ok maybe i,m slow but let me ask a few questions? A while back someone advised me to buy the GSL 392 pump. I was under the immpression that this was an add on pump used with the stock pump. Or is is it a replacment for what is on the car now? someone was saying something about the pump being internal? the one i can see on top of the tank looks pretty external or is there another in the tank? Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted August 9, 2004 Report Share Posted August 9, 2004 It's a replacement.. Here's one mounted with a different pre-filter(in place of stock cone filter).. http://2.6liter.com/userfiles/JustPaus/Walbro%20Fuel%20Pump.jpg Link to comment Share on other sites More sharing options...
bamo135 Posted August 9, 2004 Report Share Posted August 9, 2004 oh okay cool that makesthings easier then. so they took off the filter in the tank and are using that that seems like a good idea. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted August 9, 2004 Report Share Posted August 9, 2004 Not quite.. That filter you see takes place of the stock 'cone' shaped filter, that fits into the inlet side of the stock fuel pump.. It doesn't fit the Walbro, so this was used.. The intank ''sock'' looking filter, is still there... Link to comment Share on other sites More sharing options...
bamo135 Posted August 9, 2004 Report Share Posted August 9, 2004 oh i got you. is it acceptable to just clean the sock filter really well. I would like to clean out my fuel system and tank with keroseane. Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted August 9, 2004 Report Share Posted August 9, 2004 Yeah, you can clean the sock filter.. Just be careful, it might be brittle and fall apart.. If you're going to have the tank out, inspect the hoses while it's out... Link to comment Share on other sites More sharing options...
bamo135 Posted August 11, 2004 Report Share Posted August 11, 2004 what hoses the ones on the filler neck that crumbled in my hand lol. where do i get new ones or what have you guys used as substitue hoses? Link to comment Share on other sites More sharing options...
