austinyoung420 Posted June 12, 2013 Report Share Posted June 12, 2013 neith one of my windows roll up or down 1988 conquest, and I hooked a battery directly to my right side motor and it didnt move at all does this mean its shot?can I rebuild them at all?is there a relay that must be applied with power?? Quote Link to comment Share on other sites More sharing options...
Crazy larry Posted June 12, 2013 Report Share Posted June 12, 2013 did you connect ground to door and then touch a spade connector one is up and one is down the motors seldom go bad it is more likely in the switch Quote Link to comment Share on other sites More sharing options...
importwarrior Posted June 12, 2013 Report Share Posted June 12, 2013 does it even try to move at all? can you hear the motor try to actually move?i agree clean the switch. and lube up the inside of the door window rollersand guide. Quote Link to comment Share on other sites More sharing options...
mistapickles Posted June 12, 2013 Report Share Posted June 12, 2013 and lube the guides... that old grease gets as hard as plastic and will hold the window in place... Quote Link to comment Share on other sites More sharing options...
JAinsworth Posted June 12, 2013 Report Share Posted June 12, 2013 This may help: http://www.starquestclub.com/forum/index.php?showtopic=105599 Quote Link to comment Share on other sites More sharing options...
austinyoung420 Posted June 13, 2013 Author Report Share Posted June 13, 2013 they both worl with power hooked directly up to the motor but the switches I guess, shoudlnt there be power coming from one of the wires going to the switch?I checked with a test light and got nothing. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted June 13, 2013 Report Share Posted June 13, 2013 clean them and die eledtric grease them. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 17, 2013 Report Share Posted June 17, 2013 (edited) The window motors in these cars don't go bad. Never heard of one crapping out. The switch is more likely the culprit, as stated, disassemble them, clean them and apply so electric grease. Mitsu made hella good quality electric motors. I know all the new cars have window motors that crap out not long after warranty. It's a big business. Edited June 17, 2013 by louswheel01 Quote Link to comment Share on other sites More sharing options...
