Conquest351 Posted May 10, 2002 Report Share Posted May 10, 2002 I just called and priced those kits. You ready for this? $1000 for the kit! I dunno about you guys but I am going to talk to my friend about using his dad's fiberglass shop. LOL That's friggin crazy prices. Guess those Porsche guys ARE all rich, just as I suspected. Link to comment Share on other sites More sharing options...
Gary Posted May 11, 2002 Report Share Posted May 11, 2002 What C351 you don't find those prices reasonable! LOL ;D Link to comment Share on other sites More sharing options...
Conquest351 Posted May 12, 2002 Report Share Posted May 12, 2002 Sure dude, just hook a brotha up with a $G and I'll be sure to get them. Link to comment Share on other sites More sharing options...
Guest Paul87Quest Posted May 13, 2002 Report Share Posted May 13, 2002 $1000! Those guys have been using the crack pipe too long! Well...it at least was a pic where you could see what it would look like. Link to comment Share on other sites More sharing options...
MoMagnum Posted May 13, 2002 Author Report Share Posted May 13, 2002 We are on the right track now guys- the question now is: CAN ANYONE MAKE THEM? I don't(can't) want to spend $1000, and then try to "make" them fit. :-/ MoMagnum, 89 ESI 86 TSI-parting out Link to comment Share on other sites More sharing options...
Fuze Posted May 16, 2002 Report Share Posted May 16, 2002 I fabricated a set and they are on my car right now, I've had em for about 4 months. They look very similar to the RE Amemeyia kits for the FD3S RX-7. Very agressive looking and totally transforms the front end. My stock pop-ups developed problems that I just didn't have the patience to resolve, I completely eliminated the problem and made new lights/wiring. Basically, it's an all alluminum "box" made of a base, 2 sides that match the contour of the headlight lids, a back piece, and a lexan lid which is masked and painted in the areas that the light does not show through. The lid is connected via 4 tiny allen bolts, which screw into 4 small alluminum tabs which are drilled and tapped.. The sides are bolted to the base and back, which are also both drilled and tapped so it all fits togeather nicely. They look HOT, I don't have a digicam or any pics of them right now, but I'll try to get them. I'm still playing with ideas for different lights, but right now I've got (4) 130watt projectors in there ... Lemme tell you it was quite an ordeal testing, fitting, etc. I had access to a machine shop and a lot of freedom to do whatever I wanted at the time. I can disassemble one and draw up a schematic if somebody wants to try and duplicate them. When I get the pictures, I'll combine them with the schematic and put a page up if people are interested. Later Link to comment Share on other sites More sharing options...
Jeremy_C Posted May 16, 2002 Report Share Posted May 16, 2002 Oh yes, a diagram and pictures are now REQUIRED if you want to stay on this board Fuze. If not, I'll have to hunt you down and run you off the road in true road race fasion! ;D Link to comment Share on other sites More sharing options...
MoMagnum Posted May 16, 2002 Author Report Share Posted May 16, 2002 Oh yes, a diagram and pictures are now REQUIRED if you want to stay on this board Fuze. A M E N ! ! ! ! MoMagnum 89 ESI 86 TSI- parting out Link to comment Share on other sites More sharing options...
JamesR Posted May 17, 2002 Report Share Posted May 17, 2002 Hey Fuze, Did you form the lexan yourself or have a shop do it? What thickness of lexan was used? I am plan using a heat gun to bend the lexan. Link to comment Share on other sites More sharing options...
Fuze Posted May 17, 2002 Report Share Posted May 17, 2002 The machine shop I was in is inside a "compound" where my father works, at a Gvot. contracted pharmaceutical firm. He works in the robotics dept, so the machine shop for that dept has stocks of lexan, delrin, alluminum, titanium, etc.. I cut the lexan lids from a sheet, using the old metal covers as templates, but it was tricky and took some finessing. They are somewhere between 1/8 and 1/4 " thick. I built the boxes, drilled the lids and bolted them at the top and bottom, then used a heat gun to relax the lexan into the bent angle. Being very careful, because if I used too much heat the lexan would distort and throw the light all over the place, but the bend is pretty much above the light's beam projection area. I plan on doing the fog lights also, putting some High intensity lights in there and making a new module to fit in there. Really updates the car. For those that like the pop-ups, I suggest the H4 "diamondback" conversion, available at Summit racing. These are replacement lights/lenses which accept the popular H4 bulb, which HID kits are also available in, and they ahve a chrome angular back with a diffuser in front of the bulbs, which the other styles don't have. Much nicer than the Hella style. Link to comment Share on other sites More sharing options...
Conquest351 Posted May 22, 2002 Report Share Posted May 22, 2002 So what's the scoop on these things? If you can make a few I'm game to buy a set from ya. You have 2 projectors per side right? That's what I want to do. Lemme know what's up on these things. Link to comment Share on other sites More sharing options...
MoMagnum Posted May 22, 2002 Author Report Share Posted May 22, 2002 Yeah Fuze, I'm still waiting to see these things! Link to comment Share on other sites More sharing options...
Quest4Power Posted May 22, 2002 Report Share Posted May 22, 2002 here is one of the miata kits someone mentioned earlier http://www.midtennmiata.com/images/hellalgtasm-lr.jpg these lights are hella's, one prjector and one regular lens driving on each side. the lights would be a good candidate to design around, they are the same as used in the Saleen S7 and plenty of other exotic cars. i will be attempting to design my own system, if all goes well, i may be able yo produce them in small quantities. we'll see... Link to comment Share on other sites More sharing options...
Blue1989TSi Posted May 26, 2002 Report Share Posted May 26, 2002 Let's see 'em on the car... Link to comment Share on other sites More sharing options...
Ray_R Posted May 26, 2002 Report Share Posted May 26, 2002 if those lights are small enough you could just cut some holes right in the pop up cover and mount them. Link to comment Share on other sites More sharing options...
rjf Posted May 27, 2002 Report Share Posted May 27, 2002 Nostalgia aside, my vote would be to get rid of the pop-ups because they weigh 9 lbs each, another thing to go wrong (how often have you seen a SQ with one light up and one down!), and they are a aerodynamic disaster. I have been looking for a suitable replacement unit to base the mod on. As the car has angular lines, I do not want a round light. The best candidates I have found are the last year Dodge Daytona (93 I think) and/or some 80's Civics that had a rectangular flat lens with about the same angle as the front fascia panel (between the headlights) on a SQ. Does anyone know of a headlight unit that better matches the angle of the front fascia on our cars? Link to comment Share on other sites More sharing options...
Conquest351 Posted May 27, 2002 Report Share Posted May 27, 2002 I was thinking about putting the clear lens under the pop up headlights from a 90 Eclipse and putting a pair of projector lenses behind them and just using the pop up lights as air intakes for the turbo's. That would be cool but I think the headlight conversion that just takes the place of the pop ups would be easier. Link to comment Share on other sites More sharing options...
Quest4Power Posted May 29, 2002 Report Share Posted May 29, 2002 myself and a buddy of mine are in the process of making a fixed headlight conversion on our quests. we will most likely use a rectangular light, because the car is somewhat boxy in shape. will post pics upon completion. Link to comment Share on other sites More sharing options...
Juggary Posted May 31, 2002 Report Share Posted May 31, 2002 myself and a buddy of mine are in the process of making a fixed headlight conversion on our quests. Â we will most likely use a rectangular light, because the car is somewhat boxy in shape. Â will post pics upon completion. Please let us know the out come, if it looks good than I want to buy 1 set. Thanks, Gerry Link to comment Share on other sites More sharing options...
Dark_Syde_Racing Posted June 5, 2002 Report Share Posted June 5, 2002 http://www.fototime.com/%7B2FC0D6F3-72F4-49A0-87E9-D284962A6EFF%7D/picture.JPG DROOOOOL!!!! OMG THAT IS BEAUTIFUL (the rear fenders are at least) Link to comment Share on other sites More sharing options...
Dark_Syde_Racing Posted June 5, 2002 Report Share Posted June 5, 2002 that pic isnt comming up so here is the URL http://www.fototime.com/{2FC0D6F3-72F4-49A...FF}/picture.JPG the quest has 3000GT head lights and mr2 rear fenders and supra tails (along with that 83 hood) and fiji blue! and its for sale on trader online.com Link to comment Share on other sites More sharing options...
Dark_Syde_Racing Posted June 5, 2002 Report Share Posted June 5, 2002 here is that pic again (see if it works this time) http://www.fototime.com/%7B2FC0D6F3-72F4-49A0-87E9-D284962A6EFF%7D/picture.JPG here is the link [link]http://www.fototime.com/{2FC0D6F3-72F4-49A0-87E9-D284962A6EFF}/picture.JPG[/link] Link to comment Share on other sites More sharing options...
D_Venable Posted June 6, 2002 Report Share Posted June 6, 2002 What's the diameter of the lights included in the conversion for the Miata? Link to comment Share on other sites More sharing options...
Quest4Power Posted June 7, 2002 Report Share Posted June 7, 2002 the lights are 90mm in diameter. one regular and one projector per side. the lights alone go for about $60 apiece. but these are great lights. i have them on my miata and the light output is great. Link to comment Share on other sites More sharing options...
Dark_Syde_Racing Posted June 8, 2002 Report Share Posted June 8, 2002 OK I FINALLY HOSTED THE PIC MYSELF TO SHOW EVERYONE SOME SICK IDEAS FOR THEIR QUEST..me i am doing the rear feder design myself (within the next 3 weeks) and i am doing the supra tail lights also...PREPAIR TO DROOOOL! http://images.cardomain.com/installs/205000-205999/205543_178_full.jpg Link to comment Share on other sites More sharing options...
