Scoobysruvenge Posted August 1, 2015 Author Report Share Posted August 1, 2015 I'm working in it.., ,. Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 1, 2015 Author Report Share Posted August 1, 2015 Is the needle some kind of check valve to prevent back flow? Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 2, 2015 Author Report Share Posted August 2, 2015 What is this on the the stock fuel pump pressure hose. Is the a Damner of some kind damper device? Do you guys know of a thread/s on this site that explain these pieces? Do I need to add these types of devices to my current set up? Looks better yes.... http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150801_194633_611_zpsazuooe9e.jpg Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 2, 2015 Author Report Share Posted August 2, 2015 It would have been better but I put the wrong pic Aahhhhh.... Here is the correct pic. I'm am Woking on it guys. http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150801_194731_482_zps2gemhiun.jpg Link to comment Share on other sites More sharing options...
87redcat Posted August 2, 2015 Report Share Posted August 2, 2015 http://starquest.i-x.net/viewtopic.php?t=1031 8 pages of posts. Now that's a way to boost you post count. the pic above is a damper for the fuel pump if I remember corectly. If you have not already, remove the small cone filter located at the inlet side of the pump. It will not work with any aftermarket pump. It can get stuck and ruin the pump.see the post above... Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 3, 2015 Author Report Share Posted August 3, 2015 Thanks Redcat, the article above explained alot. Still curious I dug deeper into the fuel damper. What I found out is as follows: 1. Fuel dampers basically smooth the out the pulsating created by the opening and closing of the injector/s. This damper in practice creates a smoother less glitchy Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 3, 2015 Author Report Share Posted August 3, 2015 throttle response. 2. Many manufactures use these devices OEM. This got me a little more convinced that maybe there was something to this fuel damper thing. So I figured if there was something to it there must be an aftermarket for it. So I looked and I could not find much just a bunch of OEM dampers and very few specs. In addition... Can one of these devices restrict fuel if not properly sized and if it truley smooths delivery why is there no aftermarket? Racers will take any advantage they can to get an advantage and it seems to me there would be someone selling these in any color you want with different sizes. Are there any members running there pump without one? I'm sure there are. Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 4, 2015 Author Report Share Posted August 4, 2015 When I got home yesterday I found a small white box on the porch. It felt light but one opened I saw a well packed sending unit. Now the question was is it a POS http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150804_173513_448_zpswngmdw8z.jpg Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 4, 2015 Author Report Share Posted August 4, 2015 http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150804_173755_600_zpsrzsvj5wt.jpg Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 4, 2015 Author Report Share Posted August 4, 2015 http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150804_173801_338_zpsk194nnfn.jpg Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 4, 2015 Author Report Share Posted August 4, 2015 http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150804_173819_160_zpsh7el9cgy.jpg Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 4, 2015 Author Report Share Posted August 4, 2015 Sorry about the multiple posts for pics l can only get one in per post? Link to comment Share on other sites More sharing options...
BuGG Posted August 4, 2015 Report Share Posted August 4, 2015 (edited) No, just like ucw said you can do 10 per post. Edited August 4, 2015 by BuGG Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 5, 2015 Author Report Share Posted August 5, 2015 I tried and everytime I try put the second pic in I just get blue bars??? Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 5, 2015 Author Report Share Posted August 5, 2015 Here is a website that gives a method for determining if a fuel damper is needed. Of course the company sells an aftermarket fuel damper (red only) http://www.injector.com/cart/pc/viewCategories.asp?idCategory=4 Link to comment Share on other sites More sharing options...
87redcat Posted August 5, 2015 Report Share Posted August 5, 2015 that fuel sender looks like its brand new. Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 5, 2015 Author Report Share Posted August 5, 2015 Looking on car_ part.com I found a listing out of MA for a TSI gastank dented. I called to see if it had a sending unit. They sent me a pic (not very one) but the seller assured me it was in good working order and for $60 shipped I took a shot. I was pleasantly surpized when I opened the box. The only thing that does not look perfectly new is the top of the sending unit. However a little Scotchbrite and I'm sure it would shine right up. Newbie's luck! Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 5, 2015 Author Report Share Posted August 5, 2015 http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150804_173833_105_zpshow6znel.jpg Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 8, 2015 Author Report Share Posted August 8, 2015 With the gas tank ready, swnnding unit aquired, pump, filter and plumbing assembled... I just need the tank strainer which I can get at my local Mitsubishi dealership. The other parts I need are: The sending unit gasket. Fuel pump gasket. I have the old fuel pump rubber gasket, it's not bad at all but I would like to have a new one. I have no sending unit gasket at all. I can make one if OEM is not available. Do any of the members here know were to get these gaskets? Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 8, 2015 Author Report Share Posted August 8, 2015 Weather permitting I will remove the fuel injectors and blow out the fuel lines. I have read about the injector clips as a common source of trouble so a replacement set of clips are on my list of parts needed. I was curious if you guys have purchased and installed one of the many rebuild kits I see on line? Or should I just have the injectors tested, cleaned and the rubber o rings replaced? Link to comment Share on other sites More sharing options...
87redcat Posted August 8, 2015 Report Share Posted August 8, 2015 Check around and you will find a throttle body rebuild kit that contains the o rings for the injectors. usually around 30 bucks.also check out Lower Shores Performance. do a search for that name on this site. He has some throttle body shaft seals and some o rings for the fuel line that enters the top hat on top of the throttle body. cleaning out the metal fuel lines is a great idea. Dont forget to replace the 2 rubber lines up front and the return line. I had mine replace at a local shop. they reused the original ends of the hoses and crimped them in the new hose. cost me about 5 buck a piece. Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 8, 2015 Author Report Share Posted August 8, 2015 Thanks for the vote of confidence and advice. I have not looked over the throttle body or the hoses yet. Weather permitting I will get a Good look at everything under the hood tomorrow. I still a have radiator to get dipped and cleaned and have the cooling system to go through. Beyond that have to put all the stuff the previous owner had removed and put in the hatch. Air beather, vaccum lines and so on. Then hopefully I can get the car running in good stock form with the exception of the 16g for starters and upgrade the car as I go. Link to comment Share on other sites More sharing options...
87redcat Posted August 8, 2015 Report Share Posted August 8, 2015 Yes get the car running good before you start modding the crap out of it. That way with one mod at a time you can tell if something is wrong Link to comment Share on other sites More sharing options...
Scoobysruvenge Posted August 8, 2015 Author Report Share Posted August 8, 2015 The weather held but honey dos got in the way of an early start. I finally got to work this afternoon on the TB and fuel lines. http://i611.photobucket.com/albums/tt198/Scoobysruvenge1/Mobile%20Uploads/IMG_20150808_143746_575_zpszrskyhw6.jpg Link to comment Share on other sites More sharing options...
