importwarrior Posted May 7, 2010 Report Share Posted May 7, 2010 (edited) with all the other types of cars out there, could there be other strut inserts that could easily fitin to our strut assemblies?i see a ton of inserts out there. are we only limited to the MR2as far as dimensions? pro's? cons? strut inserts a plenty click me!!! on a side note this post seems interesting, dont know if something like this could work for our cars. modified nissan strut koni insert Edited May 7, 2010 by importwarrior Link to comment Share on other sites More sharing options...
BrazilBoy Posted May 7, 2010 Report Share Posted May 7, 2010 http://www.google.com/products?q=strut+insert+starion&hl=en&aq=f Link to comment Share on other sites More sharing options...
Dave-O Posted May 9, 2010 Report Share Posted May 9, 2010 How much you wanna bet any of those struts for the Starion/Conquest is either "out of stock" or the wrong part? Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 9, 2010 Report Share Posted May 9, 2010 they are correct and probably in stock but they are only the fronts. Link to comment Share on other sites More sharing options...
Komeuppance Posted May 9, 2010 Report Share Posted May 9, 2010 Alright, I got some measurments of similar struts... Illumina BZ1093 85-90 VW GTi Front Insert TH=13.062, TW=1.660, CH=14.625 EH=21.375 Illumina BZ3126 90-95 MR2 Rear Insert TH=13.938, TW=1.705, CH=14.438 EH=21.563 Illumina BZ1085 87-89 MR2 Rear Insert TH=14.75 Illumina BZ4005 84-89 300zx Front Insert TH=13.75, EH=23.00 Measurement Abreviations: TH=Insert Tube Height TW= Tube Width CH=Compressed Height from bottom of tube to top of polished area of rod EH=Extended Height from bottom of tube to top of polished area of rod (height above polished area is not measured) -Robert Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 10, 2010 Report Share Posted May 10, 2010 ok... probably been asked... how about modifying the rear housings to accept a front insert? im guessing the fronts are a longer than the depth of the rear shp housings? Link to comment Share on other sites More sharing options...
v8starion Posted May 10, 2010 Report Share Posted May 10, 2010 ok... probably been asked... how about modifying the rear housings to accept a front insert? im guessing the fronts are a longer than the depth of the rear shp housings?http://www.starquestclub.com/forum/index.php?showtopic=101947 Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 10, 2010 Report Share Posted May 10, 2010 http://www.starquestclub.com/forum/index.php?showtopic=101947 that is money right there... easiest route yet. i will be doing that to my set of blown shp's. Link to comment Share on other sites More sharing options...
importwarrior Posted May 11, 2010 Author Report Share Posted May 11, 2010 (edited) trying to find a set of blown SHP rears is going to be a challenge.anyone have a set for sale? PM me. Edited May 11, 2010 by importwarrior Link to comment Share on other sites More sharing options...
Garrett_M Posted May 11, 2010 Report Share Posted May 11, 2010 (edited) trying to find a set of blown SHP rears is going to be a challenge.anyone have a set for sale? PM me. you can also use an extra set of fronts to modify the non shp rears to use other struts. Edited May 11, 2010 by Garrett_M Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 11, 2010 Report Share Posted May 11, 2010 you can also use an extra set of fronts to modify the non shp rears. It'll show you how in the link above. that makes no sense... you can use front inserts by modifying rear shp housings. Link to comment Share on other sites More sharing options...
Garrett_M Posted May 11, 2010 Report Share Posted May 11, 2010 that makes no sense... you can use front inserts by modifying rear shp housings.or you can use rear mr2 (or various others) inserts in rear non shp housings by welding the top half of a front strut on. Front struts have inserts, rear NON shp's dont. But they can be modded to... Does that make sense? Link to comment Share on other sites More sharing options...
D_Venable Posted May 11, 2010 Report Share Posted May 11, 2010 that makes no sense... you can use front inserts by modifying rear shp housings. not entirely true Jesse.... You can use non-shp rears by cutting the top off, and welding the top threaded section of a non-shp front on to it. it's another way to do the MR2 swap Link to comment Share on other sites More sharing options...
Komeuppance Posted May 12, 2010 Report Share Posted May 12, 2010 not entirely true Jesse.... You can use non-shp rears by cutting the top off, and welding the top threaded section of a non-shp front on to it. it's another way to do the MR2 swap Yep!! -Robert Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 12, 2010 Report Share Posted May 12, 2010 not entirely true Jesse.... You can use non-shp rears by cutting the top off, and welding the top threaded section of a non-shp front on to it. it's another way to do the MR2 swap i get ya now... the wording was touch for me to catch the first time though :/ Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 12, 2010 Report Share Posted May 12, 2010 and for arguments sake, you could fabricate the entire rear housing if you wanted to. probably wouldnt really be all that hard. Link to comment Share on other sites More sharing options...
importwarrior Posted May 12, 2010 Author Report Share Posted May 12, 2010 ok are there any inserts from a 2009 or 2010 car that might be a fit for our rear struts to use as an insert. has anyone looked in to it? Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 13, 2010 Report Share Posted May 13, 2010 ok are there any inserts from a 2009 or 2010 car that might be a fit for our rear struts to use as an insert. has anyone looked in to it? the reason the front tokicos would be a good way to go is the top threaded portion will fit into either the stock strut mount or a camber plate made specifically for the car. that way your only modifying the bottom of the strut housing. i believe the mr2 struts have a bigger diameter at the top of the shaft. one of the smarter guys can confirm this. now i dont know if the front and rear tokicos had a different compression rate and how this would affect handling... Link to comment Share on other sites More sharing options...
D_Venable Posted May 13, 2010 Report Share Posted May 13, 2010 the shaft size is the same (22mm IIRC), but the threads are 14x1.5 (mr2) vs the stock 12x1.25 Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 13, 2010 Report Share Posted May 13, 2010 (edited) so the threaded part that needs to go in the hole is bigger than the stock hole in the strut mount correct? tell me the difference between the flatty front inserts and the wide bodies. for some reason the fact they are shorter comes to mind. get that fricken airdam painted! Edited May 13, 2010 by 89PalermoSHP Link to comment Share on other sites More sharing options...
D_Venable Posted May 13, 2010 Report Share Posted May 13, 2010 (edited) I'm not sure on actual insert length differences, but for MR2 insert modding, I noticed the casings are about 1/2" shorter on the flatties, plus the difference in angle at the spindle p.s. I've got a lot more to finish up before I patch some spots on and paint the airdam Edited May 13, 2010 by D_Venable Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 13, 2010 Report Share Posted May 13, 2010 so how about putting a front flatty tokico insert in a rear shp housing and not having to modify anything. Link to comment Share on other sites More sharing options...
D_Venable Posted May 13, 2010 Report Share Posted May 13, 2010 hmm, I've got both of those here (extras currently), I just have to tear down the rear SHP's, so once I tear down the struts, I can check, but I'm pretty sure that won't be anytime soon Link to comment Share on other sites More sharing options...
D_Venable Posted May 13, 2010 Report Share Posted May 13, 2010 (edited) Found this in the pics in my MR2 swap with airbags thread... a front widebody KYB replacement insert sits 10mm above the top of an uncut rear SHP housing http://www.26liter.us/gallery/albums/userpics/10030/DSCF6102.jpg but if you cut the little cup off the bottom of that insert, it might fit, or come close depending on the gland nut http://www.26liter.us/gallery/albums/userpics/10030/DSCF6081.jpg Edited May 13, 2010 by D_Venable Link to comment Share on other sites More sharing options...
89PalermoSHP Posted May 13, 2010 Report Share Posted May 13, 2010 im darn tempted to pick up a set of the flatty fronts. ive got my shp's sitting here doing nothing and from what i was reading in another thread the flattys were .400 or .500 shorter than the the others. Link to comment Share on other sites More sharing options...
