RML88TSi Posted May 13, 2013 Report Share Posted May 13, 2013 My brake booster is leaking at the front seal and won't hold vacuum. I'm looking for a good brake booster to replace it. Let me know if you got one shipped to Fl 33763. Thanks Ryan Quote Link to comment Share on other sites More sharing options...
ColdScrip Posted May 13, 2013 Report Share Posted May 13, 2013 Hey Ryan. I know rockauto stocks them and I am not the biggest fan of paying their prices for one. A solution I have done that has fixed many leaky booster of mine is to use an epoxy where it leaks. I have tested the vacuum before and after and it holds perfectly. Also I have had some occurrences where the pedal feels fine until you start the car. Then the pedal feels extremely soft and then suddenly the brakes come on hard. If thats your case thats not a leaky booster. Quote Link to comment Share on other sites More sharing options...
RML88TSi Posted May 13, 2013 Author Report Share Posted May 13, 2013 Well I am just trying to get this car on the road and haven't driven it. While attempting to bleed the brakes, I could hear air coming out and never got pedal pressure. I could blow on the pipe of the booster and air would come out at the master cylinder. I removed it and it's leaking around the rod that pushes the master. Can I epoxy around that seal? Quote Link to comment Share on other sites More sharing options...
obsolete Posted May 14, 2013 Report Share Posted May 14, 2013 (edited) SOLD I got one. Just repainted satin black, looks f-l-y. $50+ship? Also have a reman master cylinder and braided ABS delete line if you want them. http://i39.tinypic.com/2wnqu1f.jpg Edited June 5, 2013 by obsolete Quote Link to comment Share on other sites More sharing options...
speed racer Posted May 14, 2013 Report Share Posted May 14, 2013 Don't be a cheap butt.buy a brand new one,they are not that expensive.Idk if epoxy will hold up to the heat for a long time.good luck with that anyway.Rockauto doesn't have best prices but they sure beat the local autoboners and Ive had good luck with them so far and have ordered a lot of stuff from them.My brake booster is bad also and the master cylinder leaking into the boster.the engine then sucks in te brake fluid and well brake fluid doesn't make a very good fuel in a starion.lol. Quote Link to comment Share on other sites More sharing options...
ColdScrip Posted May 14, 2013 Report Share Posted May 14, 2013 I wouldn't epoxy the front. Nevermind that. I'd go new/reman in your case. Also I have no concerns whatsoever about heat getting to the rear of the brake booster where its been epoxied. You also don't use cheap epoxy Been fine for 3 years now 100+ degree days in traffic. Quote Link to comment Share on other sites More sharing options...
RML88TSi Posted May 14, 2013 Author Report Share Posted May 14, 2013 Thanks for the replies. Yeah epoxy didn't sound right for that seal. Obsolete I sent you a pm. Quote Link to comment Share on other sites More sharing options...
thetexan88 Posted May 15, 2013 Report Share Posted May 15, 2013 If you end up wanting a good used one let me know. I have one ready to put in a box and send your way. Thanks, David Springer Quote Link to comment Share on other sites More sharing options...
Starquest87Jimmy Posted June 3, 2013 Report Share Posted June 3, 2013 (edited) I just did a new one and rebuild master from auto zone. When it comes to your life do you trust used unknown? The leak of fluid is from the master, the booster doesn't hold fluid. Edited June 3, 2013 by Starquest87Jimmy Quote Link to comment Share on other sites More sharing options...
pyro_nate Posted June 5, 2013 Report Share Posted June 5, 2013 I have a new brake booster,master cylinder, and clutch master cylinder. Might as well replace all three as long as your going through the effort of replacing the booster. Quote Link to comment Share on other sites More sharing options...
iFREAKNiK Posted June 5, 2013 Report Share Posted June 5, 2013 I'll buy, call me asap 6788518513 I got one. Just repainted satin black, looks f-l-y. $50+ship? Also have a reman master cylinder and braided ABS delete line if you want them. http://i39.tinypic.com/2wnqu1f.jpg Quote Link to comment Share on other sites More sharing options...
iFREAKNiK Posted June 5, 2013 Report Share Posted June 5, 2013 I need a brake booster, the master cylinder and etc is a plus. When you call, tell me about these lines you speak of - Quote Link to comment Share on other sites More sharing options...
obsolete Posted June 5, 2013 Report Share Posted June 5, 2013 Booster was sold a couple weeks ago. I don't want to turn this into a for sale thread, so I'll send you a PM. Quote Link to comment Share on other sites More sharing options...
