My 87 Flatty
48 replies to this topic
#41 Mix_67
Mix_67
    Wheel Spinner
  • 561 posts
Posted 07 May 2021 - 07:45 AM
Well all she needed was a jump. Fired right up, made good pressures, and idled as good as it ever did. Made it about 3 miles home and now it needs 2 years dirt cleaned off the plastidip. Looking forward to getting it back out and on the road, and maybe even hit a few Auto-x this year.
"Speed costs money. How fast do YOU want to go?"-Spoolin' Fools, Venus PA
"I was doing fine until about mid corner, that's pretty much were I ran out of talent and spun the car"
'87 Flatty Intercooled w/ 16gEvo3 @ 18psi, ssq-bov, ARP Head Studs, BSEK, 5-speed swap, 5 lug swap w/ 6bolt LSD, 3:90's, Cosmo Dual Spring Coilovers, MK1Shocks, MK1 Camber Plates, M28 head, Tial 38, SAFC-2, SSI-4,750/1400 Injectors
2010 DSM Shoot-Out DSM MAXeffort Street Tire Winner
#42 Mix_67
Mix_67
    Wheel Spinner
  • 561 posts
Posted 10 May 2021 - 09:21 PM
Knocked 2 years of dust off
#43 Dred_85.5_TSI
Dred_85.5_TSI
    Flatty Love
  • 2,220 posts
  • Interests:I have an announcement to make, "Turbo........ That is all".
Posted 12 May 2021 - 05:56 AM
Good to see you back around. Sounds like our last few years have been about the same with kids and what not. I'm going to start working on my 84 again this year and try to get it back on the road.
Posted Image   1984 Starion ES: Currently running 15psi, Stock block (ARP main and head studs rod bolts, Clevite bearings) BSEK, M28 NJV head with mechanical valve train gasket matched on intake and exhaust, Treadstone exhaust manifold and Holset HX35w with BEP turbine housing, MK1 3" stainless exhaust, Old skool HKS super BOV, 3" GM MAF with MAFT, Artinist's old 4" core intercooler, custom Aluminium hard pipes, S13/SR20 Aluminium radiator w/clutch fan, Innovate LC-1 wide band O2, `83 crank pulley with A/C removed.
   `88 5 speed trans with Stedbani short shifter, Stedbani poly trans mount and engine mounts, drilled and slotted rotors, Joly roger stainless steel braided lines(brake, clutch, oil cooler, and ABS delete).
   KYB GR2, Artinist sleeve coil-overs, MK1 poly bushings, Energy Suspension poly end links, MK1 Adjustable tension rods, Cusco front camber plates, Artinist slotted rear camber plated.
ABS, A/C, Cruise control.. deleted, Right hand drive E-brake handle.
... more to come
Feedback:
Feedback thread #1
Feedback thread #2I'm PayPal Verified
#44 Mix_67
Mix_67
    Wheel Spinner
  • 561 posts
Posted 12 May 2021 - 07:03 PM
Well the car made it the 70mile round trip to work and back with no issues. Even took it for a 5 mile interstate run over lunch break.
Really make you realize how big modern cars are when you drive one of these old cars in traffic.
I have to figure out how to post pics again since my Photobucket of old is long gone.
Edited by Mix_67, 13 May 2021 - 10:11 AM.
#45 Turbo Cary
Turbo Cary
  • 1,944 posts
Posted 13 May 2021 - 12:53 PM
Use Imgur for image hosting. It's free and pretty easy to use.
#46 Mix_67
Mix_67
    Wheel Spinner
  • 561 posts
Posted 13 May 2021 - 01:46 PM
Hey now I'm back in the photo game.
Got an oil change done on lunch today. (work from home benefits). Also got the tabs on the hatch struts cleaned up and shimmed out with some zipties to get the rear wiper working.
Need to get some good sunshine to see if I can get the old auto-x magnets to flatten back out so I can use them this weekend.
Edited by Mix_67, 13 May 2021 - 01:52 PM.
#47 Mix_67
Mix_67
    Wheel Spinner
  • 561 posts
Posted 17 May 2021 - 07:05 AM
Made it to my first auto-x event in a long time. Driver is rusty, rear shocks appear blown, and the tires are well past their prime. I didn't get the times that i wanted but had a ton of fun doing it. I will be starting another topic about autox setups to get some insight on some parts upgrades and alignment settings.
#48 Mix_67
Mix_67
    Wheel Spinner
  • 561 posts
Posted 19 July 2021 - 11:57 AM
I ended up with 2.5 degrees of camber in the front and 1.8 in the rear. Car was neutral maybe favoring oversteer. Tires are 8 years old so there is plenty left in the car if I can get it to the ground.
https://youtu.be/WSX0T8qaT3U
#49 techboy
techboy
  • 3,902 posts
Posted 20 July 2021 - 09:42 AM
Love seeing another car from PA around!!
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
