MattParanoia Posted October 12, 2011 Report Share Posted October 12, 2011 So I just bought a conquest, overall a decent car. But when I give it full throttle the car just bogs down about to stall then putts itself back up to 1k, but no higher. I have no idea what the problem is, at first it sounded like it was misfiring so I went and got new plugs and wires since #2 cylinder wasn't sparking. Plugs were burnt to a crisp, and wires were shot. Now shes running better, but still bogs down at full throttle. (Also the boost gauge doesn't go above 0 until its at high throttle when it starts to bog. Don't know if this has anything to do with it.) ~ThanksMatt Quote Link to comment Share on other sites More sharing options...
lionbull Posted October 12, 2011 Report Share Posted October 12, 2011 did you observe what rpm it does it at? could be vacuum advance. Quote Link to comment Share on other sites More sharing options...
JAinsworth Posted October 12, 2011 Report Share Posted October 12, 2011 It sounds like your secondary injector is not functioning. Can you rev above 3k if you slowly push the gas pedal down? Around 3k or 1/2 throttle the secondary kicks in. If it doesn't work then you get too much air for the amount of fuel you are putting into the throttlebody which causes the engine to fall flat on its face. If you haven't do so, check the injector clip and prongs on the injector to ensure they are clean and shiny (the secondary is the blue/green inj). Quote Link to comment Share on other sites More sharing options...
MattParanoia Posted October 12, 2011 Author Report Share Posted October 12, 2011 Well neither of my injector clips are clipping on... I ordered new ones, just waiting for them (should be here tomorrow). I can get it all the way up to redline sometimes, but usually not more than once or twice. I guess the clip could be coming loose. I can't wait to get this car running. Quote Link to comment Share on other sites More sharing options...
JAinsworth Posted October 12, 2011 Report Share Posted October 12, 2011 Have you tried holding the clips in by hand and revving the engine from under the hood? Quote Link to comment Share on other sites More sharing options...
MattParanoia Posted October 12, 2011 Author Report Share Posted October 12, 2011 Yeah I did, unplugged the secondary only revved to 3k. Plugged it back in and I could get it up to 5k, but if I hold down all the way starts to cut out still. Quote Link to comment Share on other sites More sharing options...
DSMvirus1 Posted October 12, 2011 Report Share Posted October 12, 2011 bad maf? Quote Link to comment Share on other sites More sharing options...
FRO Posted October 12, 2011 Report Share Posted October 12, 2011 Check the fuel system. All filters and screens from the tank to the TB. Also the pump could be weak Quote Link to comment Share on other sites More sharing options...
MattParanoia Posted October 13, 2011 Author Report Share Posted October 13, 2011 @DSM Ordered one of those with the clips, and a thermostat so just waiting on shipping. @FRO Yeah thats what we have been thinking. Fuel pump is new, but it whines like crazy. It is supposed to be mounted under the tank, but the previous owner mounted it on top of the tank. He said the front filter was changed. Its some "Trickster EFI Fuel pump" I saw that and thought it was weird, He also ran a seperate wire from the battery terminal straight back to the pump. And the car always smells like gas fumes. Quote Link to comment Share on other sites More sharing options...
JAinsworth Posted October 13, 2011 Report Share Posted October 13, 2011 Fuel pump is mounted on top of the tank OEM. Don't know where you got your info about it being located under the tank. I would suggest you spend more time on the the FSM than posting here.Jimmy Quote Link to comment Share on other sites More sharing options...
MattParanoia Posted October 13, 2011 Author Report Share Posted October 13, 2011 I was going off of what the installation instructions for the pump say, I did read that section. I know OEM is above tank, but I wasn't sure since I don't know if that pump is correct. Quote Link to comment Share on other sites More sharing options...
