turbosigma
MSN
turbosigma@hotmail.com
Australia mate
1982
After Market
Restoring
turbosigma's Achievements
Good call, Yes. There Stage 2 turbo cam.
My 2c, its worth it, no dyno print out yet but its making more power now at 16psi than it did at 22psi. Keep in mind this is a cam and head work. Should be intreasing when it gets the new intake and tune. OS valves - double valve springs - cam - adj cam gear - cnc intake ported, exhaust only ported around valves - cnc combustion chamber https://fbcdn-sphoto...7_3319002_o.jpg https://fbcdn-sphoto...447_48305_o.jpg https://fbcdn-sphoto...7_1068305_o.jpg
new turbo trying to figure how to make it work
turbosigma replied to ultraflexxj's topic in Advanced Virtual Mechanic
Do a Compound turbo ( yes, will need another small turbo for the primary). Use one of the exhaust ports on the housing for a wastegate. Edit:- http://www.dsmtuners.com/forums/custom-fabrication/336541-my-compound-turbo-set-up.html -
Valve cover has been reinforced due to the mods on the breaters/baffles - Cam towers now use 10mm arp studs. Engine guy didn't have any problem with it anyway. Valve cover will crack/pull out long before the cam towers. Will replace the rocker shaft springs on 2,3 and 4 with aluminum or bronze sleeves . So the lot will be pulled apart then and checked.
wow -20, and we complain when it's 50 to 60 here. today is 45 or 113 in your language.
Not a Staza, but a distant cousin. Factory carby turbo stetup. http://walkercorp.ath.cx/ghturbo/image016.jpg And now. http://walkercorp.ath.cx/rad-cooler/small/Picture%20003bc.jpg
Turbonetics Godzilla or anything that run's the twin boost/vac port design - That Greddy Type R looks the goods too. http://walkercorp.ath.cx/rad-cooler/small/Picture%20002bc.jpg
Quick Question :- Does your roller cam still stick out the back of the head? The stock magna had it to drive the water pump. I'm using it as my cam trigger to the ecu, so still need it.
New rack and pinion set-up aussy style.
turbosigma replied to emagdnim's topic in Rims, Suspension and Brake Mods
Look'n at this myself - top work - more info here. http://projectzerog.com/forum/viewtopic.php?t=776 Need to get 2 crossmembers and have a go.
