- 20 replies
- 2770 views
- 36 replies
- 5013 views
- 674 views
Fuso IC installed pic
By Boosted_One,
Finally got the Fuso IC in.
Somehow I managed to keep the oil cooler in the stock location. I used the same brackets that bolted the stock intercooler in for this intercooler.
The small cooler to the left is the power steering cooler. I removed the cooling line that ran from in the front where the intercooler is.
This IC IMO is about as large as I could squeeze in. the problem is the bumper brackets interfere. The first Fuso IC I had would not have fit, too bad too.
...now I'm g
Roller Cam Dynamics 2
By Tim_C.,
The reduced base circle (.140 less) is a must for many reasons. Â Most include longevity. Â The lobe needs reduced to keep the action in it's wheel-house so to speak. Â Like a pro baseball player hitting a ball with perfect timing. Â The stock base circle would put more stress on the rockers and shafts. Â
Also, for you guys who want more from their slip rocker cams: Â You can put the 1.5 ratio roller tip rockers MD106245 on, and get the gains from the increased lift, and less resistance from t
springs
picture resizing
By ilber,
i would want  to see an automatic picture resizing to say  640x480
I have noticed  that  pictures that  insert  aredisplaying in actual size, while if view  them in another browser window(just a  picture  new version of IE would resize it).I do tend to have all my pics in 1760x1168x 24 bit, on ocasion i would  resize prior uploading to 1120x760 and doa 45% JEPG compression.
Because  when entire thread is scrolls 1168or760or  what ever  the horizontal resolution(greater  tha
