- 66 replies
- 5755 views
- 8 replies
- 806 views
- 6 replies
- 863 views
- 834 views
Mitsufest in Socal
By schaffman,
Mitusfest is in two weeks at the California Speedway in Fontana. Sunday 11/23. Lets represent
shaft assembly bearing protector/dust cover, need help!
By Mech,
im really stuck on this one.... so i removed my rear wheel bearings (outer) to replace them....but no matter how i tried it with my bearing separator and press, i couldnt do it without completely damaging this thin removable ring that goes on the shaft..im pretty certain its only function is to keep dirt and junk from getting inside to the bearing (although its sealed on the ring side).....i am replacing the bearings with sealed ones, and could run it without them, but it should really be the
MK1 crank pulley questions
By hunter85,
Ok I put this MK1 pulley on and it starts runs and idles 200% better than with the wiggly one I can also tighten my alternator/water belt finnaly . For funsies I checked the timing {put a new mark on the mk1 pulley exactly where the stock pulley mark was} It was at 6btdc and now it rests at 10btdc without advance and when I started it with advance line still on it was off the scale completely I guess 18-20 btdc. It runs fine and I think the mk1 pulley was slightly bigger {underdrive} which woul
86 hood cable / antenna mast
By randy,
I'm looking for these parts new, also do the dealer have these?
