- 12 replies
- 1098 views
- 601 views
- 9 replies
- 755 views
- 25 replies
- 2518 views
To rich at startup
By hunter85,
I picked up another conquest and it runs good when you get it started. Ok after the first start of the day its fine but if you dont crank the car as soon as you turn the key {IE leave the acc on to listen to radio, set tps, ect} and dont crank the starter it will flood the plugs and not start I know because I can uplug the primary injector and it will run for 10 secs off the gas its dumping into it , plug the injector back in good to go. I checked my oil and it looked amber but had a little gas
Tie rod adjusting sleeve
By JLOPEZ,
Need a driver side tie rod adjusting sleeve with tie rod ends.
need new battery
By randy,
I need to purchase a new battery for my conquest, should I opt for one from sears,or Walmart brand or any other? Also what series batteries are you using?
Exhaust drone with new muffler
By tankbob,
Since Ive owned my car Ive had a apexi fartcannon on there with turbo back 3in exhaust, always hated the look but it sounded great. Recently decided it was time to go quieter so I bought a cherry bomb vortex that someone on here reccomended. It is 3in single inlet and dual 3in outlets, from what Ive read on the muffler it is not supposed to drone but to fit the muffler the shop had to create a near 90 degree bend before the muffler where before it was much less. I know if I go back they wont wel
