- 8 replies
- 945 views
- 460 views
- 14 replies
- 647 views
- 398 views
lean until warmed up
By jdh0637,
Car has since been running lean until warmup, also lean for a short period of time on hot start when restarting. Is this open/ close loop switch? ohm tested ecu coolant temp, within range temp sender for dash in range air conditioner temp sender shows some crazy resistance, not sure if applicable to air fuel at warm up though literally like a switch is flipped once it reaches certain temp scares me to drive at like 18 aft and to even let it idle like that timing is bumped up to about 13-14.
exhaust manifold
By angeliz78855,
looking for an uncracked exhaust manifold shipped to 34224, thanks
Happy birthday Carguygibby
By SOTTY,
Wishing my brother Colin aka Mr Pancake bunny a very happy birthday.
6 puck sprung hub clutch kit sold
By JohnnyWadd,
Here is a 6 puck sprung hub clutch for your starion or conquest. 240 mm 1988 or 1989 type. Almost in new shape. Estimate 10k miles at most. Comes with a high quality stock replacement pressure plate. This clutch is just slightly "grabby" but it is easy on you clutch foot and on your transmission with the stock type pressure plate and sprung hub. Great for a daily driver that likes to do power slides or fun burnouts and chirp the tires in 1st 2nd and 3rd and still know the clutch will hold out fo
