My 4g63 and t-56 swap (TONS OF PICTURES
82 replies to this topic
#41 TsTKl
TsTKl
  • 394 posts
Posted 25 September 2013 - 01:35 AM
Thanks guys. I'm not at my computer with ASA so I'll look up the part number tomorrow
#42 TsTKl
TsTKl
  • 394 posts
Posted 29 September 2013 - 10:11 PM
Here's the Radiator Water Temp Switch Part Number: MB356704
So continuing with with build story. Today we focus on the Interior and Wiring.
I decided that I wanted to make the car lighter by removing any un-needed Wires and sound deadening. Since I was removing the AC, ABS, Cruise control, and other electronic devices I decided I didn't want any of the wires for those systems there. I removed EVERY SINGLE WIRE from the whole car, and started from scratch:
The last photo was taken in the beginning of the process when I was still removing wires.
Now on top of the obvious wiring changes listed above (AC etc) were some other small electrical changes. I wanted to keep my heater functioning because I don't like being cold and in case the engine ever started to get hot during a race. Another thing I kept was the radio and dash. I wanted the car as light as possible, so I converted to 1983 style manual heater controls
Now unfortunately I didn't grab the power resistor from the donor car so that the fan would work properly. I didn't realize since I was ditching the A/C control unit (which didn't work) I would have to change from the transistor style controller for the fan to the older power resistor style. I found a 91 mazda with a denso fan and was able to grab the resistor off that and make it work.
I wanted to integrate everything so it could be removed easily as possible. My Innovate LC-1 Wideband O2 sensor was one of those things.
The final picture shows my ECU wiring harness, for the interior side only. I added a 38 pin molex firewall connector so that pulling the engine would be easy and wouldn't require any sensors to be unplugged. The wideband plugs into this right next to the chassis harness connector. Things like the calibration switch/LED and fuel pump relay/cut off are incorperated into this connector. Its very nice when everything works together. Here's where I ended up mounting the ECU. No more A/C unit to take up that space.
#43 TsTKl
TsTKl
  • 394 posts
Posted 29 September 2013 - 10:25 PM
After tearing the whole thing apart, it was time to start putting things back together. I made sure I cleaned everything before re-assembling the interior.
I had to convert to an electric speedometer, and was able to use a 98 eclipse speedometer. This was good since it has the same signal for speed as the ECU, meaning I would only have to convert the signal once from the T-56 transmission to the speedo, ECU, and EPS (yes, EPS).
I did still want to lose as much weight as possible out of the dash despite me still using it. I found the factory shin guard had a very large un-necessary piece of metal which could be drilled out:
The factory 83 glove box weighed considerably less than the 88 glove box because of this:
And lastly, not pictured, I was able to remove the large steel bracket which follows the length of the dash. As a result, the dash is considerably lighter and easier to remove/install.
As it sits the car is 99% done interior and wiring wise. It has been very nice being able to sit in the car again and look at the interior, which I really like on these cars. The car needs some money to run again as it sits, so I can't give a timeline on when it will be "roadworthy" but believe me it will be very roadworthy once its done.
#44 creakyjoints
creakyjoints
  • 1,944 posts
Posted 30 September 2013 - 08:21 AM
I like your project! Why didnt you use the tach from the same car as the speedo?
#45 TsTKl
TsTKl
  • 394 posts
Posted 30 September 2013 - 08:14 PM
I'm not too big on aesthetics, so it doesn't bother me too much that they are different colors. I could always have a cover made or something. The speedo HAD to be used because it wouldn't work otherwise, while the tach still worked and bolted in easy.
I should also mention I removed ALL of the seat belts, and will be replacing the front belts with manual style belts. That saved a considerable amount of weight.
#46 Xtreme Industries
Xtreme Industries
  • 1,538 posts
  • Interests:cars
Posted 01 October 2013 - 09:54 AM
damn, this is cool. if i attempted something like this, the car would burst into flames when i tried to turn it on. i suck at electrical stuff.
keep up the good work.
1991 BMW 318i - RIP
#47 Starquest87Jimmy
Starquest87Jimmy
  • 107 posts
  • Interests:Cars, Harleys, CH-47s
Posted 22 January 2014 - 02:41 AM
Is there more?
#48 Jack86
Jack86
  • 81 posts
Posted 03 February 2014 - 09:26 PM
This is awesome man. Can't wait to see it finished.
#49 Xtreme Industries
Xtreme Industries
  • 1,538 posts
  • Interests:cars
Posted 04 February 2014 - 09:01 AM
hows the progress coming?
1991 BMW 318i - RIP
#50 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,413 posts
Posted 06 February 2014 - 09:56 AM
awesome build dood ;)
          MOPAR POWERED
#51 autotr8er2
autotr8er2
    Out of my Cotton Pickin' Mind
  • 993 posts
Posted 06 February 2014 - 01:41 PM
Keep going man great job on the pedal assembly
#52 TsTKl
TsTKl
  • 394 posts
Posted 13 March 2014 - 11:53 PM
Hey guys, thanks for the compliments. I think about this project probably every day but my current financial/living situation is preventing me from making significant progress. The car is in storage and I can't really work on it, but I've got some solid ideas down on paper that should work out really well. Also my new job has a welder so I'm getting a lot of the little welding projects I needed to get done finished. Hopefully there will be an update at the end of next month of some significance.
#53 u2slow
u2slow
  • 105 posts
  • Interests:DSMs, drag racing
Posted 14 March 2014 - 11:50 AM
Love your car. Take your time. Enjoy the adventure :D
4g63 conversion
8.89/153 mph
#54 TsTKl
TsTKl
  • 394 posts
Posted 13 January 2015 - 01:03 AM
Hey guys,
Just wanted to let you know that I've started working on this project again and should have some progress to post soon.
#55 importwarrior
  • 18,369 posts
Posted 13 January 2015 - 05:52 AM
good news. i would like to do this swap also.
keep us posted. i would like to see it finished.
#56 Convette
Convette
    I used to driftjunk
  • 4,990 posts
  • Interests:Going faster
Posted 16 January 2015 - 05:31 PM
do work.  I wanna see burnout videos asap.
#57 screemin eagle
screemin eagle
  • 1,007 posts
Posted 16 January 2015 - 07:48 PM
Import warrior buy my setup!
88 TSI 4g63
03 GMC Denali the tow truck
#58 Jack86
Jack86
  • 81 posts
Posted 19 February 2015 - 01:06 AM
I'm curious how well the t56 will work with that engine. Great build.
#59 TsTKl
TsTKl
  • 394 posts
Posted 06 March 2015 - 01:26 AM
I'm not going to lie, a lot of the motivation I currently have for working on this project comes from people constantly sending me links to (numerous different) articles about lazorack's car. I'm changing jobs again, so I should have more money for this project, although less access to a certain welder, mill, and lathe unfortunately. Will have a quality update in 11 days. Promise.
#60 importwarrior
  • 18,369 posts
Posted 06 March 2015 - 08:49 AM
Great build wish I had time and a place to do projects like this.
Keep at it.
