CXRacing 3 inch Down pipe for stock turbo $149
I-W CXRacing CXR
17 replies to this topic
#1 importwarrior
  • 18,362 posts
Posted 09 January 2015 - 05:38 AM
Check with them that this is ACTUALLY 3 Inch diameter pipe before ordering.
http://www.ebay.com/...=mtr&rmvSB=true
#2 Fuze
Fuze
    AKA @Battlemagnet
  • 2,780 posts
  • Interests:Chess Boxing
Posted 09 January 2015 - 09:44 AM
Nice! Looks just like the Top End Performance one, but stainless.. and cheaper.
Insta = @battlemagnet
#3 pcristquester
pcristquester
  • 2,545 posts
Posted 09 January 2015 - 09:57 AM
And different being 3" because TEP is sticking to their story on 2.5"...
#4 Fuze
Fuze
    AKA @Battlemagnet
  • 2,780 posts
Posted 09 January 2015 - 10:19 AM
Haha, oh yeah their 2.5" mythology. Most likely they just have a ton sitting on the shelf from the 90's, CNM proved them wrong with dyno results back then.
#5 SOTTY
SOTTY
  • 6,466 posts
  • Interests:Az gotz da cotton mouff
Posted 09 January 2015 - 01:45 PM
Again this is the old *DM dp , its more of a precat elimination pipe and its 2.5 inch in diameter and not 3inch , its a worthwhile mod and good for 11 to 12 rwhp , retains the use of the old precat springs so no flex pipe required , fit and finish is way superior to the T.E.P item .
Edited by SOTTY, 09 January 2015 - 05:13 PM.
#6 pcristquester
pcristquester
  • 2,545 posts
Posted 09 January 2015 - 03:54 PM
Are they lying about the diameter again.
#7 SOTTY
SOTTY
  • 6,466 posts
Posted 09 January 2015 - 05:16 PM
Its incorrect, these dp's are 2.5 inch , still a very worthwhile purchase for those still running a stock system .
#8 pcristquester
pcristquester
  • 2,545 posts
Posted 09 January 2015 - 05:35 PM
Well I think it's incorrect on purpose, which is bs
#9 Fuze
Fuze
    AKA @Battlemagnet
  • 2,780 posts
Posted 13 January 2015 - 09:07 AM
You're right, looking at the pipe it's 2.5", otherwise it would need to taper at the flange like the MK1 versions.
Yeah Sotty I remember bolting on my first TEP downpipe years ago and loving the seat of the pants improvement. One of the best mods.
#10 yamahlr
yamahlr
  • 157 posts
Posted 19 April 2015 - 10:10 PM
What mods are necessary to mate this to the stock turbo? Looked at the other one on Ebay with the flex pipe, and stated it requires drilling new holes to mate to stock exhaust. Looking to maybe install the TEP "b" pipe and have an N.O.S. HKS exhaust I'd like to install at the same time. Any thoughts or advise on this swap guys?
#11 SOTTY
SOTTY
  • 6,466 posts
Posted 19 April 2015 - 11:05 PM
Its a straight swap to the o.e.m "b" pipe ,  you retain the original springs from the o.e.m pre cat but using the new bolts hopefully provided (they should be) , this dp will also work with the T.e.p off road "b" pipe.
#12 Fuze
Fuze
    AKA @Battlemagnet
  • 2,780 posts
Posted 20 April 2015 - 11:20 AM
Either way, a 3" down pipe mated to a stock sized B pipe would make no sense.
Edited by Fuze, 20 April 2015 - 11:21 AM.
#13 SOTTY
SOTTY
  • 6,466 posts
Posted 20 April 2015 - 11:43 AM
Indeed but that Cx dp isn't 3" , they want to fix thier error
#14 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 05 March 2016 - 01:57 AM
here are some install pics of the 2.5 downpipe, using the stock turbo housing and stock exhaust. cost about $7 for the bolts and washers and just used the stock springs.
2005 Acura RL SH-AWD
#15 shadow89
shadow89
  • 187 posts
Posted 05 March 2016 - 08:05 PM
Will that downpipe use the same stock o2 sensor?
#16 TexasQuest
  • 9,118 posts
Posted 05 March 2016 - 08:11 PM
No the stock O2 sensor bolts on, not screws on. You'll need a Bosch 12053 O2 sensor.
88 Fiji Blue -TSi
#17 shadow89
shadow89
  • 187 posts
Posted 05 March 2016 - 10:21 PM
ok thanks
#18 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 05 March 2016 - 10:46 PM
yes he is correct the stock original one is a one piece unit. but if yours has been replaced with an aftermarket one then it should unscrew from its base.
in this pic is a ORIGINAL 02 sensor from the factory, the bosch comes with a adapter plate so it fits the stock converter. i just unscrewed the base plate on the bosch sensor and it screwed right into the downpipe.
Also tagged with one or more of these keywords: I-W, CXRacing, CXR
