spoolinup Posted July 5, 2011 Report Share Posted July 5, 2011 motor just put it finally running and timmed will idle smooth for about 10 secs then rough for like 3 but then idles smooth and idk if it is my tps or isc or what could it be Link to comment Share on other sites More sharing options...
techboy Posted July 5, 2011 Report Share Posted July 5, 2011 motor just put it finally running and timmed will idle smooth for about 10 secs then rough for like 3 but then idles smooth and idk if it is my tps or isc or what could it be Go to the FAQ section and print out a copy of how to do the TPS/ISC reset procedure. Grab your voltmeter and give that a shot. High likelihood that will solve your problem. Link to comment Share on other sites More sharing options...
Shelby Posted July 5, 2011 Report Share Posted July 5, 2011 when you guys read the mps,tps adj thread read the entire thread not just the first part Link to comment Share on other sites More sharing options...
Indiana Posted July 5, 2011 Report Share Posted July 5, 2011 If you didn't take the throttlebody apart and it ran before then likely you just put the throttle cable back on and its too tight. The cable has to be sloppy loose at idle so you can make sure that contact tip switch gets mashed closed that's on the end of the idle motor. I've also seen the arm bent but someone has to have done that on purpose and it might prevent it from mashing that switch closed even with the cable off. Did you plug the MAF in? Are your intercooler hoses all connected? Link to comment Share on other sites More sharing options...
spoolinup Posted July 5, 2011 Author Report Share Posted July 5, 2011 i rebuilt the tb so im guessing one of the sesnsors is off Link to comment Share on other sites More sharing options...
