Dyno day
11 replies to this topic
#1 StarquestRescue
StarquestRescue
  • 4,628 posts
  • Interests:Mits owner from 1980
Posted 03 April 2010 - 07:47 PM
I was the last car to dyno, and i tuned a little between runs. It was $50 for 3 runs, burgers were free and i go a free t-shirt.  :D I made 5 runs, and could of made another, but i quit while i was ahead.
Best Hp = 258, best Tq = 324.
First 3 runs @19 psi. last 2 at 20-20.5 psi. Run 8 is the only one it did not break up on after 5000 rpm.
Bob Brady was on me to lean it out, and i did, but i like to move in small steps. There is more in the turbo, but i was up against some issues with erratic air flow signal at higher rpm, and afr that seems to jump rich when the duty cycle goes past 85%. I may be able to get around that by leaning it out, but with the air flow signal jumping around it is difficult to dial in the afr. I do not have a lot of tune time on the 2G mas, 2 secondary, re flashed afc Neo setup yet.
Mods at the time.
88 TSI 19c ported turbine housing and exhaust manifold. Marnel head, arp studs, factory head gasket, 7 to 1 compression Modified tep down pipe. Rob Kruger 2.5 exh with cat. Tep intercooler & otvc pipe. 2G mas, 2 Secondarys and bumped up fuel pressure. Tuned with reflashed afc Neo (program version 1.104). Rear 9s. Lightened flywheel & Bosch "350" fuel pump. Bse and ac delete. Innovated X16 wideband and two SSI4 logger boxes.
I did have about %40 unleaded race gas in it, but some braver souls have done similar  #'s on pump.
First run of the day. (run 5)
Run 9
Edited by StarquestRescue, 05 April 2010 - 04:00 PM.
2012 fall set up 20g 06  in the stock turbine houseing. 2g mas, Neo afc, Versafueler, 1050 / 2000 injectors on E85.  379hp 395 tq TBI Power
2012 spring set up. 18g06 in the stock turbine houseing.  2g mas, Neo afc, Versafueler, 1050 / 2000 injectors on E85.  Innovated data logging. 358 hp 393 tq. 12.71 @ 112
2011 set up. 18g05h,  2g mas, Neo afc, Versafueler, 1050 / 2000 injectors on E85.  Innovated data logging. 307 hp 360 tq  12.78 @ 112
2010 set up. 18g05h,  2G mas, Lsp 850 / 1400 injectors. Tuned with re flashed afc Neo version 1.104 and Innovated data logging.  297 hp 403 tq.
401 / 427 TBI   Dyno link-----------TBI Power http://www.sqperform....php?topic=33.0-----------Rear Gear link----------2010 Dyno link-------Feedback link
#2 TainterRacing
TainterRacing
  • 1,797 posts
  • Interests:Have a ???? Ask me. A Quester since 1997
Posted 04 April 2010 - 09:50 AM
When did you start to get on it?
It looks like it comes on a bit late.
The peak hp not bad at all that the stock cam?
This is a ported 14g 20-21psi stock injection, 1g mass, 2.5in ex, non jet valve head, ported ex manifold
Edited by TainterRacing, 04 April 2010 - 10:01 AM.
#3 psu_Crash
psu_Crash
  • 7,291 posts
Posted 04 April 2010 - 10:50 AM
Nice TBI numbers, sounds like you had a good time! I'm sure there is more in your setup but I don't blame you for not wanting to make drastic changes.
Where did you dyno at?
'86 Starion, MPI with MS2extra, Turbo Lab GTX3071R, P&P head, OS SS Valves, Wiseco +.030, ARP head/rod, RPW Roller Cam, Crower Rods, AEM H2O/Meth Injection, Mighty Max CAS 4 Direct Fire Wasted Spark, BSE, Tial 38mm, JDL exhaust mani, HKS turbo timer and EVC3, AEM UEGO, 3" DP into 2 1/2" Dual Exhaust, 85# Delphi's, Magna modded by Chad, Accufab FPR, Walbro 255, D2 Coilovers, GNT Poly Bushings and mounts, Autopower 4 point cage, Funk-Lock, LED Tails and Dome ... etc^4
2016, 17, 19 SCCA Solo, Glen Region Season Champion in Street Modified
The Valencia Project
http://www.starquest...+golden +dreams
My Feedback Link
#4 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 04 April 2010 - 11:08 AM
We started the runs at 2500. Full boost was achieved at 3750-3800 rpm. Right where the torque peaked.
I think there is another 20-25 in it, with a leaner tune and a little more boost. Remember my car has a 2.5 exhaust and cat. I have some 3" stuff here i need to get on.
Serpentkiller was going to come with the supra car, but his trans went the night before. There is a shop about a mile away. You need to get your car back together.
#5 Dan_Brew
Dan_Brew
  • 446 posts
Posted 04 April 2010 - 09:31 PM
Nice numbers
Im with you on it haveing more I did similar numbers on a smaller turbo on 93 gas and on a mustang dyno.
I have some of the same problems that you ran into with it breaking up in the higher rpms. I had mine tuned by a pro and he thinks that its interference of some sort in the higher rpm ranges. He said that I should try to shield all the wiering going back to the ecu to see if that would help out. Next time you get on a dyno you should just jump on it and see where your power is. On mine I was hiting 300tq by 2500 rpms.
How do you like the 2G mas? Im running mine with the 3 inch maf and maft and it seams to work well.
Congrats on the great numbers its nice to see more tbi cars making good power.
White 89 Conquest SHP 238hp/331tq 20lbs of boost. Best 1/8th mile time 8.68
NJV Head-Mech. lifters-Ported & stress relived manifold-14b Turbo port matched exhaust housing-Fully ported 52mm intake & TBI knife edged-TEP hard pipes-HKS BOV-2.5" exhaust-Act clutch-3" GM Mas-Maft-AFC Neo-AEM wide band-ARP studded-255 fuel pump
#6 Funky Phil
Funky Phil
    Super Pooper
  • 6,465 posts
Posted 05 April 2010 - 12:13 AM
You should definately check the wastegate linkage and maybe tighten it up. When I had mine many moons ago. (stock block TBI setup with hardpipes, 2.5 ex, 1GMAS) It was a lagger like what your dyno graph is showing. turned out the wastegate linkage had too much slack and was set slightly open. I tightened it up to not crack til 18psi which would momentarily spike to 22psi and settle to 18psi. It was wicked. But, I was seeing that boost in the 3000rpm range. not saying you should make it that tight.
But anyways, just a thought. Check your wastegate linkage. maybe bring it in a few turns.
Couldnt tell if you are logging IAT but I know that once your over 18psi that 19C blows HOT!
phil
Edited by phinko, 05 April 2010 - 12:15 AM.
10.95@120mph  https://m.youtube.co...h?v=8Q01UKt5q4U
Built G54B, S364, R154, stock 6-bolt, fireballs
#7 psu_Crash
psu_Crash
  • 7,291 posts
Posted 05 April 2010 - 12:55 AM
I can't agree more! I screwed up a control arm bolt during reassembly over the weekend so I'm trying to find those. But other than that it's drivable. Then I get to see what happens with the H2O/Meth since it's all hooked up now and should be ready to go.
Dyno is at the top of my To Do list as soon as I get it back on the road.
My Feedback Link
#8 starquestJOE
starquestJOE
  • 3,586 posts
Posted 05 April 2010 - 09:51 AM
maybe me and mike can get together and take a ride down and make some runs. i know i'll need to dyno mine whens its together. and john you goin to make the meet
IM STARQUEST 4 LIFE ....
88 esi-r-white-SOLD
88 tsi white 61k-SOLD
89 tsi-black-rip
87 tsi-black/red-SOLD
88 tsi yellow sold
89 tsi white parts car
88 esi-r-black-RIP
#9 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 05 April 2010 - 04:23 PM
I like the 2G. Here is a good read on the issues i found with the 1g and stock.  http://www.kdmperfor...d.php?t=4808  I also have seen evidence that air hard pipes make the air flow signal more erratic.
I did not think staring the run sooner would have made much difference. In the past i have had problems trying to boost from down low and did not want to waste a run. Thanks on the #'s. I was pretty happy, but i know there is more in it.
phil
Yes i could probably tighten that up a little. Not logging IAT yet, i do have two input channels left. Last time i was checking the back side off the inter cooler and the heat only made it 3/4 of the way across. Any thing bigger than a stock turbo can benefit from an intercooler up grade.
Edited by StarquestRescue, 05 April 2010 - 04:24 PM.
#10 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 05 April 2010 - 04:36 PM
Link to the last time i dynoed. http://www.starquest...owtopic=82526
What i was looking for from the 2g was a tune that would run great on a cool mourning, and drive home in a hot afternoon with out the afr drifting out of whack. So far i am real happy with it. The signal is  still a little choppy, i an going to try a baffle in the ahp.
I actually had a 3G mas on it for a week, it ran ok, but no better than the 2G, so i went back to a more proven tune for the dyno.
For the newbies, you need a way to add 20-25% more fuel to run the 2g.
#11 Dan_Brew
Dan_Brew
  • 446 posts
Posted 05 April 2010 - 08:51 PM
Whats your fuel presure at ideal?
#12 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 05 April 2010 - 09:38 PM
View PostDan_Brew, on 05 April 2010 - 08:51 PM, said:
Whats your fuel pressure at ideal?
I do not know. The car could idle better, it hunts back and forth a little. I may try and reset it again and see if i can get it better. The injector could probably stand to be cleaned. I went thur 3 850's and 1 1000. All leaked on the out side. finally the second 1000 stayed dry on the out side.
