OPTIMUSPRIME Posted June 16, 2010 Report Share Posted June 16, 2010 (edited) I seen this done before... Please share your information.Contemplating on upgrading this way. How is the idle? Full Throttle? 1G,2G or 3G MAF?My intentions were to run a 14G and leave everything alone but, I have a itch and plan to run a 18G if I can set 2 Secondary Injectors (88-89)want to keep the engine "FACTORY LOOK"Ok, whats the formula? OK, GM MAF AND MAF-T, WHAT INJECTOR SIZE ARE YOU RUNNING/BOOST? YOUR THOUGHTS? Edited June 17, 2010 by OPTIMUSPRIME Link to comment Share on other sites More sharing options...
BrazilBoy Posted June 16, 2010 Report Share Posted June 16, 2010 I did that back in 95 with my old 87 with a 1g..Didn't work out so hot bad low end and unless your running 20psi+ it ain't worth it.. Plus your looking to install 20+ injectors...Get a new set and call it done.. Contact Brian at lowershores performance to get a bigger secondary and slighty bigger primary.. Send your mod list too so he can help you out.. Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 16, 2010 Author Report Share Posted June 16, 2010 http://memimage.cardomain.com/ride_images/1/2609/2701/6521350046_large.jpgcame across this...MAF-Translator + 3" GM Airmas and 2 Secondary Injectors Link to comment Share on other sites More sharing options...
BrazilBoy Posted June 16, 2010 Report Share Posted June 16, 2010 I did that back in 95 with my old 87 with a 1g..Didn't work out so hot bad low end and unless your running 20psi+ it ain't worth it.. Plus your looking to install 20+ yr old injectors...Get a new set and call it done..Contact Brian at lowershores performance to get a bigger secondary and slighty bigger primary.. Send your mod list too so he can help you out.. Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 16, 2010 Author Report Share Posted June 16, 2010 OK, I GOT IT I just reply to the Delphi/Bosh injector set up on his TREAD. Looks like the 850/1400 is the right combo im just not sure what else is involve for the Injectors to work properly with the STOCK MAS. What is this 3" GM MAF, ANYWAYS? Link to comment Share on other sites More sharing options...
BrazilBoy Posted June 16, 2010 Report Share Posted June 16, 2010 OK, I GOT IT http://www.starquestclub.com/forum/public/style_emoticons/default/laugh.gif I just reply to the Delphi/Bosh injector set up on his TREAD. Looks like the 850/1400 is the right combo im just not sure what else is involve for the Injectors to work properly with the STOCK MAS. What is this 3" GM MAF, ANYWAYS? A GM 3" mas used with a MAF-T or dsm transaltor.. It replaces the stock mas and will flow crazy good... You can find them for about 250 -350 depending on which one you get... Link to comment Share on other sites More sharing options...
StarquestRescue Posted June 17, 2010 Report Share Posted June 17, 2010 I have run 2 secondary but do not recommend it do to tuning issues. Basically is screws up the size ratio between the injectors. On two secondary when the car transition from the primary to both injectors the afr will go about 1.5 to 2 points leaner right after the transition. I addressed the problem by setting my afc throttle points at 20% for low and 32% for high. The low setting being my primary injector tune and the high being my both injector tune. This worked to a point but i still had to drive around the problem area, or boost through it. Most put up with a pig rich tune when on just the primary. I had it tuned great on both sides of the problem area. I like the 2g mas, but it is big and ugly and barely fits. A maft is another option. I have not used one yet. The stock oem mitsu injectors can support up to 240 hp. Stick with them as long as you can. I found larger injectors are actually harder to tune. The 2g would require a safc 2 or newer. An afc neo should be re flashed to v1.104 A wide band and some tuning would be required.I would recommend a afc2 or newer with a maft as well The stock mas quickly becomes a problem on these cars if you want to push the limits of the stock injectors. The 1g is better, but still a problem and tends to run richer at points which adds more problems. http://sqperformance.forumcity.com/viewtopic.php?t=108 Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 17, 2010 Author Report Share Posted June 17, 2010 A GM 3" mas used with a MAF-T or dsm transaltor.. It replaces the stock mas and will flow crazy good... You can find them for about 250 -350 depending on which one you get...ok, so How do I search for the GM MAS 3"?Is their a part number? Does it come from a particular car? ok, where can I get it?And it has to be used with a MAF-T or DSM translator? wich one? Dont leave me hanging here....... Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 17, 2010 Author Report Share Posted June 17, 2010 (edited) I have run 2 secondary but do not recommend it do to tuning issues. Basically is screws up the size ratio between the injectors. On two secondary when the car transition from the primary to both injectors the afr will go about 1.5 to 2 points leaner right after the transition. I addressed the problem by setting my afc throttle points at 20% for low and 32% for high. The low setting being my primary injector tune and the high being my both injector tune. This worked to a point but i still had to drive around the problem area, or boost through it. Most put up with a pig rich tune when on just the primary. I had it tuned great on both sides of the problem area. I like the 2g mas, but it is big and ugly and barely fits. A maft is another option. I have not used one yet. The stock oem mitsu injectors can support up to 240 hp. Stick with them as long as you can. I found larger injectors are actually harder to tune. The 2g would require a safc 2 or newer. An afc neo should be re flashed to v1.104 A wide band and some tuning would be required.I would recommend a afc2 or newer with a maft as well The stock mas quickly becomes a problem on these cars if you want to push the limits of the stock injectors. The 1g is better, but still a problem and tends to run richer at points which adds more problems. http://sqperformance.forumcity.com/viewtopic.php?t=108My plans are to have bigger injectors/upgraded MAF and a 18G TurboI dont want to run the 18G with OEM injectors and STOCK MAF. I was reading in one of your post and make sence of the 850/1400cc set up and just want to be clear on what I would need to run them with out issues. ******UPDATE****Ok, just founf out you are testing the 850/1400 (delphi/Bosh) injectors....I feel breaking news coming! Edited June 17, 2010 by OPTIMUSPRIME Link to comment Share on other sites More sharing options...
Hoosierquest Posted June 17, 2010 Report Share Posted June 17, 2010 ok, so How do I search for the GM MAS 3"?Is their a part number? Does it come from a particular car? ok, where can I get it?And it has to be used with a MAF-T or DSM translator? wich one? Dont leave me hanging here....... http://cgi.ebay.com/ebaymotors/1G-DSM-Maf-Translator-3-GM-Maf-sensor-/150454337085?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item2307c6fe3d here is a start. Yes, you have to get a DSM 1gen eclipse Maf-Translator (Maf-T) then you can run that with a GM style 3 inch MAF sensor. This will give you some tunability. Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 17, 2010 Author Report Share Posted June 17, 2010 http://cgi.ebay.com/ebaymotors/1G-DSM-Maf-Translator-3-GM-Maf-sensor-/150454337085?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item2307c6fe3d here is a start. Yes, you have to get a DSM 1gen eclipse Maf-Translator (Maf-T) then you can run that with a GM style 3 inch MAF sensor. This will give you some tunability.OK, NOW WE ARE GETTING SOMEWHERE... Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 17, 2010 Author Report Share Posted June 17, 2010 (edited) OK....SO I CAN KEEP THE OEM INJECTORS IF I GET THE GM MAF AND THE MAF-T AND WORK ?AND IF I BUY LARGER INJECTORS (850CC/1400CC) I SHOULD BE ABLE TO TUNE IT WITH THE MAF-T, CORRECT?I SHOULD BE ABLE TO TUNE WITH THE MAF-T EITHER WAY, STOCK INJECTORS OR UPGRADED INJECTORS, CORRECT? Edited June 17, 2010 by OPTIMUSPRIME Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted June 17, 2010 Author Report Share Posted June 17, 2010 Ok, I found where to get the sensor from.... here it is.2003 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J 2003 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J 2003 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E 2003 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = X 2003 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E 2003 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J 2003 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J 2003 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E 2003 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = X 2003 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X 2003 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E 2003 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = X 2003 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E 2003 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E 2003 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E 2003 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E 2003 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E 2003 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E 2002 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J 2002 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J 2002 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E 2002 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E 2002 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J 2002 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J 2002 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W 2002 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W 2002 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E 2002 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W 2002 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E 2002 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H 2002 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H 2002 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E 2002 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E 2002 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E 2002 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E 2002 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J 2002 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E 2001 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J 2001 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J 2001 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W 2001 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E 2001 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J 2001 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J 2001 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J 2001 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E 2001 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W 2001 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W 2001 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W 2001 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W 2001 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W 2001 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W 2001 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W 2001 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E 2001 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H 2001 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W 2001 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H 2001 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E 2001 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E 2001 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E 2001 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E 2001 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J 2001 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E 2000 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J 2000 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J 2000 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W 2000 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E 2000 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J 2000 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J 2000 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J 2000 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E 2000 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W 2000 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W 2000 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E 2000 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W 2000 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W 2000 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W 2000 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W 2000 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E 2000 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W 2000 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H 2000 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E 2000 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E 2000 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J 2000 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E 1999 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M 1999 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M 1999 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W 1999 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = M 1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J 1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = M 1999 CHEVROLET MONTE CARLO V6 3.1L 189cid GAS FI N Engine VIN = M 1999 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W 1999 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W 1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W 1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X 1999 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E 1999 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W 1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W 1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = X 1999 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W 1999 OLDSMOBILE ALERO V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1999 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W 1999 OLDSMOBILE CUTLASS V6 3.1L 189cid GAS FI N Engine VIN = M 1999 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H 1999 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E 1999 PONTIAC GRAND AM V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1999 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = M 1999 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E 1998 BUICK CENTURY CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 BUICK CENTURY LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 BUICK SKYLARK V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 CHEVROLET LUMINA LTZ V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X 1998 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W 1998 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X 1998 GMC SAFARI V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 OLDSMOBILE ACHIEVA V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 OLDSMOBILE BRAVADA REGIONAL V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1998 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1998 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 PONTIAC GRAND AM V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 PONTIAC GRAND PRIX V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1998 PONTIAC TRANS SPORT MONTANA V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1998 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1997 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M 1997 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M 1997 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1997 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 CHEVROLET LUMINA LTZ V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1997 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1997 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1997 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1997 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X 1997 CHEVROLET VENTURE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1997 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1997 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1997 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X 1997 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1997 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1997 OLDSMOBILE CUTLASS GLS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1997 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1997 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M 1996 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1996 BUICK ROADMASTER LIMITED WAGON V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1996 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1996 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1996 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1996 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1996 CHEVROLET BERETTA Z26 V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 CHEVROLET BERETTA V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1996 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W 1996 CHEVROLET CORSICA V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1996 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1996 CHEVROLET LUMINA APV V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1996 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1996 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1996 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X 1996 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1996 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1996 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X 1996 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1996 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W 1996 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1996 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1996 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1996 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1996 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1996 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E 1995 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1995 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M 1995 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1995 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1995 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1995 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1995 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1995 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W 1995 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1995 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1995 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1995 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1995 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1995 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1995 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1995 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1995 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1995 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1995 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1995 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1995 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1994 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1994 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1994 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1994 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1994 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1994 CHEVROLET CAPRICE LS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1994 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W 1994 CHEVROLET CAPRICE CLASSIC LS V8 4.3L 265cid GAS FI N Engine VIN = W 1994 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P 1994 CHEVROLET LUMINA EURO V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1994 OLDSMOBILE CUTLASS CIERA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1994 OLDSMOBILE CUTLASS SUPREME S V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1994 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M 1994 OLDSMOBILE CUTLASS SUPREME S V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1994 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1994 PONTIAC GRAND PRIX SE V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X 1994 PONTIAC GRAND PRIX SE V6 3.1L 189cid GAS FI N Engine VIN = M Link to comment Share on other sites More sharing options...
TexasQuest Posted June 17, 2010 Report Share Posted June 17, 2010 OK....SO I CAN KEEP THE OEM INJECTORS IF I GET THE GM MAF AND THE MAF-T AND WORK ?AND IF I BUY LARGER INJECTORS (850CC/1400CC) I SHOULD BE ABLE TO TUNE IT WITH THE MAF-T, CORRECT?I SHOULD BE ABLE TO TUNE WITH THE MAF-T EITHER WAY, STOCK INJECTORS OR UPGRADED INJECTORS, CORRECT?Yes Link to comment Share on other sites More sharing options...
