importwarrior Posted October 21, 2015 Report Share Posted October 21, 2015 i need to know what the S and L terminals - wires do in the alternator???i can't seem to find info and would like a refresher please. Thank you for the help. L ? S? Thanks. http://i35.photobucket.com/albums/d182/Professor-Quest123/Batt%20Alt/AL-34.jpg Link to comment Share on other sites More sharing options...
ucw458 Posted October 21, 2015 Report Share Posted October 21, 2015 Signal and lamp. Lamp is for the alt light. Signal gets 12v+ when the ignition is on. The signal wire is what turns the alt on and powers the regulator. Link to comment Share on other sites More sharing options...
importwarrior Posted October 22, 2015 Author Report Share Posted October 22, 2015 Is the signal what tels the alt what voltage output is? Link to comment Share on other sites More sharing options...
Turbo Cary Posted October 22, 2015 Report Share Posted October 22, 2015 Is the signal what tels the alt what voltage output is? No I believe Signal is for the gauge. The L for lamp is to activate the battery light on the dash. That's what I took from what was said Link to comment Share on other sites More sharing options...
ucw458 Posted October 22, 2015 Report Share Posted October 22, 2015 No the signal wire isn't for the gauge. Nor does it tell the alt what the voltage output is. The signal wire just turns on the alt. 12v+ when the key is on that's all. The gauge gets power from the ignition switch. Link to comment Share on other sites More sharing options...
importwarrior Posted October 22, 2015 Author Report Share Posted October 22, 2015 so the "L" only turns on the gauge dash light to say alt is not working.thats it? what tells the alt that just for example, it is producing 11 volts and you need to up the output.i know the regulator adjusts output voltage but something has to provide the current voltage produced. Link to comment Share on other sites More sharing options...
ucw458 Posted October 22, 2015 Report Share Posted October 22, 2015 Yes it only turns on the dash light. The regulator handles all output. It monitors output voltage and adjusts the voltage it sends to the stator. The regulator is a variable power supply. If you send 12 volts to the stator you get around 35 volts from the alt. So the regulator feeds around 3-5 volts to the stator depending on current load conditions to get 13-14 volts output. The 12v+ S terminal powers the regulator. 1 Link to comment Share on other sites More sharing options...
