what are these parts. pics inside.
Ron Burgandy
CAR IS AN 89 FIJI AUTOMATIC. these are parts under the hood that i have no idea what they are or what and where they go. please help.
#1 what is the vacume thing and where do the two little hoses go?
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-36-44_485.jpg
#2 i believe these are my oil cooler lines
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-37-04_43.jpg
#3 This was cut and comes out of the firewall where and what does it go to?
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-37-20_253.jpg
#4 what is this and it has a line missing. whats missing and where does it go?
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-37-41_395.jpg
#5 idk what this is im guessing some sort of coolant line
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-37-55_898.jpg
#6 What is this. it is connected to the canister.
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-38-05_727.jpg
#7 this wire is snipped its connected to the little block on the right on the wheel well.
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-38-46_88.jpg
#8 these are connected to the fuse blocks. do they connect to the battery?
http://i1139.photobucket.com/albums/n543/spoolinfoolin/2012-02-15_11-39-11_148.jpg
Edited by Ron Burgandy
You need to number them so we can reference.
First is the purge valve for the charcoal canister and fuel tank vent for when your car goes upside down.
Second, yes.
Third, cruise control.
Fourth, brake line junction to the ABS.
Fifth and Sixth, fuel return and feed lines from the throttle body.
Seventh, I think its to the dash tach.
Ok so right now i have no ABS which idc anyway as long as the rest of the breaks work. I can remove the charcoal canister i wont need it. And the wires to the fuse blocks will be sorted out and addressed properly. This is how the po did the car before i got it.
When that charcoal canister is removed and the lines to that valve, you have to keep the vent line to the fuel tank open and that just lets moisture in. Cold fuel, hot fuel, moist air means a rusty tank. All that does is let the intake suck the fumes from the gas tank so the system stays closed and keeps the moisture out. Its a GOOD thing to KEEP it.
What if you just attach a valve directly to the line?
thats your abs line, not needed if your removing it, just run a line from the proportioning valve, the one your pointing at, to the master cylinder where that line connects to.
so it will just loop back through right? like a by pass?
