marty Posted August 13, 2010 Report Share Posted August 13, 2010 i have this rattling in my drivetrain which i believe to be a balance shaft going out; i have the kit, which contains very, very basic instructions, 1 sheet; after looking at my car, i did show it to a foreign car mechanic in town, who suggested i "just drive it until it blows" (he was serious)! mechanic wise on a scale of 1 to 5, i give myself a solid 3, i did a head gasket replacement with little difficulty years ago on a previous conquest, so my question; can the engine even stay in the car? Any special tools needed? sorry so wordy, it just looks a little intimidating, thanks for any replies Link to comment Share on other sites More sharing options...
cyberquest Posted August 13, 2010 Report Share Posted August 13, 2010 its a pretty easy thing. doing it in car could be done but your gonna have to take the radiator and stuff out of your way. Link to comment Share on other sites More sharing options...
Starfighterpilot Posted August 13, 2010 Report Share Posted August 13, 2010 (edited) I did it in my drive way about 5 years ago. It took me two days cuz I took my time and made sure everything was right. And I replaced the rod bearings then cuz I had the oil pan down and wanted to look at 'em but I did not need to. I had "the just in case" replacement bearings in hand, so WTH took plasti guage readings & replaced 'em. One less thing to be concerned about later on. I would suggest that you look at the below post which details what is involved in doing the BSE and you make up your own mind. I know that I used PQ's link to make sure that I did the BSE correctly. http://starquest.i-x.net/viewtopic.php?t=944&sid=7157e75594c45aaa11a9d4985aeeb2fc It's fairly straight forward and easy. Just be sure the engine is in time when you button 'er up. For What It's Worth. KEN Edited August 13, 2010 by Starfighterpilot Link to comment Share on other sites More sharing options...
cyberquest Posted August 13, 2010 Report Share Posted August 13, 2010 here is a pic of one i did in car a couple years ago. http://i37.photobucket.com/albums/e82/silverquest/Quest%20Pics/quest098.jpg this topic should help walk you thru doing the BSE.http://starquest.i-x.net/viewtopic.php?t=944 Link to comment Share on other sites More sharing options...
Technology Posted August 13, 2010 Report Share Posted August 13, 2010 On a scale of 1 to 5, it would be a 5. Out of 10, it would be a 9. Don't dive into the job with a fistfull of hope and some basic tools. Just read the service manual, look up an FAQ about it and ask questions if you have them. Give yourself two full days. Link to comment Share on other sites More sharing options...
vbrad511 Posted August 13, 2010 Report Share Posted August 13, 2010 I'm with Ken (starfighterpilot) on this. Follow the step by step on the IX link he posted and allow yourself 2 days if you've never done it before. The hardest part of the whole thing for me was scraping the 20+ year old oil pan gasket off the bottom of the block. I think it'd petrified on there. And the pan DOES need to come down to be able to get the oil pump and it's pickup off correctly. You'll be amazed at the pile of muck in the pan once you get it off. Also make sure to use a new OEM oring on the pickup when it goes back together. The aftermarket ones tend to not seal right. Everything else is pretty simple, just takes time and attention to detail. If you handled the head gasket you should be able to make this happen. Oh yeah, radiator out just to give a little more room, and engine doesn't have to come out. Link to comment Share on other sites More sharing options...
marty Posted August 13, 2010 Author Report Share Posted August 13, 2010 thanks for all the replies, i will look over the posts thoroughly Link to comment Share on other sites More sharing options...
dmyers151 Posted August 14, 2010 Report Share Posted August 14, 2010 I did mine in my driveway. Took me a week of nights after work. Link to comment Share on other sites More sharing options...
Indiana Posted August 14, 2010 Report Share Posted August 14, 2010 All that chewed up metal chewed up the other bearings, you have it torn down you need to do it right and replace the rod and main bearings at the same time. You should remove and flush out the oil cooler and you need new timing components you can't just put in a BSEK and think that this old tired motor will continue to run but only a few more miles then its going to need major work after its all chewed up inside. That BSEK should have only been able to be purchased with a full rebuild kit it has caused most of these engines to be just shortly after destroyed. Link to comment Share on other sites More sharing options...
marty Posted October 15, 2010 Author Report Share Posted October 15, 2010 I got around to installing the BSEK kit, & did a jet valve elimination while i was at it. the information you guys gave me was invaluable, thanks so much. & now, the aftermath: good news, & not so good. the noise is gone, that appears to have been the source of it; oil pressure is very high, that was another of my worries; a slight antifreeze leak, i'm hoping it is just a clamp i have to retighten, i have not yet located it; but upon driving the car, it backfires like a mother! it keeps blowing off intercooler hoses, & will not stay running. I tried to be meticulous upon re-assembly, but something is not right. suggestions? thanks again guys Link to comment Share on other sites More sharing options...
87Black_Stallion Posted October 16, 2010 Report Share Posted October 16, 2010 All that chewed up metal chewed up the other bearings, you have it torn down you need to do it right and replace the rod and main bearings at the same time. You should remove and flush out the oil cooler and you need new timing components you can't just put in a BSEK and think that this old tired motor will continue to run but only a few more miles then its going to need major work after its all chewed up inside. That BSEK should have only been able to be purchased with a full rebuild kit it has caused most of these engines to be just shortly after destroyed.Isn't necessary! Reason why there are oil filters on the car. Link to comment Share on other sites More sharing options...
Indiana Posted October 16, 2010 Report Share Posted October 16, 2010 Isn't necessary! Reason why there are oil filters on the car. No, there is no oil filter that filters 100% of your oil 100% of the time. Oil is only filtered PARTIALLY and when there is crap from guides and chewed up bearing material it free flows everywhere over and over. Why would someone need to do a BSEK unless the bearings were ate up? Takes a long time usually for that to happen and the pan was off so why not spend another hour and 50 more dollars to get it over with? All oil filters have a bypass valves, some of those open up at very low pressures if not they would explode. Cold oil, thick oil, high rpms all just have the valve open all the time only filtering a little bit of the oil. The point is to have clean oil and that's why its changed frequently. You can't filter out what passes through the bypass valve. If the filter caught all the crap then no motors would ever be worn out would they? Be nice if that were true. So many times this same thing has happened and seems like the noise is gone, comes back worse a little bit later. You know, after you decide to drive the crap out of that tired old pos motor that had the crap pumped through it. Its also in the oil cooler laying in the bottom just waiting to flow out on a hot day at high rpms. Then you get to rebuild the entire thing and it eats up the head too and might even kill your turbo. Isn't that worth spending that extra time and money on? Link to comment Share on other sites More sharing options...
Skullzaflare Posted October 16, 2010 Report Share Posted October 16, 2010 I got around to installing the BSEK kit, & did a jet valve elimination while i was at it. the information you guys gave me was invaluable, thanks so much. & now, the aftermath: good news, & not so good. the noise is gone, that appears to have been the source of it; oil pressure is very high, that was another of my worries; a slight antifreeze leak, i'm hoping it is just a clamp i have to retighten, i have not yet located it; but upon driving the car, it backfires like a mother! it keeps blowing off intercooler hoses, & will not stay running. I tried to be meticulous upon re-assembly, but something is not right. suggestions? thanks again guysdid you hook the wastegate actuator back up? sounds like your overboosting oil pressure is suppose to be higher with bsek check the rubber hose that connects the metal line at the back of the water pump Link to comment Share on other sites More sharing options...
