88-cnqst-tsi Posted April 24, 2013 Report Share Posted April 24, 2013 im getting this http://www.ebay.com/itm/CXRacing-Aluminum-Radiator-240SX-S13-SR20-55mm-3-Rows-/250764602376?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a62bc2c08&vxp=mtr and I want to know where I should put the fan switch sensors, also do I need a special type of coolent for a aluminum rad Link to comment Share on other sites More sharing options...
Komeuppance Posted April 24, 2013 Report Share Posted April 24, 2013 Bottom. No. -Robert Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 24, 2013 Author Report Share Posted April 24, 2013 Bottom. No. -Robertwill I have to drill holes and get bungs welded on Link to comment Share on other sites More sharing options...
Komeuppance Posted April 24, 2013 Report Share Posted April 24, 2013 Yes. -Robert Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 24, 2013 Author Report Share Posted April 24, 2013 is there a different way to do it Link to comment Share on other sites More sharing options...
Komeuppance Posted April 24, 2013 Report Share Posted April 24, 2013 Re-read the link I posted about the SR20 rad in your other thread. -Robert Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 24, 2013 Author Report Share Posted April 24, 2013 I did and theres people that say to mount the primary sensor in the a/c spot in the intake manifold but im not sure if that's a good way to go since that's not the temp in the rad Link to comment Share on other sites More sharing options...
Komeuppance Posted April 24, 2013 Report Share Posted April 24, 2013 Primary thermosensor removed from original rad, placed in EGR thermoswitch location. And then wired to trigger both fan relays. -RobertHis fans turn off and on just fine. I wouldn't have approved it if they stayed on all the time, that's for sure. -RobertWell my set up works...sooooo...i just did the same swap and i installed the secondary switch in the drain hole of the radiator just drill and tap it to M16-1.5 works great. thanks StarQuestMike -Robert Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 24, 2013 Author Report Share Posted April 24, 2013 I guess if I go that route, the egr willnt work Link to comment Share on other sites More sharing options...
Shelby Posted April 28, 2013 Report Share Posted April 28, 2013 the main question is how hot is the rad coolant , lets just say the fan sensor is in the intake,,the thermostat fails to open the fan run cause the intake is over heat'd but does the coolant get cool'd nope cause of no flow to the rad ,, be a real pain to trouble shoot wouldn't it, cause you'd think well the fans do run so it must just be the gauge off , few people actualy lay hands on the rad to see if it is hot or not Link to comment Share on other sites More sharing options...
importwarrior Posted April 28, 2013 Report Share Posted April 28, 2013 (edited) check this out. this is an alternative. the screw is for a ground wire to the engine block.just splice lower radiator hose then clamp it down make sure to run ground wire.on a side note the stock mitsu sensor might not fit. you might have to drill taphole to proper thread pattern or use a different fan sensor.the link below does come in different sizes so make sure to get the proper sizefor the quest hose. Link: http://www.aliexpres.../616319272.html this is called a radiator temp sensor adapter. search for one.http://i2.frsimg.com/images/detailed_images/Greddy_16401630_6_15543_15544_15545.jpg Edited April 28, 2013 by importwarrior Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 29, 2013 Author Report Share Posted April 29, 2013 the main question is how hot is the rad coolant , lets just say the fan sensor is in the intake,,the thermostat fails to open the fan run cause the intake is over heat'd but does the coolant get cool'd nope cause of no flow to the rad ,, be a real pain to trouble shoot wouldn't it, cause you'd think well the fans do run so it must just be the gauge off , few people actualy lay hands on the rad to see if it is hot or notyeah that's a problem then so ill see if I can get a bung welded in the rad and run the two fans off that one sensor but is the cx racing rad thick enough to weld? Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 29, 2013 Author Report Share Posted April 29, 2013 check this out. this is an alternative. the screw is for a ground wire to the engine block.just splice lower radiator hose then clamp it down make sure to run ground wire.on a side note the stock mitsu sensor might not fit. you might have to drill taphole to proper thread pattern or use a different fan sensor.the link below does come in different sizes so make sure to get the proper sizefor the quest hose. Link: http://www.aliexpres.../616319272.html this is called a radiator temp sensor adapter. search for one.http://i2.frsimg.com/images/detailed_images/Greddy_16401630_6_15543_15544_15545.jpgI was actually just looking at those but the holes are to small and like the post above, will it read properly Link to comment Share on other sites More sharing options...
Shelby Posted April 29, 2013 Report Share Posted April 29, 2013 they do not weld radiators they solder them Link to comment Share on other sites More sharing options...
SOTTY Posted April 29, 2013 Report Share Posted April 29, 2013 (edited) Derale also make a adjustable thermo fan switch with a probe sensor that goes into your top radiator hose for around $30 and can be found on Ebay , easy to install and works great ! , i went this route using the same radiator you just bought Edited April 29, 2013 by SOTTY Link to comment Share on other sites More sharing options...
TexasQuest Posted April 29, 2013 Report Share Posted April 29, 2013 I was actually just looking at those but the holes are to small and like the post above, will it read properly240 guys run them all the time no problem when they swap out their fan clutch to electric fans. Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 29, 2013 Author Report Share Posted April 29, 2013 Derale also make a adjustable thermo fan switch with a probe sensor that goes into your top radiator hose for around $30 and can be found on Ebay , easy to install and works great ! , i went this route using the same radiator you just bought can you send me a link to the correct one please and will I have to get a new sensor or tap a new hole? Link to comment Share on other sites More sharing options...
Shelby Posted April 30, 2013 Report Share Posted April 30, 2013 Derale also make a adjustable thermo fan switch with a probe sensor that goes into your top radiator hose for around $30 and can be found on Ebay , easy to install and works great ! , i went this route using the same radiator you just bought those sensors go into the lower rad hose not upper Link to comment Share on other sites More sharing options...
SOTTY Posted April 30, 2013 Report Share Posted April 30, 2013 those sensors go into the lower rad hose not upperThen i guess both Derale performance and myself are both wrong , the capillary tube and probe sensor is inserted in the top radiator hose . Link to comment Share on other sites More sharing options...
SOTTY Posted April 30, 2013 Report Share Posted April 30, 2013 (edited) can you send me a link to the correct one please and will I have to get a new sensor or tap a new hole?I suck at internet mang , Derale performance , Los angeles , C.a the part # is 16769 ,punch that into your computer and it'll come up, it's very easy to install , no tapping into the rad whatsoever , comes with everything you need , it's a very clever set up that works very well and powers up to two 12" fans . Edited April 30, 2013 by SOTTY Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 30, 2013 Author Report Share Posted April 30, 2013 (edited) I suck at internet mang , Derale performance , Los angeles , C.a the part # is 16769 ,punch that into your computer and it'll come up, it's very easy to install , no tapping into the rad whatsoever , comes with everything you need , it's a very clever set up that works very well and powers up to two 12" fans . I wanna run stock fans cause im broke as a joke, will they fit , I can make mounts Edited April 30, 2013 by 88-cnqst-tsi Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted April 30, 2013 Author Report Share Posted April 30, 2013 those sensors go into the lower rad hose not upperThen i guess both Derale performance and myself are both wrong , the capillary tube and probe sensor is inserted in the top radiator hose . lol who do I trust Link to comment Share on other sites More sharing options...
SOTTY Posted April 30, 2013 Report Share Posted April 30, 2013 lol who do I trustoh that ones easy as i won't give out wrong information on something iv'e tried and tested myself and i have the installation instructions in front of me as i type with the detailed drawing of the radiator top hose showing the temp probe inserted and do yourself a big favor no matter how broke you are and buy two cheap Ebay 12 inch fans and the ties to attach them to mang , don't mess trying to adapt the stock fans , that and there probably getting to old to be of any use like other things in the Starquest world Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted April 30, 2013 Report Share Posted April 30, 2013 if SOTTY has done this to HIS OWN QUEST and it works, do you need more info here ? no, IT WORKS ...and if it keeps his quest cool in that vegas heat, it'll work ANYWHERE Link to comment Share on other sites More sharing options...
importwarrior Posted April 30, 2013 Report Share Posted April 30, 2013 (edited) check this out. this is an alternative. the screw is for a ground wire to the engine block.just splice lower radiator hose then clamp it down make sure to run ground wire.on a side note the stock mitsu sensor might not fit. you might have to drill taphole to proper thread pattern or use a different fan sensor.the link below does come in different sizes so make sure to get the proper sizefor the quest hose. Link: http://www.aliexpres.../616319272.html this is called a radiator temp sensor adapter. search for one.http://i2.frsimg.com/images/detailed_images/Greddy_16401630_6_15543_15544_15545.jpg you just have to get a different fan sensor form jegs or summitracing. the sell them to fit in there.Also just make sure you have a good ground wire.use a meter to test it.used it before on an eclipse and had no problems. http://www.ebay.com/...r-/121033753578$6.99in the pic below you can see the grounding screw. http://i.ebayimg.com/t/34mm-Blue-Water-Temperature-Gauge-Join-Pipe-Radiator-Hose-Sensor-Adapter-/00/s/NjAwWDYwMA==/$(KGrHqN,!o0FC1s1dqNUBQvsqWFQ6!~~60_3.JPG Edited April 30, 2013 by importwarrior Link to comment Share on other sites More sharing options...
