JayR_NYC Posted August 22, 2010 Report Share Posted August 22, 2010 where and how do i dis-connect the factory aLarm...its driving crazy cuz i cant dis-arm it with my key switch Link to comment Share on other sites More sharing options...
vbrad511 Posted August 22, 2010 Report Share Posted August 22, 2010 Both of your doors and your hatch have "reed switches" which cancel the alarm. They're "c" shaped white plastic jobbers that sometimes come off, especially if you've ever used a slim jim to get the car open. Pull the door panel(s) and look around the lock cylinder. It should be obvious. Link to comment Share on other sites More sharing options...
Indiana Posted August 23, 2010 Report Share Posted August 23, 2010 Unplug the horn for it there are two and the alarm horn is separate from the cars horn. The alarm horn is that one by the air cleaner. at least I'm 99% sure it is Link to comment Share on other sites More sharing options...
JayR_NYC Posted August 23, 2010 Author Report Share Posted August 23, 2010 Unplug the horn for it there are two and the alarm horn is separate from the cars horn. The alarm horn is that one by the air cleaner. at least I'm 99% sure it isthe crazy thing is that ripped the wires off cuz i was so mad that the s*** didnt want 2 turn off...i know bout the door lock dis arming the alarm...i did that and nothing...and yesterday after work it did it again...so i unplugged the battery...but i heard that theres a relay 2 unplug 4 the alarm Link to comment Share on other sites More sharing options...
Caliber308 Posted August 24, 2010 Report Share Posted August 24, 2010 (edited) the crazy thing is that ripped the wires off cuz i was so mad that the s*** didnt want 2 turn off...i know bout the door lock dis arming the alarm...i did that and nothing...and yesterday after work it did it again...so i unplugged the battery...but i heard that theres a relay 2 unplug 4 the alarm The only way I know to shut the alarm off and still be able to start the car is by inserting the door key to disarm it. To try and disable it completely involves a whole lot of disconnecting of wires. It's all in the Starquest Factory Service Manual Volume no.2. If you want to attempt to do all this...Good Luck. Myself,I will continue to use my Ignition key to disarm it. I checked, the Alarm system is connected to the ECU and ETACS and there is no "one wire" to disconnect it. It is a series of wires that go to the Door locks, Rear hatch,Hood,Lights,Horn and Ignition. If you can figure it out, your a better man than I. CALIBER 308 Edited August 24, 2010 by Caliber308 Link to comment Share on other sites More sharing options...
DieHARDmitsu. Posted August 24, 2010 Report Share Posted August 24, 2010 I had a similar problem last year on My 89 Quest. There is little sensor under the hood, above the coolant overflow bottle area that was the culprit. It's housed in a rubber sleeve. I simply unpluged it and the problem stopped . Link to comment Share on other sites More sharing options...
Caliber308 Posted August 24, 2010 Report Share Posted August 24, 2010 I had a similar problem last year on My 89 Quest. There is little sensor under the hood, above the coolant overflow bottle area that was the culprit. It's housed in a rubber sleeve. I simply unpluged it and the problem stopped . That is the Hood Switch. I guess it could be a stuck open circuit and that is what is causing his problem??? CALIBER 308 Link to comment Share on other sites More sharing options...
JayR_NYC Posted August 24, 2010 Author Report Share Posted August 24, 2010 I had a similar problem last year on My 89 Quest. There is little sensor under the hood, above the coolant overflow bottle area that was the culprit. It's housed in a rubber sleeve. I simply unpluged it and the problem stopped . can u get a pic so i could see what ur talking bout...please Link to comment Share on other sites More sharing options...
DieHARDmitsu. Posted August 24, 2010 Report Share Posted August 24, 2010 (edited) here is a pic of a starion I found on the net. Arrows point to the sensor. http://yfrog.com/jwrefrencepicj Edited August 24, 2010 by DieHARDmitsu. Link to comment Share on other sites More sharing options...
VICE Posted August 29, 2010 Report Share Posted August 29, 2010 I had a smililar problem a few years ago, I had an aftermarket alarm installed and the stock anti theft alarm kept going off every time the passenger door was opened.. I disconnected the horn but the headlights would pop up and lights would blink still, I cut the hood switch and trunk switch wires and it would still do it sometimes when I opened them. SOMEBODY herre told me to CUT a certain wire in the ETACS unit under the driver seat and since then, the anti theft has not bugged me ever again.. Link to comment Share on other sites More sharing options...
