elkuko87 Posted August 25, 2014 Report Share Posted August 25, 2014 Hi I am new at this web forum I was told when I took off my flywheel that when I re install will need to index why there is only one way that this goes on when you match up the bolts can any one help me with this also need bolts I lost one thinking about arp need input I am at a stand still know Quote Link to comment Share on other sites More sharing options...
speedyquest Posted August 25, 2014 Report Share Posted August 25, 2014 You can take a look at the service manuals by going to www.starquestgarage.com and either downloading or viewing them. That should get you all the information you ever need. Good luck man : ) Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 25, 2014 Author Report Share Posted August 25, 2014 I try to go on it its under construction Quote Link to comment Share on other sites More sharing options...
ucw458 Posted August 25, 2014 Report Share Posted August 25, 2014 It's been "under construction" for many years. Alot of info is there if you click on the links. Quote Link to comment Share on other sites More sharing options...
speedyquest Posted August 25, 2014 Report Share Posted August 25, 2014 I sent him a link to the actual menu of the pdf's. Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 25, 2014 Author Report Share Posted August 25, 2014 thanks Quote Link to comment Share on other sites More sharing options...
Dad Posted August 26, 2014 Report Share Posted August 26, 2014 it's not clocked unless you have a dowell Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 26, 2014 Author Report Share Posted August 26, 2014 what do you mean clock the holes lined up Quote Link to comment Share on other sites More sharing options...
Dad Posted August 26, 2014 Report Share Posted August 26, 2014 No indexing required unless you have a dowel pin. Flywheel is zero balanced so doesn't matter indexed or not. Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 26, 2014 Author Report Share Posted August 26, 2014 Do I still have to heat up the flywheel Quote Link to comment Share on other sites More sharing options...
speedyquest Posted August 26, 2014 Report Share Posted August 26, 2014 Have you read the service manual? Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 26, 2014 Author Report Share Posted August 26, 2014 it looks like you have to measure play like an index I have never had to do this you change a flywheel torque the bolts and that's thatno heating or anything else so I am confuse with this process I did not take the motor apart just to put on engine stand if I knew was going to be like this I would have left it alone Quote Link to comment Share on other sites More sharing options...
Dad Posted August 26, 2014 Report Share Posted August 26, 2014 Same deal on a stock Quest, flywheel can be installed easily, all bolt holes are the same so no indexing needed, Now if you have an 88 or 89 year quest then your flywheel has a dowel pin hole, then of course it goes on only one way. I have seen instructions on heating a flywheel to install but that is only for the aluminum Fidenza flywheel, Which by the way will use a dowel. I sure hope this helps you. Don't think I can be any clearer. Dad Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 26, 2014 Author Report Share Posted August 26, 2014 thanks that means torque bolts and go on Quote Link to comment Share on other sites More sharing options...
Dad Posted August 27, 2014 Report Share Posted August 27, 2014 With a little threadlocker Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 27, 2014 Author Report Share Posted August 27, 2014 thank you ser dad Quote Link to comment Share on other sites More sharing options...
elkuko87 Posted August 27, 2014 Author Report Share Posted August 27, 2014 AND THANKS TO EVERYONE FOR THE HELP ;) Quote Link to comment Share on other sites More sharing options...
