Everything posted by spoolinup
pm'd
how do you bleed the lifters?? okay will do then repost thanks
need good shape oil pick up or any good tips how to clean mine air, brakekleen???
rebuilt the motor had it re machined and the cylinders honed the block cleaned used a set of good stock pistons. brand new rings, all bearings and the head was all rebuilt by a local good machine shop. the motor ran and everything timing is dead nuts on. was reading no oil pressure on the gauge but oil was coming out of the lifters when i first started with the valve cover off to make sure there was good oil flow. the pick up could have plugged and the oil not got to the rings and seated. well now the motor cranks and has low comp in all 4 cylinders about 40-50psi. but the motor did run before could the rings just not be seated good enough to have the motor run. i rebuilt a old oil pump to fix the problem which i thought it was. haven't put in the car yet just got it towed home from work. any ideas tips or things to check. thanks appreciate it. has fuel and spark. email, pm call or txt me i need help asap. 3607914859 zack
is it a 1to1 reg?
like all the others broken. need new one help me out.
what oil should i use durig break in regular 1030 full synth?? whats best
what oil should i use aka should i put some in the head before start up how long should i run it for. how long should i not get on the new motor hard. what rpms should i stay under for a while. how long till i do a oil change after first start up. any tips for breaking new motor in thanks.
do you hve the link for the cosmos
need lowering spring dont wanna chop the stock ones
clutch is s*** need either just the disk or clutch and pressure plate also looking for flywheel let me know
either new or used but in good condition let me know
looking for pretty much something i can just bolt up to my turbo comes with cone filter all the right plugs and evreything let meknwo what you have
where is the sending unit
my oil level is good on the stick but my oil pressure is below half mark could my pick up be a little clogged and also with the stock injetcors black and green which one is primary and secondayr and which one goes where i rebuilt my tb and forgot
i mean i have 3 stock heads one a jet and 2 non jests should i just ditch the caravan head
i think my motor came with the caravan head on it and sometimes at cold start for a sec i get this annoying fast tick noise sounds like a sensor is almost stuck or the starter stick but it comes out of my valve cover does the caravan head have more lift from the lifters so i would have to trim my valve cover?? need help
i rebuilt the tb so im guessing one of the sesnsors is off
motor just put it finally running and timmed will idle smooth for about 10 secs then rough for like 3 but then idles smooth and idk if it is my tps or isc or what could it be
non cracked of course stress relieved or not let me know thanks need one asap
sorry dude about replying been trying to get my motor running if you still want the head i am takin pics for you tomorrow
