Clear Corner Light Lenses
JohnnyWadd
These are crystal clear acrylic cut to exactly match the stock lenses and proper thickness to set on the shelf in the stock housing.
Price $25.00 shipped.
These are for the corner lights in the fenders not the turn signals. "clear corners"
18 Sets ready to ship. Just picked them up today and test fitted them. They fit very nice and have a perfect clean cut. The stock lense is not a perfect parallelogram (the triangles at either end are slightly different angle due to the lower edge of the light being slightly longer) These lense have been reverse engineered with that in mind and fit nicely without an uneven gap. Also each corner is perfectly radius'ed slightly round.
Colors or black out pieces will be available next run if i get enough interest. Also next run will be cheaper like $15.00 or so because we already have the pattern saved. I lost a few bucks on labor getting them perfect this time.
http://i1187.photobucket.com/albums/z388/starionkiller/starion%20clear%20corners/th_C360_2013-02-10-22-59-35.jpg
Clear lense...
http://i1187.photobucket.com/albums/z388/starionkiller/starion%20clear%20corners/th_C360_2013-02-10-23-01-35.jpg
Smoked lense...
http://i1187.photobucket.com/albums/z388/starionkiller/starion%20clear%20corners/th_2013-02-19235932.jpg
Prismatic...
http://i1187.photobucket.com/albums/z388/starionkiller/starion%20clear%20corners/th_C360_2013-02-14-19-38-56.jpg
Example of what you can do with housings on your own. I did this with red vynil film...
http://i1187.photobucket.com/albums/z388/starionkiller/starion%20clear%20corners/th_C360_2013-02-24-15-17-49.jpg
Edited by JohnnyWadd
Hey jeff, are these gonna be exactly same as the ones I bought from ya? I haven't put them on yet, is there an easy way to pop those lenses off?
No these are crystal clear. If you want these instead let me know. They are hard to get out becuase the lense is tougher than the housing and more resistant to heat. I tried the oven method and messed up the housing and the lense was fine. I am gonne try a new methed that i think will work and do a write up.
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
