Starquest87Jimmy Posted October 25, 2013 Report Share Posted October 25, 2013 87quest_stv How did you get your head lights to look like that? What head lights did you put it there. Link to comment Share on other sites More sharing options...
importwarrior Posted October 25, 2013 Report Share Posted October 25, 2013 those lights are permanently fixed like that. i dont believe they go up and down. Link to comment Share on other sites More sharing options...
87quest_stv Posted October 25, 2013 Report Share Posted October 25, 2013 87quest_stv How did you get your head lights to look like that? What head lights did you put it there. custom fab. tore the old light assembly out and only re-used the lid. built my own light box and mounts for HID projectors.here's a link to my build.... I stopped working on the car dead in its tracks a yr and a half ago. so I dont have any further progress at this time. But I'm planning to start again. http://www.starquestclub.com/forum/index.php?showtopic=129075 Link to comment Share on other sites More sharing options...
jtmuncher Posted October 28, 2013 Author Report Share Posted October 28, 2013 (edited) what is this small harness used for? its the one on the passenger firewall right next to the clutch fluid res . also correct me if I am wrong but since there is an open connection now, I need to run a brake line from the proportion valve to the master cylinder right? thankshttp://img.photobucket.com/albums/v440/leche1103/null_zps3a861493.jpg Edited October 28, 2013 by jtmuncher Link to comment Share on other sites More sharing options...
Funky Phil Posted October 28, 2013 Report Share Posted October 28, 2013 brake fluid low level sensor/windshield wiper motor/ABSand yes, if your referring to the removal of the abs pump. Link to comment Share on other sites More sharing options...
importwarrior Posted October 28, 2013 Report Share Posted October 28, 2013 well as far as engine harness goes.i would figure out the wire colors for theoil pressure sender wirestarter wirewater temp gauge sensor wirethen try and save then to use on your new engine. then most of the gauges should work.if you choose to use the stock gauges on the car. Link to comment Share on other sites More sharing options...
19cturbo Posted October 28, 2013 Report Share Posted October 28, 2013 on that brake line, you can either get a new line and run it. or, like i did, i reused the factory one, i just cut and reflared the end of it and re bent it to go to the proportioning valve.. Link to comment Share on other sites More sharing options...
jtmuncher Posted October 28, 2013 Author Report Share Posted October 28, 2013 Thanks guys. I appreciate the help. Unfortunately the previous owner hacked up some of the wiring under the dash and down near the ecu. The more I can eliminate the better. I think I bit off as much as I can chew with this car, maybe a little more. Link to comment Share on other sites More sharing options...
19cturbo Posted October 28, 2013 Report Share Posted October 28, 2013 (edited) take some pics of the haggard wiring.. some of it you may not need. pictures are worth a thousand words, always helps us answer questions.. Edited October 28, 2013 by 19cturbo Link to comment Share on other sites More sharing options...
87quest_stv Posted October 28, 2013 Report Share Posted October 28, 2013 http://www.starquestgarage.com/manuals/service/conquest/1988/88_conquest_service_manual_-_group_26_-_electrical.pdf save this to your favorites Link to comment Share on other sites More sharing options...
19cturbo Posted October 29, 2013 Report Share Posted October 29, 2013 http://www.starquest..._electrical.pdf save this to your favorites its easier to download them all. i have a file on my desktop with them all in it.. you dont have to wait on them to load at that point. Link to comment Share on other sites More sharing options...
jtmuncher Posted October 29, 2013 Author Report Share Posted October 29, 2013 (edited) take some pics of the haggard wiring.. some of it you may not need. pictures are worth a thousand words, always helps us answer questions.. Thanks. Daughter had a band recital this evening so I didn't get much done today. I will get some specific pics posted up of the hacked wiring in the next day or two. http://www.starquest..._electrical.pdfsave this to your favorites Done...good stuff, thank you. Thanks again fellas. Edited October 29, 2013 by jtmuncher Link to comment Share on other sites More sharing options...
jtmuncher Posted November 3, 2013 Author Report Share Posted November 3, 2013 http://img.photobucket.com/albums/v440/leche1103/null_zps203a45dc.jpghttp://img.photobucket.com/albums/v440/leche1103/null_zpsbaa80d9f.jpghttp://img.photobucket.com/albums/v440/leche1103/null_zps437379e3.jpg Engine bay is about ready. Need to start hammering out trans tunnel now. Link to comment Share on other sites More sharing options...
87quest_stv Posted November 3, 2013 Report Share Posted November 3, 2013 damn... that was fast.. great job Link to comment Share on other sites More sharing options...
importwarrior Posted November 4, 2013 Report Share Posted November 4, 2013 Use a bottle jack and some wood on that trans tunnel. I read some where one guy used that when he did his swap. Link to comment Share on other sites More sharing options...
jtmuncher Posted November 4, 2013 Author Report Share Posted November 4, 2013 damn... that was fast.. great job Thanks. IMO it took me way to long...the car is really in bad shape. Most of the bolts/nuts that come off are rusted and a lot of of the body panels are rusted as well. next on the list; finish removing engine harness, gut out everything out under the passenger side dash, open up hole in firewall for Toyota harness, open up trans tunnel.... in that order. As for the tunnel, I like the idea of the bottle jack so I will try that first. Need to go thru the threads to see exactly where and how much it needs to widen. Thanks again. Link to comment Share on other sites More sharing options...
19cturbo Posted November 4, 2013 Report Share Posted November 4, 2013 that was me.. it worked like a charm! no hammer just kept flipping the jack from side to side pressing one side then the other.,.. mainly you just want to flatten the ribs that are under there.. http://i223.photobucket.com/albums/dd23/19cturbo/1JZ%20SWAP/5F5161EE-8640-4320-8DF8-57E07E0DEB2A-315-000000C94969F11B_zps095eb45d.jpg Link to comment Share on other sites More sharing options...
19cturbo Posted November 4, 2013 Report Share Posted November 4, 2013 are you retaining your ac? if you remove that big black box for the AC, the toyota harness will go right through that hole.. http://i223.photobucket.com/albums/dd23/19cturbo/1JZ%20SWAP/CBD3578B-E666-4DC6-9851-17840E466E5E-49022-000020D315D3876A_zps17479b84.jpg then i made a bracket and mounted my ECU where that box was.. http://i223.photobucket.com/albums/dd23/19cturbo/1JZ%20SWAP/6F72D4E1-D22D-433B-8271-C351BD833658-27462-0000115385A96A1F_zpsd92948e5.jpg Link to comment Share on other sites More sharing options...
jtmuncher Posted November 4, 2013 Author Report Share Posted November 4, 2013 (edited) Nah AC is gone along with just about every other amenity. At this point I hope the head lights work. The popup mechanism would be a plus haha. I thought that existing hole in the fw had to be widened a bit. Thanks for mentioning that about the ribs in the tunnel. Now I know exactly what needs to be done. We have beading air guns at work that might do this job if my compressor will keep up. I hope to have more updates next week. Thanks again. Edited November 4, 2013 by jtmuncher Link to comment Share on other sites More sharing options...
19cturbo Posted November 4, 2013 Report Share Posted November 4, 2013 i didnt have to widen the hole in the firewall at all Link to comment Share on other sites More sharing options...
jtmuncher Posted November 4, 2013 Author Report Share Posted November 4, 2013 Ok good to know. I appreciate your help. Link to comment Share on other sites More sharing options...
19cturbo Posted November 4, 2013 Report Share Posted November 4, 2013 (edited) not a problem. i had lots of questions to when i first done this lol! you should have seen my post when i went MPI.. i was a mess Edited November 4, 2013 by 19cturbo Link to comment Share on other sites More sharing options...
importwarrior Posted November 4, 2013 Report Share Posted November 4, 2013 (edited) LOL Thanks! for the pics on the bottle jack. I could not remember who used it.why not work smarter not harder. Edited November 4, 2013 by importwarrior Link to comment Share on other sites More sharing options...
BOHO Posted November 4, 2013 Report Share Posted November 4, 2013 I did have to widen the hole a bit. The 2jz plugs are a little bigger than the 2jz ones. Just FYI...19c doesn't know everything..... ;) Link to comment Share on other sites More sharing options...
importwarrior Posted November 4, 2013 Report Share Posted November 4, 2013 i think you mis-typed.I did have to widen the hole a bit. The 2jz plugs are a little bigger than the 2jz ones. Just FYI...19c doesn't know everything..... ;) Link to comment Share on other sites More sharing options...
