Transmission problem maybe? Hard to turn.
5 replies to this topic
#1 Lizzord30
Lizzord30
  • 1,927 posts
  • Interests:Think outside the box!!
    The box has stale air.... Yuck
Posted 22 May 2012 - 04:47 PM
Having some problem with my car I think transmission, My engine without connected to the trans is very easy to turn, but after putting the transmission (stock 88 auto) it is pretty hard to move the engine doesnt seams to change with changing the gear. When moving the the rear wheels it always feels pretty hard to move, and i dont think the brakes are an issue.  With the engine a little losse from the transmission the engine it turns over pretty easy. Any ideas?
89 TSI: The Blue Car Best time 12.4 15psi 7:1  Now is a part car for my 88.
88 Starion ESI-R Red Auto 60-1 hifi, Hawk ECU, 720cc inj, Magna Intake, from 8:1-9:1 compression.
More info here: http://www.starquestclub.com/forum/index.php?showtopic=130169
96 850 Turbo Volvo 5cyl, 2.3l, 15g Over 230k
#2 vbrad511
vbrad511
  • 8,392 posts
Posted 22 May 2012 - 07:41 PM
Sounds like your torque converter isn't clocked into the pump in the trans correctly. If you've tightened the bolts down and the converter is amiss you can break the pump. Probably should back the trans away from the motor and make sure the converter dogs are seated properly.
#3 Lizzord30
Lizzord30
  • 1,927 posts
Posted 22 May 2012 - 08:03 PM
Have any tricks to get it clocked in right?
#4 MikeMeyerhoff
MikeMeyerhoff
    I mod therefore I am
  • 5,599 posts
Posted 23 May 2012 - 11:58 AM
Slide the convertor on the trans before you put it in. Then bolt the convertor to the flexplate once the trans is mounted to the motor...  Not the other way around (like a manual trans).  Its harder that way because you have to keep the convertor from falling off and the trans will wiegh more, but its worth it.
The engine will be harder to turn with the auto trans attached.  Even in neutral, there is some internal friction and you are pumping fluid.
Kevlar Bands for Starquest Automatics - $50  Out of Stock  (I Pay $15 for cores)
Rational,  Irrational,  Beerrational.
#5 Lizzord30
Lizzord30
  • 1,927 posts
Posted 23 May 2012 - 01:22 PM
Thanks for the help got it good! Removed the engine from the trans, dissconected the engine mounts, then pulled it back and then on it rotated it some then it slipped on and now turns easy!
#6 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 17 October 2013 - 02:51 PM
9 out of 10 times doing that will break the oil pump drive gear inside the tranny ,,the pump drive gears was what you were not meshed with
you never mount convertor on flex plate then install into tranny at same time as installing engine , always incert into trans  then bolt to  flex plate
88TSI Silver
89TSI red auto
