JoshC Posted March 22, 2011 Report Share Posted March 22, 2011 What psi can you boost on a stock setup? Link to comment Share on other sites More sharing options...
foolish_child Posted March 22, 2011 Report Share Posted March 22, 2011 I have mine pushing 15 lbs, and my buddy has his set at 15 also we have no problems. Link to comment Share on other sites More sharing options...
JAinsworth Posted March 22, 2011 Report Share Posted March 22, 2011 If you plan to bump the boost up, make sure you get an aftermarket boost guage. The factory isn't accurate much above stock. Link to comment Share on other sites More sharing options...
Terminated Posted March 22, 2011 Report Share Posted March 22, 2011 it depends on what you mean by stock. If you mean a completely stock car with a boost controller. Then you really shouldnt mess with the boost. You need alot more than just a boost controller to run higher boost safely. Consult the newbie checklist in the faqs section. iirc it has a series of checklists that you should study before upping the boost. In order to do it safely, you will probably need an upgraded MAS, as well as an upgraded fuel pump. You will probably need some larger injectors(depending on desired boost) and an adjustable FPR. And all of that is just to ensure your readings for the increased airflow stay accurate and you flow enough fuel to not run lean and blow your motor. Once youre sure your fuel and air systems can take it. I believe the highest boost level that you can run with a 12a and still be efficient is around 12psi Like i said, read through that newbie checklist and then read it again Link to comment Share on other sites More sharing options...
JoshC Posted March 22, 2011 Author Report Share Posted March 22, 2011 ok thanks i should be good then Link to comment Share on other sites More sharing options...
Terminated Posted March 22, 2011 Report Share Posted March 22, 2011 and to go along with jainsworth, get a wideband a/f gauge along with a good boost gauge Link to comment Share on other sites More sharing options...
The Rabbit1 Posted March 23, 2011 Report Share Posted March 23, 2011 the highest the 12a will go efficiently is 15lbs. and it can do it on stock fuel and air systems. but if anything is questionable, and you push a car that isn't running 100%.. you may blow your engine. Stock fuel pump and injectors are more than enough for anything the 12a can throw at it. again, it is ill advised to go over 15psi on the stock 12a turbo. Link to comment Share on other sites More sharing options...
Caliber308 Posted March 23, 2011 Report Share Posted March 23, 2011 (edited) A word of caution. The higher you boost a Stock Turbo above recommended boost levels from the factory (10 psi.) The shorter the lifespan will be on it.And Turbos aren't cheap. Bill Edited March 23, 2011 by Caliber308 Link to comment Share on other sites More sharing options...
