Everything posted by RML88TSi
I added a few pics of it mounted to a spare head. It clears the distributor and looks like the angle in the back should clear the brake booster.
Thanks and yes this was on a g54. I never installed it but I have a spare head to try and check some clearances.
I'm selling a custom manifold that was run on a race corolla. It uses bosch style injectors and the fuel rail has 8an fittings. Throttle body bolt pattern is 3.5" by 3.5". Because it was on a track car there was no thermostat or rear water pass. However, the threaded fitting could be cut off and use a remote thermostat set up like the FIP manifold. The rear water could also be drilled and tapped for a fitting. It's a very nicely made manifold that I hope someone can use. Sold http://i1160.photobucket.com/albums/q482/lckhrt/MPI%20Manifold/2abd0876-fe4f-48d5-affd-76e4869655cd_zpsxfamsy2s.jpg
Sent a pm and got a line going.
I've got a set of hard pipes I'm not going to be using. Three pieces including the over the valve cover pipe, wrap around air can pipe, and a small pipe off of the intercooler. The ovcp has a turbo xs style flange for a blow off valve. Also, some couplers and hose clamps. Asking $150 plus shipping or best offer. Sold "http://i1160.photobucket.com/albums/q482/lckhrt/Hardpipes/3cd4d3c6-539a-4f93-b5a0-517326890376_zpsmm1zqqhe.jpg"
This turbo was built by cmr turbo in tampa. It has the stock exhaust housing so it is a bolt on.
It Is the big 16 and td05h
I have for sale a 16g turbo that was used for a very short time before going bigger. With it comes new braided oil feed line and drain. Also, new water lines and banjo bolts. Sold "http://i1160.photobucket.com/albums/q482/lckhrt/Turbo/d9ea7845-c81a-4f7f-b9b1-3a63863e66fe_zpsckfojpjk.jpg"
Driver side has the usual hole in the bolster and the leather is pretty dry on both.
PM sent
Thanks for the list sent you a PM
Is it the triangle shaped piece on the door? What's needed to remove the rear hub?
I'm not sure if you're talking about the coin tray in the center console-- it wasn't there and the console was broken. I could still get the column covers but I'm not sure how much they'll be as they aren't mentioned on the price list. As far as the rear axle, it's listed as $37 and the shipping to you in CA would probably not make worth getting. I can probably go back this weekend.
What part are you looking for?
Just a heads up for anyone near the Clearwater LKQ. There are two Starions 86 and 88 that have some good parts left. http://lkq190.com/fu...-21-c4p-014.jpg
SOLD Thanks Joel
I am selling a 89 Starion(159 total built that year), 5spd with 167k miles. It is white and has been repainted at some point. I replaced the rusted tank, fuel pump with a good spare, spare injectors and new fuel filter. It will run but has a bad exhaust leak. I also swapped the clutch master and slave. It will drive but the brakes are no good-the master is rusted and rear calipers seized. The interior is tan with nice seats. It is missing some pieces like the center console. The windshield is cracked and has rusted through in two spots both top and bottom. The driver fender has been hit and needs replacing--I have a good fender to go with it. Passenger fender has been scraped but not dented. The driver frame rail has started to rust but not rotted. Both mirror housings are cracked but I have replacements. This car has been sitting for years, seen its share of abuse, and will have to be towed. With two other conquests in the garage, I've come to realize that I have neither the time or money to keep this car. I saved this rare 89 from the crusher and hope I can get a fellow enthusiast to get her back on the road. I'm sure I missed something and would be glad to answer any questions. Again, this is a project and needs a lot of care. Title, I'm asking $1200. I'm located in Clearwater FL 33763.
I've got a pair off my 87 wide body parts car I won't use. I can get you a pic if you're interested.
Not mine. I looked at this today http://tampa.craigslist.org/hil/cto/3903417871.html Rare 89 starion with R48 windsor red paint code. Runs and drives has 2 tone black tan checker cloth interior, been resprayed and would need complete restoration. I know some enthusiast would like to pick this rare car up, just too much for me. A few pics I took http://s1160.photobu.../R48 89 Starion
I purchased a brake booster from obsolete. He sold me a really nice part, packed it up nice, and shipped it quick. Thanks again
Thanks for the replies. Yeah epoxy didn't sound right for that seal. Obsolete I sent you a pm.
Well I am just trying to get this car on the road and haven't driven it. While attempting to bleed the brakes, I could hear air coming out and never got pedal pressure. I could blow on the pipe of the booster and air would come out at the master cylinder. I removed it and it's leaking around the rod that pushes the master. Can I epoxy around that seal?
My brake booster is leaking at the front seal and won't hold vacuum. I'm looking for a good brake booster to replace it. Let me know if you got one shipped to Fl 33763. Thanks Ryan
