rioyellow Posted March 23, 2013 Report Share Posted March 23, 2013 Hey I was thinking if any one ever put a launch control on a starquest that will be cool if anyone did let me no I wood like to buy one for my quest Link to comment Share on other sites More sharing options...
rioyellow Posted March 23, 2013 Author Report Share Posted March 23, 2013 I guess no one Link to comment Share on other sites More sharing options...
StarquestRescue Posted March 23, 2013 Report Share Posted March 23, 2013 What are you calling launch control? To me it means a system that can controller timing, boost and rpm. And than ramp the power in as traction allows. That pretty much takes a stand alone ecu system. The most sophisticated systems employ traction control as well. A msd ignition with a two step rev limiter can be installed. But if you are thinking of a system to control the timing at launch, that takes a stand alone ecu. Make the power first, than buy some good drag radials. Link to comment Share on other sites More sharing options...
scott87star Posted March 23, 2013 Report Share Posted March 23, 2013 Lots of guys are running launch control, I've personally set up at least a dozen MS or FIP systems for launch control. As SQR says, they are stand alone fuel/ignition controllers with launch control option which allows for programming all the rpm limits, timing retard and spark/fuel cut to optimize your requirements. Link to comment Share on other sites More sharing options...
vbrad511 Posted March 23, 2013 Report Share Posted March 23, 2013 Or are you thinking of a line lock on the front brakes....old school? 1 Link to comment Share on other sites More sharing options...
Funky Phil Posted March 23, 2013 Report Share Posted March 23, 2013 line lock = roll control Link to comment Share on other sites More sharing options...
Crazy larry Posted March 23, 2013 Report Share Posted March 23, 2013 I'm running a line lock. it can be done. Link to comment Share on other sites More sharing options...
rioyellow Posted March 24, 2013 Author Report Share Posted March 24, 2013 I'm talking about a two step rev limiter Link to comment Share on other sites More sharing options...
StarquestRescue Posted March 24, 2013 Report Share Posted March 24, 2013 I recommend using the 8910 adapter. http://www.starquestclub.com/forum/index.php?showtopic=58296 Link to comment Share on other sites More sharing options...
Funky Phil Posted March 24, 2013 Report Share Posted March 24, 2013 yes, buy either an MSD 6AL2 (programmable or non-programmable) Or an older MSD 6AL box with a 2 step control. Those will do it for you. then get a tach adapter and wire it up Link to comment Share on other sites More sharing options...
