gabea101
Everything posted by gabea101
  1. The turbo ebay link is for a 20g I think. You said look for a TD05H-16G right? Will any TD05H-16G work on ebay? Also will I need another downpipe to work with the diamond plate? Thanks for the info and links.
  2. Can anyone tell me a good bolt on Turbo upgrade for the 1987 starion and where to get it? It has the original turbo on it. Just looking for a little more HP without any modifications. Any links or phone numbers will be appreciated. Thanks
  3. ok. I thought it might be a drain. Is it ok to let it hang there at the bottom or do I need to try to find that nipple? Thanks
  4. Can someone tell me if the very bottom MAF hose gets connected to anything. If so can you tell me or show some pics of where it goes? thanks
  5. found a forum and they recommeded the vacuum advance. I bought a new one and replaced it and it still cuts out around the 3500 rpm (arounf 3 boost area). I still have to clean the distributor... Could it be the timing?
  6. I already replaces the injector clips to.
  7. I will get a new distributor and try that.
  8. My 87 has this revving problem almost everyday for about 5 minutes or so. Then it goes back to ideling and running ok. This video is what its doing. https://www.google.com/url?sa=t&source=web&cd=11&ved=0CCAQtwIwADgK&url=http%3A%2F%2Fm.youtube.com%2Fwatch%3Fv%3DGwBLXEuQtE8&rct=j&q=starion%20revving%20youtube&ei=wSeXU7b-DsqryASqkICgAQ&usg=AFQjCNGdR82erXERI8FAwQyzSzjX3Jy35g&sig2=BFCsFzwnQs5-Yhu0uBG8mg&bvm=bv.68445247,d.aWw
  9. What does this black bare wire go to? Can you tell me where to attach it?
  10. I will change the fuel filter this weekend and if that does not help...I will probably contact hurst....Thanks again
  11. recent...about 1 month. Another symptom is driving it and losing total power for about 1 sec then it kicks back in and then does it again with 1 sec intervals for about 20-30 secs....
  12. Update..drained all the fluid and replaced with new fluid and fixed the problem. Thanks for your replies.
  13. they are stock injectors....put the new clips on and its still sputtering...what else can I check?
