gabea101 Posted November 7, 2011 Report Share Posted November 7, 2011 I have an 87 Starion. I lost power to the power windows, seat belts(wont retract), heater, clock led time (but the orange light is still lite on it), and the beeper wont beep if I forget to take the keys out. Can you tell me what the problem could be? Link to comment Share on other sites More sharing options...
FLATBROKE313 Posted November 7, 2011 Report Share Posted November 7, 2011 (edited) Fusable links located between the battery and fender under that black cover,pull that and take a look. Edited November 7, 2011 by FLATBROKE313 Link to comment Share on other sites More sharing options...
Starfighterpilot Posted November 7, 2011 Report Share Posted November 7, 2011 Classic example of: Fusible links in Link Box 2 corroded; the electrical connector A-33/34 is melted; and/or your power wires, AWG 10 (white) and or AWG 12 (white with black tracer) going to and out of the A-33/34 connector are corroded and the wiring insulation on one or both of them is starting to melt. It could also VERY probably be your grounds are corroded and need to be cleaned and or the ground wires need to be replaced. See the following links: http://starquest.i-x...53a317a11b089a6 http://starquest.i-x...topic.php?t=916 And this link for what electrical problems I recently had which were caused by deteriorated (white & white with black tracer) power wires and pictures of what I found. http://starquest.i-x.net/viewtopic.php?t=3747 For What It's Worth. KEN Link to comment Share on other sites More sharing options...
gabea101 Posted November 7, 2011 Author Report Share Posted November 7, 2011 Thanks for the info guys. I will check this out. Link to comment Share on other sites More sharing options...
TexasQuest Posted November 7, 2011 Report Share Posted November 7, 2011 Check all your fuses too. Link to comment Share on other sites More sharing options...
Starfighterpilot Posted November 7, 2011 Report Share Posted November 7, 2011 Check all your fuses too. You are absolutely right. However you have to determine the cause of the fuse(s) blowing - be it old age or a fault in the circuits that the blown fuse was supply power to. For What It's Worth. KEN Link to comment Share on other sites More sharing options...
