87quest_stv Posted May 21, 2012 Author Report Share Posted May 21, 2012 (edited) I got my engine test fired today. And it sounded like It was running on 4 of the 6 cylinders. Kinda bummed out. Any clue where to start troubleshooting? I've examined the harness where it connects to the coils and the clips are all new looking and no crumbling. The wiring looks ok too. Edited May 21, 2012 by 87quest_stv Link to comment Share on other sites More sharing options...
87quest_stv Posted May 22, 2012 Author Report Share Posted May 22, 2012 So I pulled the plugs out and they were pretty black and wet. So figured they were fouled. Put some new ngk's in there and started right up and purred like a kitten Link to comment Share on other sites More sharing options...
87quest_stv Posted May 22, 2012 Author Report Share Posted May 22, 2012 (edited) Test run of the engine on the pallet. The sound quality is terrible from my phone. Also seems I have a vacuum leak somewhere. Will be replacing all the vacuum lines before installation http://www.youtube.com/watch?v=Xp_XPkY9vxk&feature=youtu.be Edited May 22, 2012 by 87quest_stv Link to comment Share on other sites More sharing options...
BOHO Posted May 22, 2012 Report Share Posted May 22, 2012 Mine did the same thing until I got the IAC working. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 22, 2012 Author Report Share Posted May 22, 2012 Mine did the same thing until I got the IAC working. was there some kind of reset you had to do? Link to comment Share on other sites More sharing options...
BOHO Posted May 22, 2012 Report Share Posted May 22, 2012 No but I didn't have the ground and 12v to it. The computer controls it but it needs a separate 12v and ground. Link to comment Share on other sites More sharing options...
87quest_stv Posted May 23, 2012 Author Report Share Posted May 23, 2012 Working on replacing the cam seals, crank seals, waterpump, timing, and serpentine belt. Man that JDM waterpump is heavy! There's probably about 3 lbs of weight savings over the US waterpump. Link to comment Share on other sites More sharing options...
BOHO Posted May 23, 2012 Report Share Posted May 23, 2012 I thought about keeping it and running hydraulic doors....yes....I had that thought...lol... Link to comment Share on other sites More sharing options...
87quest_stv Posted May 23, 2012 Author Report Share Posted May 23, 2012 (edited) I thought about keeping it and running hydraulic doors....yes....I had that thought...lol... That would be interesting. So just need to pick up a new thermostat tomorrow, and the new pulleys and I'll be able to button things upThe thermostat that was in there looked brand new. So did the timing belt. But I changed the timing belt anyhow and will put a new thermostat in too Got the new cam seals inhttp://www.getyasumminimotos.com/Conquest/engmaint3.jpg cleaned things up a bit and put the new water pump, new timing belt roller on, and front crank seal inhttp://www.getyasumminimotos.com/Conquest/engmaint.jpg And the new timing belt, along with hydraulic tensionerhttp://www.getyasumminimotos.com/Conquest/engmaint2.jpg Edited May 23, 2012 by 87quest_stv Link to comment Share on other sites More sharing options...
87quest_stv Posted October 21, 2013 Author Report Share Posted October 21, 2013 Bump to find.planning on finishing swap soon Link to comment Share on other sites More sharing options...
87quest_stv Posted October 27, 2013 Author Report Share Posted October 27, 2013 anyone know if these will work with a JDM 2jzgte turbo?http://www.ebay.com/itm/Twin-Turbo-Compressor-Wheel-TOYOTA-CT12A-1JZ-GTE-2JZ-GTE-37-2-54-mm-Supra-Soarer-/380733048436?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a5754674&vxp=mtr Link to comment Share on other sites More sharing options...
87quest_stv Posted October 28, 2013 Author Report Share Posted October 28, 2013 just ordered some needed stuff from drift motion to complete this engine and transmission.clutch forkFork supportoutput shaft seal for R154clutch release hub kitpressure plate bolt setclutch release bearingR154 bell to trans bolt setand 6061 Aluminum JZ Pulley Kit V2.0 I still need the bellhousing and clutch kit but i'll get that a little later Link to comment Share on other sites More sharing options...
87quest_stv Posted October 28, 2013 Author Report Share Posted October 28, 2013 I went and got into model airplane flying and wasted a bunch of money of that earlier this year. So once I get some of my planes sold i'll get the bellhousing and clutch ordered up.no rush cause I still have the scrub and paint my engine bay. rebuild my steering box, replace the balljoints and the main steering linkage Link to comment Share on other sites More sharing options...
87quest_stv Posted November 4, 2013 Author Report Share Posted November 4, 2013 this should be good for 350-400hp right? http://www.ebay.com/itm/121125981368 Link to comment Share on other sites More sharing options...
BOHO Posted November 4, 2013 Report Share Posted November 4, 2013 Never heard of them. Link to comment Share on other sites More sharing options...
87quest_stv Posted November 4, 2013 Author Report Share Posted November 4, 2013 me either. says can take up to 520hp. but I know you cant ever take them for the word with this non brand stuff. i'm just looking for something more affordable.I'm not planning a big power machine right now just come thing to drive daily. I did a best offer and they accepted it. so once I get things installed i'll give feedback on the part Link to comment Share on other sites More sharing options...
87quest_stv Posted November 5, 2013 Author Report Share Posted November 5, 2013 (edited) Got my transmission goodies today. the R154 I bought didnt have a clutch fork or support. so most of this is for the tranny stuff from drift motionI also just referenced all these part numbers with my local toyota dealer online parts site and the toyota dealer was quite a but cheaper. I'd say about 20% Edited November 5, 2013 by 87quest_stv Link to comment Share on other sites More sharing options...
19cturbo Posted November 5, 2013 Report Share Posted November 5, 2013 for the money on that clutch kit, id almost just go with the competition clutch stage 4.. me and BOHO both run it.. its a great clutch on those compressor wheels, id just save that money and start working towards a Single turbo setup.. you wont regret it.. i promise Link to comment Share on other sites More sharing options...
87quest_stv Posted November 5, 2013 Author Report Share Posted November 5, 2013 yea I looked into the clutch but for 500 bucks its just the clutch and pressure plate.. i still needed a flywheel as well.. or did the competition set up include a flywheel too? Link to comment Share on other sites More sharing options...
19cturbo Posted November 5, 2013 Report Share Posted November 5, 2013 i missed that, no the CC did not come with a flywheel.. sorry Link to comment Share on other sites More sharing options...
87quest_stv Posted November 5, 2013 Author Report Share Posted November 5, 2013 (edited) So I've got the clutch and flywheel stuff should be here Friday. Ordered the R154 bellhousing should be here next week sometime. SO once I get the steering linkages and ball joints replaced and the engine bay painted I'll be able to start the assembly and install.Also My wife just a our second baby last weds. so progress has been slow. But we'll get her done Edited November 5, 2013 by 87quest_stv Link to comment Share on other sites More sharing options...
