- 387 views
- 980 views
- 1 reply
- 627 views
- 10 replies
- 866 views
HEADLAMP ACTUATOR MOTOR
By KIDMEN,
What is the difference between the 1984 1985 headlamp actuator motor and the 1987 thru 1989
turbonetics delta mark 2 wastegate problem
By Power ram 50 turbo,
I'm having troubles with my turbonetics external wastegate over boosting won't open I have a 9 to 13 lbs spring in it and it's boosting 30lbs so the question is how do I hook the vacuum lines to it I'm pulling the reference from the turbo compressor side. on the wastegate I have two ports one is vacuum the second is boost I tried it many different ways and it's still over boosting I took it apart and checked the diaphragm and it's good if any of you guys have any info on this wastegate or is
Tep Rear Battery Strut Bar
By 87-88-89,
Anyone have a rear strut bar that holds the battery for sale that Tep made? http://www.racetep.com/arlanrear2.jpg
What is the white 4 pin plug by the coil. not ac relay 1986 wide
By BADBAJA,
It is a 4 pin plug that should have a relay plugging into it, it appears anyway. White plug near the 4 ac relays(still have the 4 ac relays hooked up so its not them I hope). Wire colors are as follows Blue/white Blue/white Blue Black I traced the first 3 going into the car through the drivers side big harness. Black looks like it nay go to ground. Car has ac and analog gauges. I checked the service manual and I am still scratching my head.
