spooky1 Posted June 26, 2010 Report Share Posted June 26, 2010 I just installed my new vac advance on my car.I timed the engine to 10 before top dead center.Took he car own the road and it ran ok.I noticed though when i had the hood popped and was reving the engine about 1/2 throttle it started spark knockng.Sounded like a friggin diesel truck.When i pulled the vac advance hose off it went away.What am i doing wrong? It has new accel wires,msd blaster 2 coil,new cap,new rotor.Its running a small 16g with non jet head,225 walbro,and fuel pressure at 38-40lbs.The motor has less than 1000 miles on it. Link to comment Share on other sites More sharing options...
Indiana Posted June 26, 2010 Report Share Posted June 26, 2010 Was it fully warmed up when you timed it? Sure you had the right mark on the crank pulley and not a scratch or nick?Sure you used the #1 plug wire? I'd check that timing again, don't drive it like that. Link to comment Share on other sites More sharing options...
spooky1 Posted June 26, 2010 Author Report Share Posted June 26, 2010 I just checked it again waiting till the car was completely warmed up.When i checked it it was not at 10 but clser to top dead so i reset it.When i rev up the car it revs nice with no sounds. Its oly when i slowely rev up the car that it gets to a knock sound.Timing mark on the crank is correct because i used a metallic silver pen to higligt the notch,The tester was on the #1 wire. Dont know what else to do.When the advance is unhooked theres no noise when sowely reving so its def in te timing. Link to comment Share on other sites More sharing options...
TainterRacing Posted June 26, 2010 Report Share Posted June 26, 2010 Rev the motor and have the timming gun on and watch and see what the timming is at. Link to comment Share on other sites More sharing options...
Starwolf Posted June 26, 2010 Report Share Posted June 26, 2010 idk if it could be this...but the grease inside the distributors gets pretty bad after 20 years if it hasnt been done already. I would take the cap and rotor off and check to see if the weights are still moving freely. Again im not very smart with the whole timing bit...but i know i had problems with this in my car recently. Link to comment Share on other sites More sharing options...
Shelby Posted June 27, 2010 Report Share Posted June 27, 2010 (edited) check to make sure the vac signal hose is on the 1st of the 3 in a row vac ports and that is is not seeing any vac at idle Edited June 27, 2010 by Shelby Link to comment Share on other sites More sharing options...
