Seekerz Posted March 30, 2012 Report Share Posted March 30, 2012 is there a preassembled rebuild kit made by any company out there or would i have to buy each item individually?? Also where would i get a good turbo rebuild kit?? Quote Link to comment Share on other sites More sharing options...
Dad Posted March 30, 2012 Report Share Posted March 30, 2012 http://www.enginemachineservice.com/conquest.html Quote Link to comment Share on other sites More sharing options...
apate Posted March 30, 2012 Report Share Posted March 30, 2012 You can get a turbo kit from EbayCheck out this thread (post 15 has a link to ebay) http://www.starquestclub.com/forum/index.php?showtopic=125700&hl=&fromsearch=1 Quote Link to comment Share on other sites More sharing options...
Seekerz Posted March 30, 2012 Author Report Share Posted March 30, 2012 Thanks Dad and apate. My car is running super hot and its running rough so i have a feeling im headed towards a complete rebuild before long.... Quote Link to comment Share on other sites More sharing options...
Seekerz Posted March 30, 2012 Author Report Share Posted March 30, 2012 Also where does everyone get their hard pipes? Quote Link to comment Share on other sites More sharing options...
Technology Posted March 30, 2012 Report Share Posted March 30, 2012 This site. And have you replaced the thermostat? Quote Link to comment Share on other sites More sharing options...
Indiana Posted March 30, 2012 Report Share Posted March 30, 2012 Plugged up exhaustWrong ignition timingDead fansWrong concentration mix of coolant/waterWrong pressure radiator capDirty radiator coreGrass and bugs between the radiator and a/c condenser.Missing air dam and air guideToo large intercooler blocking air flow up to the radiator (air doesn't come through the "grill") Why would you think a motor that runs hot needs rebuilt? Is the oil cooler plugged up? The thermovalve in the oil filter adapter stuck closed? Quote Link to comment Share on other sites More sharing options...
john82wa Posted March 30, 2012 Report Share Posted March 30, 2012 (edited) Look at this and scroll down till you hit the cooling system. Excellent guide: http://www.starquest...showtopic=66449 I think this should be pinned up to the top or placed somewhere in the newb section (pinned though). It took me awhile to find it again and its a great reference!! Edited March 30, 2012 by john82wa Quote Link to comment Share on other sites More sharing options...
Seekerz Posted April 1, 2012 Author Report Share Posted April 1, 2012 (edited) I fixed half the problem of rough and hot. I had a leak in the water pump gasket that only became a visible problem when it was running. Plugged up exhaust Wrong ignition timing Dead fans Wrong concentration mix of coolant/water Wrong pressure radiator cap Dirty radiator core Grass and bugs between the radiator and a/c condenser. Missing air dam and air guide Too large intercooler blocking air flow up to the radiator (air doesn't come through the "grill") Why would you think a motor that runs hot needs rebuilt? Is the oil cooler plugged up? The thermovalve in the oil filter adapter stuck closed? Everything is mostly stock (radiator cap, intercooler, etc.) fans are hot wired to a switch i can flip on and off, no thermostat but im putting one in soon, has air dam and guide, timing is as close as we can get it and no one has been able to get it perfect, no grass or bugs, exhaust is clear, radiator shouldnt be plugged up i believe my father flushed it out. And i will have to check out all the oil system components when i replace the gasket, filter, and sensor. I think it needs rebuilt because it has been ran hard since it last had anything done to it over all, so id rather be safe than sorry. Edited April 1, 2012 by Seekerz Quote Link to comment Share on other sites More sharing options...
Indiana Posted April 1, 2012 Report Share Posted April 1, 2012 fans are hot wired to a switch i can flip on and off, no thermostat. If there's no thermostat it will never cool down. The coolant flows way too fast. There's more heat coming from the engine than is being removed from the radiator. Its blown into the water jacket and now the only restriction is all the little holes in the block deck and when it gets to the radiator it just blasts right on through. You aren't smarter than a sensor to turn the fans on and if they run all the time they burn up, overheat wiring and kill alternators. Put it back together the way its supposed to be. Quote Link to comment Share on other sites More sharing options...
Seekerz Posted April 1, 2012 Author Report Share Posted April 1, 2012 If there's no thermostat it will never cool down. The coolant flows way too fast. There's more heat coming from the engine than is being removed from the radiator. Its blown into the water jacket and now the only restriction is all the little holes in the block deck and when it gets to the radiator it just blasts right on through. You aren't smarter than a sensor to turn the fans on and if they run all the time they burn up, overheat wiring and kill alternators. Put it back together the way its supposed to be. I plan to but i needed a vehicle and that was the quickest way to get one so thats what i had to do. Im in the process of getting everything back to the way is supposed to be. And the thermostat that was in the engine when i got had been messed with. Somebody had cut it apart, cut the spring, welded it back together and put it back in. I tried testing it and it didnt even work. But i have another thermostat im putting in later today. And the fans arent connected to the alternator I have them wired to the battery and a switch breaking the power so i can control them. I have another set of fans if these burn up so its all temporary. Quote Link to comment Share on other sites More sharing options...
