nycain Posted September 24, 2013 Report Share Posted September 24, 2013 (edited) driving home earlier i smell somthing burning stop and check it was the #6 fuse tail so i replaced it , then i feel the fuse it got so hot it starts to melt has anyone ever have that issue before or what should i start checking Edited September 24, 2013 by nycain Link to comment Share on other sites More sharing options...
ucw458 Posted September 24, 2013 Report Share Posted September 24, 2013 Check your grounds. Bad grounds cause resistance and higher current flow. That can blow fuses. Link to comment Share on other sites More sharing options...
jszucs Posted September 24, 2013 Report Share Posted September 24, 2013 Check all your tail light bulbs. Most have let moisture in and are nasty. Could be a short in there. Check the wireing going to the pedal switch, might also be starting to short. Clean and bend the tabs for the fuses. Link to comment Share on other sites More sharing options...
Shelby Posted September 24, 2013 Report Share Posted September 24, 2013 almost every fuse on the car has more then one circirt ran thru it,, just because the fuse says brake lights don't think that can be the only place theres a problem ,theres only one place in the FSM that lists fuses and all circirts that run thru each but i can't recall exactly where thats located i know thats not much help Link to comment Share on other sites More sharing options...
nycain Posted September 26, 2013 Author Report Share Posted September 26, 2013 the problem was the gluster had a broken circuit replaced it and every thing is ok yea!!!! Link to comment Share on other sites More sharing options...
Shelby Posted September 26, 2013 Report Share Posted September 26, 2013 see had nothin g to do with stop lamp circirt Link to comment Share on other sites More sharing options...
nycain Posted September 27, 2013 Author Report Share Posted September 27, 2013 thanks guys Link to comment Share on other sites More sharing options...
